Hopperdhh(at)aol.com Guest
Posted: Sat Apr 14, 2012 3:23 pm Post subject: take off with half flaps |
A rule of thumb I learned from my instructor is (before takeoff roll) to lower the flaps to be even with the full deflected aileron.
This gives good lift without introducing too much drag. With a nose gear I use full up elevator during the takeoff roll until the nose gear is off the runway. Raise the flaps as soon as you are clear of any obstacles.
Dan
N766DH about 500 hours flying since 2004
In a message dated 4/14/2012 6:26:01 P.M. Eastern Daylight Time, sarg314(at)gmail.com writes:
| Quote: | I normally take off in my 6A with no flaps. I let the nose stay down (= lower climb rate) while it accelerates to 105kt IAS and then raise the nose to hold that speed. I have a fixed pitch Catto prop, so take offs are not as energetic as with a constant speed.
I vaguely recall that Vans favors half flaps for take off, I guess in order to shorten ground roll and/or get over that obstacle at the end of the runway. What is the recommended procedure for the half flap take off? When do you drop the flaps? How do you manage the pitch to get the most out of it?
thanks,
Tom Sargent
larywil(at)comcast.net Guest
Posted: Sat Apr 14, 2012 4:57 pm Post subject: take off with half flaps |
Tom,
I do not want to sound like a smart ass, but why
do you want to use your flaps on take-off, other
than a very short field or soft field. I remember
that in the old days, Van was flying out of a
very, very short grass strip ( ~ 1500 ft.). For
him, it would make sense. But the average 160 hp
F/P RV will take off in 800 ft. or less. The 180
with a C/S will do it 400-500 feet. I'm only at
1/2 throttle when my RV-4 is off the ground at 1000 feet or less.
I actually never use flaps to land unless the
strip is less than 2500 ft. with trees. This has
something to do with the fact that my manual
flaps are very difficult to raise at over 70
knots. I had a problem one day with them, and
decided to see what the difference was between
Flaps and No Flaps landings. There were only
minor differences. And "go arounds" were simpler
because I didn't have to worry about the flaps.
Now, maybe my C/S prop helps to slow me down in
the later part of the approach. But it doesn't
slow me down over the numbers. RV's are
incredibly dirty when your doing a round out at
65-70 mph. They slow down and descend like a J-3
Cub. Which, of course, doesn't even have flaps.
When people see an RV-4, 6, 7 or 8 they always
think of it as a "high speed super demon" They
always want to know how fast it goes. I like to
tell them how slow it can go ( Then I brag about
my 3000 ft./min climb and 200 mph top speed)
Finally, please note; I rank in the bottom half
of the "pilot ability rating" . I'm am just
reporting my experiences after 13 years.
Louis Willig
energetic as with a constant speed. Â
thanks,
Tom Sargent
Kellym
Posted: Sat Apr 14, 2012 6:35 pm Post subject: take off with half flaps |
Well, the highest percentage of accidents are loss of control on either
landing or takeoff. The sooner you leave the ground, the lower the risk.
Flaps reduce ground roll, which reduces wear and tear on your tires and
landing gear. IMHO, flaps should be used except when you have a good
reason not to, like strong crosswinds, undulating runway surface, etc.
On 4/14/2012 5:55 PM, Louis Willig wrote:
Tom,
I do not want to sound like a smart ass, but why do you want to use
your flaps on take-off, other than a very short field or soft field. I
remember that in the old days, Van was flying out of a very, very
short grass strip ( ~ 1500 ft.). For him, it would make sense. But the
average 160 hp F/P RV will take off in 800 ft. or less. The 180 with a
C/S will do it 400-500 feet. I'm only at 1/2 throttle when my RV-4 is
I actually never use flaps to land unless the strip is less than 2500
ft. with trees. This has something to do with the fact that my manual
flaps are very difficult to raise at over 70 knots. I had a problem
one day with them, and decided to see what the difference was between
Flaps and No Flaps landings. There were only minor differences. And
"go arounds" were simpler because I didn't have to worry about the
flaps. Now, maybe my C/S prop helps to slow me down in the later part
slow me down over the numbers. RV's are incredibly dirty when your
doing a round out at 65-70 mph. They slow down and descend like a J-3
Cub. Which, of course, doesn't even have flaps. When people see an
RV-4, 6, 7 or 8 they always think of it as a "high speed super demon"
They always want to know how fast it goes. I like to tell them how
slow it can go ( Then I brag about my 3000 ft./min climb and 200 mph
top speed)
Finally, please note; I rank in the bottom half of the "pilot ability
rating" . I'm am just reporting my experiences after 13 years.
Louis Willig
> so take offs are not as energetic as with a constant speed. Â
> thanks,
> Tom Sargent
Checked by AVG - www.avg.com
KCHD |
robin(at)PaintTheWeb.com Guest
Posted: Sat Apr 14, 2012 7:09 pm Post subject: take off with half flaps |
Adding to Kelly's point. I like to unweight the front end ASAP and a little flaps helps there too. I don't think half flaps is right. Suggest you try 1 notch or the equivalent. I put a few degrees in on my 8A go FWF and don't touch anything but trim till I can make the field. Then I reconfigure.
I suggest you go out some nice morning and try 6 TO's in various configurations to see how it feels.
Robin
Well, the highest percentage of accidents are loss of control on either landing or takeoff. The sooner you leave the ground, the lower the risk.
Flaps reduce ground roll, which reduces wear and tear on your tires and landing gear. IMHO, flaps should be used except when you have a good reason not to, like strong crosswinds, undulating runway surface, etc.
sarg314(at)gmail.com Guest
Posted: Sat Apr 14, 2012 8:55 pm Post subject: take off with half flaps |
The reason I am asking is to find out how to best do a short field take off in this plane. I do landings with and without flaps, but my takes offs are always the same.Â
Tom Sargent
ghinman(at)mymts.net Guest
Posted: Sun Apr 15, 2012 5:45 am Post subject: take off with half flaps |
Another reason to take off with no flap is for
engine cooling.
If you notice the engine overheating on takeoff or climb-out
try less flap or no flap.You will notice a difference.
I fly an RV-8.
George H. Inman
ghinman(at)mts.net
204 287 8334
204 799 7062
Posted: Sun Apr 15, 2012 10:19 am Post subject: take off with half flaps |
On 04/14/2012 11:52 PM, thomas sargent wrote: | Quote: | The reason I am asking is to find out how to best do a short field take off in this plane. I do landings with and without flaps, but my takes offs are always the same.
Tom Sargent
| Go for it, especially for short field or soft field operations. I think you'll be amazed at how much quicker it will get off the ground with some flaps. Just remember that full flaps might up the ante a bit if you have an engine out on takeoff while still at low speeds. Try all configs, but I'd bet that 1/3-1/2 would be the best compromise for takeoff.
The 1st time I did it, it was by accident (left them down to protect them from spectators at a flyin, & forgot to raise 'em prior to takeoff). I popped off the ground so quickly (grass strip) that it almost scared me.
Raising them is pretty safe at anything above about 70 kts, as long as you're not trying to climb over an obstacle when you raise them. There'll be minimal settling, but drag goes down & acceleration compensates quickly.
Hope that helps,
Charlie
