bakerocb
Posted: Thu Mar 22, 2012 7:03 pm Post subject: Portable Transponder |
3/2/2012
Hello John Cammarano, I hope that this helps solve your problem.
'OC' Baker
From: "John Delafield" <john.delafield(at)lxavionics.co.uk>
To: <bakerocb(at)cox.net>
Sent: Thursday, March 22, 2012 4:15 PM
Subject: RE: Portable Transponder
| Quote: | Dear Sir,
We assemble the transponder box using a certified TT 21 or 22 which has
FAA
approval so no worries there. The entire box is not approved by anyone
but
as it is portable I do not think it necessary anyway.
The altitude encoder is built in to the transponder and it meets the new
25ft spacing requirement.
I am pretty sure for your application that you would not need the very
expensive hand made leather case that we normally provide and not having
this would reduce the price to you by about $200.
Lead time for delivery would be a few weeks.
I very much hope that we can help you,
All the best,
John Delafield
LX avionics Ltd
07850 950349/01865 374125
www.lxavionics.co.uk
Company Number 4417407 Registered in England and Wales
VAT GB 793 1777 86
Registered address (NOT FOR BUSINESS): 30 St Giles, Oxford
From: bakerocb(at)cox.net [mailto:bakerocb(at)cox.net]
| Quote: | Sent: 22 March 2012 15:42
To: johnd(at)lxavionics.co.uk
Subject: Portable Transponder
3/22/2012
Hello John, We are seeking a portable airtraffic radar transponder for use
in a small homebuilt (no electrical power) fixed wing airplane in the US.
Your products seen here:
http://www.lxavionics.co.uk/portables.htm
appear to offer a solution.
I have two questions:
1) How is the information normally provided to a transponder by an
altitude
encoder for automatic altitude information transmission by the transponder
provided for in your products?
2) Are you aware of any regulatory reason (TSO or inspection requirements)
that would make your products not be acceptable for use in the United
States?
Thanks for your help,
'OC' Baker Says: "The best investment we can make is the time and effort
to
gather and understand knowledge."
jessevli(at)zeelandnet.nl Guest
Posted: Fri Mar 23, 2012 3:40 am Post subject: Portable Transponder |
I would suggest to use an external antenna with a good groundplane. It doubt the VSWR is very good the way when it is directly connected (however Trig products will give an error when the VSWR is very high).
Another point to think of is the high peak power that a transponder is transmitting (about 125 or 250 Watt depending on class) The pulse duration is only short, lowering the average power. My transponder test equipement suggest to take a distance of at least to meter to reduce field strength your exposed to during transponder field testing.
When the antenna is directly on the unit you will be likely close to the antenna. Some scientist say that exposure to high level RF fields is not dangerous, while other doubt this, I think it is better to take some distance from the antenna to reduce the field strength at your seating position.
Jesse
