graybeard
Joined: 20 Sep 2011 Posts: 34 Location: Grants Pass, OR
Posted: Fri May 04, 2012 10:44 am Post subject: Wiring Connectors |
It looks like I will have a need for several connectors/terminal strips that can “split� a single power input to multiple outputs. I’m thinking position and strobe light wiring from single VP-X output pins to AeroLED wing tips and rudder lights for example. Anything out there that will do that? I can fab my own, but would just as soon not have to start from scratch.
Stan Loer
RV8 QB
althomas454(at)msn.com Guest
Posted: Fri May 04, 2012 11:19 am Post subject: Wiring Connectors |
Stan,
You might want to give SteinAir a call. They have a good supply of terminal strips and wiring supplies. They are great to work with and I highly recommend them.
http://steinair.com 877-STEINAIR (877-783-4624)
Al Thomas
To: RV8-List(at)matronics.com
Subject: Wiring Connectors
Date: Fri, 4 May 2012 11:43:00 -0700
It looks like I will have a need for several connectors/terminal strips that can “split” a single power input to multiple outputs. I’m thinking position and strobe light wiring from single VP-X output pins to AeroLED wing tips and rudder lights for example. Anything out there that will do that? I can fab my own, but would just as soon not have to start from scratch.
Stan Loer
RV8 QB
rget="_blank">http://www.matronics.com/Navigator?RV8-List
http://forums.matronics.com
Speedy11(at)aol.com Guest
Posted: Sat May 05, 2012 6:34 am Post subject: Wiring Connectors |
Stan,
I can't recall needing a single-to-multiple or multiple-to-single electrical connection during building. Seems like I brought all three position lights to a single terminal on the switch. But, of course, the VPX may require totally different wiring.
It should be relatively easy to construct, but Stein will surely have what you need. He's also agreeable to a phone call.
Stan Sutterfield
www.rv-8a.net
PS - I remember now that I did have a terminal strip at the tail so as to bring all the grounds into a single wire. Don't remember where I bought it but I'm sure an internet search will provide sources.
In a message dated 5/5/2012 12:05:03 A.M. Pacific Daylight Time, rv8-list(at)matronics.com writes:
| Quote: | It looks like I will have a need for several connectors/terminal strips
that can =9Csplit=9D a single power input to multiple
outputs. I=99m thinking position and strobe light wiring from
Stan Loer
RV8 QB
