tdawson-townsend(at)auror Guest
Posted: Tue Jan 24, 2012 6:04 am Post subject: Bonanco brake lines |
Listers:
I'm thinking of replacing the plastic brake lines in the cabin. Can anyone say, if I call Bonaco and ask for "RV-10 brake lines", do they already know the appropriate measurements, or will I have to provide them?
N52KS
jdriggs49(at)msn.com Guest
Posted: Tue Jan 24, 2012 6:16 am Post subject: Bonanco brake lines |
Yes they know the right size.
Subject: Bonanco brake lines
Date: Tue, 24 Jan 2012 14:01:36 +0000
Listers:
N52KS
http://forums.matronics.com
philperry9
Posted: Tue Jan 24, 2012 6:30 am Post subject: Bonanco brake lines |
They have the measurements for all of the lines except the long runs through the tunnel and the shorter runs from the tunnel to the LG mounts.
Check out my video of a full installation. It'll help you make some choices regarding lengths of those runs if you want them.
http://youtu.be/gemgQmVsOYI
Phil
On Tue, Jan 24, 2012 at 8:13 AM, Danny Riggs <jdriggs49(at)msn.com (jdriggs49(at)msn.com)> wrote:
[quote] Yes they know the right size.
From: tdawson-townsend(at)aurora.aero (tdawson-townsend(at)aurora.aero)
Listers:
N52KS
amekler
Posted: Tue Jan 24, 2012 6:33 am Post subject: Bonanco brake lines |
I have the ones from www.nonstopaviation.com
Alan
On Jan 24, 2012, at 9:01 AM, "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero (tdawson-townsend(at)aurora.aero)> wrote:
[quote] Listers:
N52KS
glastar(at)gmx.net Guest
Posted: Tue Jan 24, 2012 7:21 am Post subject: Bonanco brake lines |
Just be aware, that this is a replacement for the plastik lines only but
not for the alu lines you have in the tunnel.
Cheers Werner (progressing slowly)
Listers:
N52KS
mregoan(at)hispeed.ch Guest
Posted: Tue Jan 24, 2012 9:31 am Post subject: Bonanco brake lines |
Having an intense fear of flaring, I chose to replace all the aluminum and plastic tubing with Bonaco lines.
I was very impressed by Phil Perry's installation and copied it, with some slight modifications. For anyone interested, the attached document shows the results. There is a table at the end of the document with the hose sizes, lengths, fittings and clocking not only for the standard Bonaco RV-10 set but also for the tunnel brake and fuel hoses. Note the caveat on the fuel lines from the tanks - I haven't yet had the wings on to verify the length and clocking but as far as I can see they are good! As for the rest I am happy with the result.
Cheers,
Gordon Anderson
41015, Switzerland
Description: |
 Download |
Filename: |
Brake_and_Fuel_System_Modifications.pdf |
Filesize: |
2.31 MB |
Downloaded: |
353 Time(s) |
Brian Steeves
Posted: Wed Jan 25, 2012 2:11 pm Post subject: Re: Bonanco brake lines |
I replaced every brake line with ones from Bonaco. They did a great job and everything fit great. Would definitely do it again.
I gave him a couple of measurements but had all the rest. SHould have everything you need now.
Brian
