redrocketrider
Joined: 13 May 2011 Posts: 67 Location: Nervino airport
Posted: Wed Jan 11, 2012 2:30 pm Post subject: Radiator Cap for Rotax 912 |
Hi All,
Happy New Year!
We have a dilemma, just got off the phone with Aircraft Spruce and they want $80 for one radiator cap!!
Anyone know of another source to purchase one not costing that much?
Thanks Bob
Toodie & Bob Marshall
Beckwourth, CA
KF/4/1200 flying
_________________ Keep the dirty side down/Blue skies. Bob |
helili(at)chahtatushka.ne Guest
Posted: Wed Jan 11, 2012 2:41 pm Post subject: Radiator Cap for Rotax 912 |
I’d try my nearest auto parts store.
John Hart
KF !V
Wilburton, OK
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of rtmarshall
Sent: Wednesday, January 11, 2012 4:25 PM
Subject: Radiator Cap for Rotax 912
Hi All,
Happy New Year!
Thanks Bob
Beckwourth, CA
KF/4/1200 flying
KeysFox
Posted: Wed Jan 11, 2012 2:44 pm Post subject: Radiator Cap for Rotax 912 |
Rotax went to a higher pressure radiator cap for 912s a few years ago to
allow a little hotter coolant temp before boil over.
Thought it was less than $80 from Lockwood, in sebring Florida.
BJ
Kitfox IV 912/80 hp.
Quote: | Hi All,
Happy New Year!
Thanks Bob
Beckwourth, CA
KF/4/1200 flying
_________________ B Jones
N154K
443-480-1023 |
peteohms
Posted: Wed Jan 11, 2012 3:03 pm Post subject: Radiator Cap for Rotax 912 |
I get mine at the auto parts store for $6.
Pete
Kitfox III 912
On 1/11/2012 4:25 PM, rtmarshall wrote: [quote] Hi All,
Happy New Year!
Thanks Bob
Beckwourth, CA
KF/4/1200 flying
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
Posted: Wed Jan 11, 2012 3:34 pm Post subject: Radiator Cap for Rotax 912 |
After a little research, found that the 912 uses a pressure of 1.2 bar for the radiator cap. 1.2 bars is equivalent to 17.4 pound per square inches.
18 psi caps by Stant are available from amazon.com:
http://www.amazon.com/Stant-10234-Radiator-Cap-PSI/dp/B000B8JUG6
17 psi caps are also available from amazon.com:
http://www.amazon.com/Stant-10251-Radiator-Cap-PSI/dp/B000C8226K
I’d try one of these rater than shelling out $80. May be that your local auto parts store can get one for you without the shipping charge.
John Hart
KFIV
Wilburton, OK
Hi All,
Happy New Year!
Thanks Bob
Beckwourth, CA
KF/4/1200 flying
lcfitt(at)sbcglobal.net Guest
Posted: Wed Jan 11, 2012 5:19 pm Post subject: Radiator Cap for Rotax 912 |
I find this interesting. Kitfoxes generally - at least the earlier ones
with 912 and the external radiator run a bit on the cool side. Is there
another advantage for the high priced high temp thermostat? As mentioned, I
would go to the nearest auto parts store, but good luck there. If It isn't
in their computer matched with make model and year they might just shoo you
away as my two local stores did a while ago.
Lowell
Sent: Wednesday, January 11, 2012 2:40 PM
Subject: Re: Radiator Cap for Rotax 912
BJ
> Hi All,
> Happy New Year!
> Thanks Bob
> Beckwourth, CA
> KF/4/1200 flying
redrocketrider
Posted: Wed Jan 11, 2012 8:37 pm Post subject: Radiator Cap for Rotax 912 |
Thanks lowell, I am sure you are right, a fellow on the list has provided
some great info and I am on the hunt. Bob
Beckwourth, CA
KF/4/1200 flying
Sent: Wednesday, January 11, 2012 5:15 PM
Lowell
BJ
> Hi All,
> Happy New Year!
> Thanks Bob
> Beckwourth, CA
> KF/4/1200 flying
redrocketrider
Posted: Wed Jan 11, 2012 8:53 pm Post subject: Radiator Cap for Rotax 912 |
Hi John, The problem that I think I will have is that the coolant tank radiator cap is about 1/2 the size of a standard cap. I know of a great radiator shop over in Reno and I will take this gold plated beauty made exclusively for Rotax and there probably is some smaller German car that may have a cap this size, I am not totally toast yet, but I am losing small amounts of coolant and it could be that all the air is not out of the system yet, as I changed to dextron which has seemed to help but it is 16 to 24 * F up here so it is hard to tell at this point, I thought I would toss a new cap on just for grins but the old one certainly looks good at the moment. Thanks for everybody's help once again. This is the older 912. Bob
Beckwourth, CA
KF/4/1200 flying
Guy Buchanan
Posted: Wed Jan 11, 2012 11:05 pm Post subject: Radiator Cap for Rotax 912 |
On 1/11/2012 8:50 PM, rtmarshall wrote: Quote: | I know of a great radiator shop over in Reno and I will take this gold plated beauty made exclusively for Rotax and there probably is some smaller German car that may have a cap this size,
Hey my Acura has a teeny tiny radiator cap. I'll check it tomorrow.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded
Now a glider pilot, too.
