GeorgeCoy
Posted: Mon Feb 20, 2012 5:55 am Post subject: Rate 100LL, 93/93 Autogas (10% ethanol) & 91 Mogas for A |
Stay away from the fuel with ethanol. It will damage the rubber bits in the
fuel system. My personal opinion is use 100LL or a mix of 100LL and the 91
MOGAS. These engines were developed around the use of leaded fuels.
| | - The Matronics M14PEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
Snazpappy
Posted: Sat Jul 13, 2019 7:12 pm Post subject: Re: Rate 100LL, 93/93 Autogas (10% ethanol) & 91 Mogas f |
What kind of mix would you suggest George?
GeorgeCoy
Posted: Mon Jul 15, 2019 6:27 am Post subject: Rate 100LL, 93/93 Autogas (10% ethanol) & 91 Mogas for A |
We do not recommend using any fuel with alcohol. It is very detrimental to
the rubber products in the fuel system. We also do not recommend unleaded
auto gas as the in the long term it causes cylinder problems. The engine was
designed for leaded fuel. Personally in all my years I have never used
unleaded auto gas in my aircraft.
If you are so pressed economically to use auto fuel or in a situation where
avgas in not available then use a lead substitute. (or add lead as my
Russian friends did for years when avgas was not available)
George Coy
