ddsyverson(at)comcast.net Guest
Posted: Mon May 29, 2006 8:29 am Post subject: Corn Gas - Auto Fuel |
There probably is a lot more to be said about yet about this subject; I see no
one has talked much about the energy content, but we have touched a bit on
the vapor presasure issue.
Corn gas (what we call ethanol in the US - Midwest - probably need to change
that to "cane gas" where it is made from sugar cane) has a couple
characteristics that make it unique in addition to the structural effects on
our equipment.
1) Energy content:
Pure ethanol has approximately 60% of the BTUs of non-ethanol gasoline. A car
which gets 20 MPG on gasoline, will get 12 MPG if recalibrated to run on pure
ethanol (approximately) - everything else being equal (its not actually
equal, but it is close enough to equal for government work). If we use 10%
ethanol/90% gasoline, doing the math says we will get 94% of the energy out
of the 10% corn gas mix compared to non-corn gas. IT ALSO MEANS - we are
running lean by that same amount..... the larger percentage of ethanol, the
leaner we run; and, while a small addition of ethanol might go by unnoticed,
particularily if we have a mixture adjustment on our engine, more than a
little ethanol will mean that a carbureted engine will have to be re-jetted
if it is going to live and run on higher percentages of ethanol. Electronic
fuel injected engines have the ability to fine tune the mixture on our cars
to some degree; and, what we call "flex fuel" EFI cars can run on anything
from 100% gasoline to 85% ethanol by making the rather dramatic mixture
adjustments necessary for this - you could not do that with a carburetor - it
would need to be rejetted.
The Variable venturi carburetors on rotax engines, as I understand it, can
adjust the mixture automatically according to ambient pressure (as with
changes in altitude) But I don't believe they can make the adjustments for
energy content of the fuel - it works differently than the leaning adjustment
on a continental or lycoming which controls the fuel flow - not the air flow.
So.... maybe a rotax can get along on small admixtures of ethanol, but I would
be inclined to take the factory's recommendations since they are the best
source of what works and what doesn't.
2) Vapor pressure: Gasoline and ethanol are not the same. Ethanol, by itself,
is more volatile than gasoline and vaporizes more easily at low pressures,
particularily if it is warm (like at 12,000 feet in New Mexico in August).
Ethanol is a single chemical compound of fairly short structure. Gasoline is a
generous mixture of short and long chain hydrocarbons (heptane, hexane,
octane, nanotane, etc, etc; as well as isomers of each) - causing it to have
both low vapor pressure components and high vapor pressure components - as a
matter of fact in Minne-snowta, the oil companies are kind enough to change
the porportions of short chain to long chain ratios in gasoline seasonally so
the dumb stuff won't vapor lock in the summer and your car will actually
start in the winter - seems the gas has to vaporize a little in order to burn
at all. Basically, you can't change the ratios of short chain to long chain
hydrocarbons with ethanol, because, ethanol, by definition, is a single
compound, not a mixture of compounds like gasoline.
Some parts of the world. Like Brazil, have had a lot of experience (20 +
years) with ethanol in their cars and there has to be a body of information
out there about what works and what doesn't.
Really hoping that EAA will have some updates to their auto gas information.
Later,
Dave S.
St Paul, MN
On Monday 29 May 2006 10:08 am, Randy Daughenbaugh wrote:
<rjdaugh(at)rapidnet.com>
Ignorant question here...why is Ethanol harmful to run in our motors
again??
Andrew
Andrew,
I will take a whack at this one.
A. It is corrosive to some materials
B. It attacks some elastomers.
morid(at)northland.lib.mi Guest
Posted: Tue May 30, 2006 6:40 am Post subject: Corn Gas - Auto Fuel |
Great post Dave.
Deke
smokey_bear_40220(at)yaho Guest
Posted: Tue May 30, 2006 9:57 am Post subject: Corn Gas - Auto Fuel |
Great post Dave!
I am in Brazil today. The pure alcohol price is about
50% of gas, but there is still a mix of gas, diesel,
alcohol and even propane in use on the roads here.
Feelings are mixed on which is best too. Wish I could
find a fuels expert to ask.
I mostly travel up to 10 miles a day on burger power
when not working. Good milage, but occasionally
stalls and sputters when running. Clogged carb.
Certainly not lean..... Slow climb rate too. Do you
think 10% alcohol might help?
Kurt S.
rjdaugh(at)rapidnet.com Guest
Posted: Tue May 30, 2006 12:48 pm Post subject: Corn Gas - Auto Fuel |
While it is true that energy density in alcohol is not as great in
hydrocarbons, one of the mileage problems with running alcohol in engines
designed for gasoline is that the engine is not taking advantage of the
properties of the alcohol. Alcohol (ethanol or methanol) has much higher
octane rating than petroleum. Thus engines could be designed with much
higher compression ratios and we could get much higher mileage from lighter
engines than what results when we burn ethanol in engines designed for
gasoline.
I don't mean to defend the ethanol fuel industry. I am not sure it is fuel
efficient. It takes a lot of energy to grow corn (fertilizer, tractor fuel,
refining the ethanol, etc) but it is paving the way for ethanol from
cellulose. And they are burning it at Indy next year!
Randy
Posted: Tue May 30, 2006 3:10 pm Post subject: Corn Gas - Auto Fuel |
Randy,
I think I saw recently where someone is developing an
alcohol designed engine. Higher compression and more
turbo will make it get about the same MPG as gas.
Kurt S.
--- Randy Daughenbaugh <rjdaugh(at)rapidnet.com> wrote:
| Quote: | While it is true that energy density in alcohol is
not as great in
designed with much
gasoline.
for ethanol from
year!
Randy
