brubakermal(at)yahoo.com Guest
Posted: Tue Jan 24, 2012 4:21 am Post subject: call me willy |
yes please call me willy
Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022
Sent: Monday, January 23, 2012 11:32 PM
Subject: Re: Kitfox-List: I just need a prop
Hi I have a prop on Barnstormers came off a 503
listed under ultralights
--- On Tue, 1/24/12, Malcolm Brubaker <brubakermal(at)yahoo.com> wrote:
Subject: I just need a prop
To: "kitfox-list(at)matronics.com" <kitfox-list(at)matronics.com>
Date: Tuesday, January 24, 2012, 12:25 AM
needed a prop for a 503 60in. its for a quicksilver belt drive on floats so a gearbox tractor will work. must be composit
Sent: Monday, January 23, 2012 6:23 PM
Subject: Kitfox-List: Re: Used 912ul wanted
--> Kitfox-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com>Hi Guys,The S, F and A are certified engines. The 912UL (UL= Ultralight) is the 80 hp and the 912ULS (ULS = Ultralight special) is a 100 hp. The 912S is the certified version of the 912ULS. The 100 hp after 2003 comes with a slipper clutch, but the 912UL's do not unless it was added as an option. The engine doesn't carry by itself an SLSA rating. That is on the total aircraft from that particular aircraft Mfg. The engine can be used in anything. If it goes into an experimental than it falls under those rules.--------Roger LeeTucson, Az.Light Sport Repairman - Maintenance RatedRotax Repair Center - Heavy Maint. RatedHome 520-574-1080 TRY HOME FIRSTCell 520-349-7056Read this topic online here:http://forums.matronics.com/viewtopic.php?p=364616#364616 http://www.matronics.com/Navigator?Kitfox-List> ========================
el=nofollow target=_blank>http://www.matronics.com/Navigator?Kitfox-List
et=_blank>http://forums.matronics.com
occom
Posted: Tue Jan 24, 2012 7:20 am Post subject: call me willy |
Ok, From now on you are willy. Willy Brubaker! How does your wife feel about this change?
[quote] From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Malcolm Brubaker
Sent: January-24-12 8:19 AM
Subject: call me willy
Subject: Re: I just need a prop
Subject: Re: Used 912ul wanted
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
Posted: Tue Jan 24, 2012 1:51 pm Post subject: call me willy |
just dont call me late for supper. we still have a kitfox lite for sale on barnstormers
or juat go to my web site at michigansportpilotrepair.com
and our state ultralite banquet will be feb11 in midland mi
Sent: Tuesday, January 24, 2012 10:17 AM
Subject: RE: call me willy
Subject: Kitfox-List: call me willy
--> Kitfox-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com> Hi Guys, The S, F and A are certified engines. The 912UL (UL= Ultralight) is the 80 hp and the 912ULS (ULS = Ultralight special) is a 100 hp. The 912S is the certified version of the 912ULS. The 100 hp after 2003 comes with a slipper clutch, but the 912UL's do not unless it was added as an option. The engine doesn't carry by itself an SLSA rating. That is on the total aircraft from that particular aircraft Mfg. The engine can be used in anything. If it goes into an experimental than it falls under those rules. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=364616#364616 http://www.matronics.com/Navigator?Kitfox-List> ========================
