graybeard
Joined: 20 Sep 2011 Posts: 33 Location: Grants Pass, OR
Posted: Sun Apr 08, 2012 2:39 pm Post subject: EMF |
Can a ground path generate enough EMF to adversely affect a magnetometer? I had planned to use the upper longerons as the ground path for the elevator trim and tail strobe/position light wiring, but I’m mounting the Dynon Skyview ADAHRS on a bracket bridging the longerons, bringing the two in close proximity. Makes me wonder if I would be better off running separate ground wires.
Stan Loer
RV-8 QB
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 26631 Location: Livermore CA USA
Posted: Sun Apr 08, 2012 3:07 pm Post subject: EMF |
At 03:39 PM 4/8/2012 Sunday, you wrote:
| Quote: | Can a ground path generate enough EMF to adversely affect a magnetometer? I had planned to use the upper longerons as the ground path for the elevator trim and tail strobe/position light wiring, but I'm mounting the Dynon Skyview ADAHRS on a bracket bridging the longerons, bringing the two in close proximity. Makes me wonder if I would be better off running separate ground wires.
Stan Loer
RV-8 QB
Hi Stan,
Always run separate ground wires. I never depend on the airframe for grounding anything. I bring all of the ground wires up to a single point behind the panel. I ZERO and I mean ZERO alternator noise in my headphones.
$.02
I mounted my Dynon Magomenter/AHRS right behind the elevator bellcrank on the RV-6. The compass swings a far amount when I move the elevator though full-throws. In contrast, in the RV-8, I mounted the magnometers under the vertical fin and had no problems with erroneous movements or alignment.
$.02
Matt
Status: 80+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
_________________ Matt Dralle
