brubakermal(at)yahoo.com Guest
Posted: Mon Jan 23, 2012 4:28 pm Post subject: I just need a prop |
needed a prop for a 503 60in. its for a quicksilver belt drive on floats so a gearbox tractor will work. must be composit
Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport (989)513-3022
Sent: Monday, January 23, 2012 6:23 PM
Subject: Re: Used 912ul wanted
--> Kitfox-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)>
Hi Guys,
The S, F and A are certified engines. The 912UL (UL= Ultralight) is the 80 hp and the 912ULS (ULS = Ultralight special) is a 100 hp. The 912S is the certified version of the 912ULS. The 100 hp after 2003 comes with a slipper clutch, but the 912UL's do not unless it was added as an option. The engine doesn't carry by itself an SLSA rating. That is on the total aircraft from that particular aircraft Mfg. The engine can be used in anything. If it goes into an experimental than it falls under those rules.
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center - Heavy Maint. Rated
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=364616#364616http://www.matronics.com/Navigator?Kitfox-List>  ========================
fishhawk16(at)yahoo.com Guest
Posted: Mon Jan 23, 2012 8:35 pm Post subject: I just need a prop |
Hi I have a prop on Barnstormers came off a 503
listed under ultralights
--- On Tue, 1/24/12, Malcolm Brubaker <brubakermal(at)yahoo.com> wrote:
Subject: I just need a prop
To: "kitfox-list(at)matronics.com" <kitfox-list(at)matronics.com>
Date: Tuesday, January 24, 2012, 12:25 AM
Subject: Kitfox-List: Re: Used 912ul wanted
Hi Guys,
Roger Lee
Tucson, Az.
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=364616#364616 http://www.matronics.com/Navigator?Kitfox-List> ========================
el=nofollow target=_blank>http://www.matronics.com/Navigator?Kitfox-List
et=_blank>http://forums.matronics.com
llow target=_blank>http://www.matronics.com/contribution
| [quote][b]
