yourtcfg(at)aol.com Guest
Posted: Wed Apr 25, 2012 7:05 am Post subject: 680FLP |
"Calling Tom Fisher, over" Tom, I am delivering your old 680FLP to FL. It is currently at my home airport. How does the heater work?? Is there a switch or valve that needs moved? I have done the obvious, turn the switch on and the heat up,. The light illuminates, but no heat. It even smells like it may be making heat, but none enters the cabin??? Thanks jb [quote][b]
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
tfisher(at)commandergroup Guest
Posted: Wed Apr 25, 2012 9:07 am Post subject: 680FLP |
Gee I wish you had let me know when you were going to come here.
The heater is a brand new digital heater, I used it once, have no idea what may be out of kilter, the engineer that put it in is no longer around, sorry.
T...
tylorhall(at)mac.com Guest
Posted: Wed Apr 25, 2012 3:18 pm Post subject: 680FLP |
JB and Tom,Great to here another one is back into the air.
Have a good flight JB.
Tylor
On Apr 25, 2012, at 11:06 AM, Tom Fisher wrote:
[quote]Gee I wish you had let me know when you were going to come here.
T...
[quote]---
stratobee
Posted: Wed Apr 25, 2012 5:42 pm Post subject: Re: 680FLP |
Tight squeeze getting her out of your field, JB!
_________________ Adam |
Posted: Wed Apr 25, 2012 8:14 pm Post subject: 680FLP |
Yep probably will be. Lots of HP but little thrust. Should be fine but wont have any room for trouble. jb
Sub22
Posted: Mon Feb 10, 2014 5:27 pm Post subject: Re: 680FLP |
Try slow fighting, nose up. Then try heater ignition. It's worked for me a few times. -30°F
Does it fire up in warm air?
_________________ JS Bennett |
RPMCommander
Posted: Mon Feb 10, 2014 10:38 pm Post subject: Re: 680FLP |
turns out it had alot to do with the airconditioner that was mysteriously removed. Thats all I will say.
