mjpienaar(at)shaw.ca Guest
Posted: Mon May 28, 2012 6:44 pm Post subject: Help with Wiring |
Hi All,
I found a used "Slick Start" unit on ebay that came without instructions.
Does anybody have a wiring diagram that I could use?
Mike
| | - The Matronics Lom-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lom-List |
sbeaver(at)columbus.rr.co Guest
Posted: Tue May 29, 2012 3:48 am Post subject: Help with Wiring |
You will find a diagram here: http://motorstarna.com/m14p-service-bulletins/57
Connect the ground pin to ground, the power pin to your starter solenoid so that it receives power when the starter is energized, and connect pin one to you left P-lead (in addition to the existing p-lead to mag switch wire. That remains unchanged)
Steve
From: Mike Pienaar <mjpienaar(at)shaw.ca (mjpienaar(at)shaw.ca)>
Reply-To: <lom-list(at)matronics.com (lom-list(at)matronics.com)>
Date: Monday, May 28, 2012 10:43 PM
Subject: Help with Wiring
Hi All,
Mike
com
ronics.com/contribution
Posted: Tue May 29, 2012 7:43 am Post subject: Help with Wiring |
Thanks for the quick reply, appreciate it
Mike
