Vertical Power Online Load Planning Tool
Bob.Fairall(at)fairalls.c
PostPosted: Mon May 07, 2012 12:53 pm    Post subject: Vertical Power Online Load Planning Tool Reply with quote
I am fitting a Vertical Power VP-X Sport Electronic Circuit Breaker System to my second Europa.
Vertical Power provide an Online Load Planning Tool. A question asked is "Does your primary alternator have an External Regulator (B & C or similar) or does it have an Internal Regulator (Power Plane or similar). My engine is a Rotax 912S.
Can anyone tell me which of these two types of regulator the 912S has please?
Thanks, Bob Fairall, Kits 71 and 494.
bill mcclellan
PostPosted: Mon May 07, 2012 1:17 pm    Post subject: Vertical Power Online Load Planning Tool Reply with quote
Page 13 of the latest Vertical Power VP-X install manual (Feb 20, 2012) goes into an explanation of the different types of regulators. See if that answers you question. If not email them, they are very helpful.
Bill McClellan
rehn(at)rockisland.com
PostPosted: Mon May 07, 2012 2:11 pm    Post subject: Vertical Power Online Load Planning Tool Reply with quote
If you have a "stock" 912S it comes with an external rectifier-regulator. The generator is mounted on the back of engine, a stator internal generator. The external regulator has several lettered connection points two of which are B and C. Don't know if that is what your VP-X is referencing? Hope this helps.
Jerry
On May 7, 2012, at 1:52 PM, Bob Fairall <Bob.Fairall(at)fairalls.co.uk> wrote:
kingsnjan(at)westnet.com.
PostPosted: Mon May 07, 2012 8:19 pm    Post subject: Vertical Power Online Load Planning Tool Reply with quote
The Rotax has an external regulator but the set-up is a different animal from the one being referred to.
B&C is a reference to B&C Specialty Co.
If I were you I would follow Bill McClellan's advice.
Cheers
Kingsley from Oz (presently in Vancouver BC preparing to descend upon Fred Klein on Orcas Island)
On 08/05/2012, at 6:52 AM, Bob Fairall <Bob.Fairall(at)fairalls.co.uk> wrote:
rampil
PostPosted: Wed May 09, 2012 7:59 am    Post subject: Re: Vertical Power Online Load Planning Tool Reply with quote
If you are set on using this device, why not call them and ask the
company to explain how to use it with a Rotax?
Maybe they can clarify why they apparently do not have clear
documentation for these engines.
Ira N224XS
pestar
PostPosted: Thu May 10, 2012 1:01 pm    Post subject: Re: Vertical Power Online Load Planning Tool Reply with quote
I have a Vertical Power VP-X fitted to my 914 powered DynAero MCR-4S.
It has been in the air for 10 months, I have attached my schematic as how it is all fitted together. Trust this is useful.
I use a Schicke regulator from Germany as the original Rotax Ducati does not have great reliability, no difference in wiring configuration. The circuit also show my overvoltage protection as provided by the VP-X
Cheers Peter
ZK-PSA Alternator-0V-Schicke V4.pdf
Rotax Alternator-0V-Schicke Regulator
 Filename:  ZK-PSA Alternator-0V-Schicke V4.pdf
 Filesize:  36.58 KB
 Downloaded:  528 Time(s)
Peter Armstrong
Auckland, New Zealand
DynAero MCR-4S (Do not shoot me Smile ).
rampil
PostPosted: Thu May 10, 2012 5:48 pm    Post subject: Re: Vertical Power Online Load Planning Tool Reply with quote
Hi Peter,
Thanks for the schemata.
Might be a miss in the wiring. You have two wires leading to the shunt connectors of the MGL box. Both of these wind up on the hot lead from the battery??
Ira
Ira N224XS
pestar
PostPosted: Thu May 10, 2012 11:44 pm    Post subject: Re: Vertical Power Online Load Planning Tool Reply with quote
Ira
Not miswired, in the Schicke regulator that is where they have the indicator lamp and I chose to go without it.
Thanks for the observation.
Cheers Peter
Peter Armstrong
stephen vestuti
PostPosted: Fri May 11, 2012 12:10 am    Post subject: Re: Vertical Power Online Load Planning Tool Reply with quote
Hi Peter,
Interesting circuit diagram, Thanks for posting it .
I was amazed to see that the VPX its self is not protected by a fuse or circuit breaker - it must be reliable !
Also, Ira's observation seems correct,
Steve.
rampil
PostPosted: Fri May 11, 2012 4:39 pm    Post subject: Re: Vertical Power Online Load Planning Tool Reply with quote
Peter,
The shunt is a low value resistor through which all current out of the
alternator flows. The small voltage generated by the current gives
you your ammeter signal to the MGL. It has nothing to do with the
Alternator Warning lamp.
Ira N224XS