Deceased K-IV 1200
A glider pilot too. |
KeysFox
Posted: Thu Jan 12, 2012 6:05 am Post subject: Radiator Cap for Rotax 912 |
I replaced all hoses and installed an in-line water temp sending unit per
Rotax/Lockwood suggestions, and about 30 hours later had to retighten
clamps because of very slight coolant loss. I never saw signs of coolant
on any pipe, hose, clamp, but retightening the clamps did the trick.
As an aside, the in-line water temp is a bit HIGHER than the CHT mounted
reading, even when gauges and sending units are switched, so an error in
sending units, cables and gauges is not the cause. I use UMA gauges and
matched sending units.
BJ
Kitfox IV with early S/N Rotax 912 80 hp
Quote: | Hi John, The problem that I think I will have is that the coolant tank
older 912. Bob
Beckwourth, CA
KF/4/1200 flying
Sent: Wednesday, January 11, 2012 3:30 PM
Subject: RE: Radiator Cap for Rotax 912
inches.
I'd try one of these rater than shelling out $80. May be that your
John Hart
KFIV
Wilburton, OK
Hi All,
Happy New Year!
Thanks Bob
Beckwourth, CA
KF/4/1200 flying
http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution
N154K
443-480-1023 |
Posted: Thu Jan 12, 2012 7:56 am Post subject: Radiator Cap for Rotax 912 |
John, this note reminds me that in the day the gasket would occasionally leak and someone came up with an automotive replacement. It was from a Mercedes, I believe. I can't find my reference. Maybe someone else has the info.
Lowell
Sent: Wednesday, January 11, 2012 8:50 PM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Beckwourth, CA
KF/4/1200 flying
9 [quote][b]
Guy Buchanan
Posted: Thu Jan 12, 2012 9:42 am Post subject: Radiator Cap for Rotax 912 |
On 1/12/2012 7:52 AM, Lowell Fitt wrote: Quote: | this note reminds me that in the day the gasket would occasionally leak and someone came up with an automotive replacement. It was from a Mercedes, I believe. I can't find my reference. Maybe someone else has the info. |
Lowell,
Are you thinking of the Mercedes gas cap gasket?
Guy Buchanan Normal Guy Buchanan 2 21 2011-09-20T05:05:00Z 2011-09-20T05:05:00Z 1 31 183 1 1 213 14.00 <![endif]--> 59 false false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} <![endif]--> <![endif]--> <![endif]-->
Guy Buchanan
Assistant Scoutmaster – Troop 680
760.809.6145
gebuchanan(at)cox.net (gebuchanan(at)cox.net)
www.troop680.org
Deceased K-IV 1200
Posted: Thu Jan 12, 2012 10:27 am Post subject: Radiator Cap for Rotax 912 |
Guy,
Thanks for that. I guess it is a little of the senior moment thing. Gas cap - radiator cap, all the same to me. Now if my wife was home, she could help me find the project I'm working on.
Lowell
Sent: Thursday, January 12, 2012 9:37 AM
Lowell,
Guy Buchanan
760.809.6145
www.troop680.org
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
redrocketrider
Posted: Thu Jan 12, 2012 3:12 pm Post subject: Radiator Cap for Rotax 912 |
Hey thanks Guy.
Beckwourth, CA
KF/4/1200 flying
[quote] From: Guy Buchanan (gebuchanan(at)cox.net)
Sent: Wednesday, January 11, 2012 11:01 PM
Guy Buchanan
Ramona, CA
| [b]
Guy Buchanan
Posted: Mon Jan 16, 2012 1:53 pm Post subject: Radiator Cap for Rotax 912 |
OK. Time warp. Checked the Acura and it has a nice, teeny, very weird, radiator cap. Nothing like the 912. However I did find this interesting thread:
http://forums.matronics.com/viewtopic.php?p=296729
Did you already know about this?
Guy Buchanan
Ramona, CA
On 1/11/2012 11:01 PM, Guy Buchanan wrote: [quote] On 1/11/2012 8:50 PM, rtmarshall wrote: Quote: | I know of a great radiator shop over in Reno and I will take this gold plated beauty made exclusively for Rotax and there probably is some smaller German car that may have a cap this size,
Guy Buchanan
Ramona, CA
Deceased K-IV 1200
redrocketrider
Posted: Tue Jan 17, 2012 11:58 am Post subject: Radiator Cap for Rotax 912 |
On My way to Beemer! Thanks Guy
Beckwourth, CA
KF/4/1200 flying
Sent: Monday, January 16, 2012 1:51 PM
Guy Buchanan
Ramona, CA
On 1/11/2012 11:01 PM, Guy Buchanan wrote: Quote: | On 1/11/2012 8:50 PM, rtmarshall wrote: Quote: | I know of a great radiator shop over in Reno and I will take this gold plated beauty made exclusively for Rotax and there probably is some smaller German car that may have a cap this size,
Guy Buchanan
Ramona, CA
| [b]
