etienne.phillips(at)gmail Guest
Posted: Mon Jan 02, 2012 12:10 pm Post subject: Headset microphone level reducer |
Hi All
I have two dissimilar headsets that have very different microphone output levels. The one headset is an oldish basic Avcomm model, and the other is a new child-sized one. My MGL radio/intercom doesn't have the ability to reduce the volume of the new headset adequately.
I've never worked with electret microphones before, so am not sure how to build a signal reducer. I have noticed that they are polarity sensitive, which leads me to expect some phantom power is required...?
I need to reduce the volume by about 15dB (according to the MGL radio) to match the Avcomm. Ideally, I'd like to be able to build a passive circuit that I can squeeze into the headset itself, rather than an interface box or off-the-shelf device. This will allow me to use the new headset in other aircraft as the Avcomm's seem to play nicely with other major brands.
If anyone has some insight, I'd be most appreciative!
Etienne
Posted: Mon Jan 02, 2012 3:36 pm Post subject: Headset microphone level reducer |
At 12:29 PM 1/2/2012, you wrote:
<etienne.phillips(at)gmail.com>
Hi All
Are both microphones intended for interface to an aviation
transmitter/intercom inputs? 15 db is a BIG difference.
An aviation microphone, is powered by a bias current
applied to a combination of ELECTRONICS as an amplifier
and the electret microphone element.
The goal is to reduce magnitude of signal voltage
without materially upsetting the DC power that is
supplied to the microphone's electronics. I would
suggest a resisteor in series with say a 100uF/10v
capacitor tied right across the microphone's signal/
power wires. We know that the microphone's AC output
impedance is some finite value. Let's assume 1000 ohms.
Okay, you're wanting to attenuate the AC signal by
about 2/3. So the resistor in series with the capacitor
will be 500 ohms or less. This is just an guess/example
and but it's in the ballpark. You can fiddle with the
value of the fixed resistor until the two microphones
demonstrate near equal performance.
Having a capacitor in series with the resistor will
keep the AC load resistor from also affecting the
DC power that comes out of the radio or intercom to
power the microphone.
Posted: Tue Jan 03, 2012 10:19 pm Post subject: Headset microphone level reducer |
Thanks Bob!
That's exactly the kind of circuit I was looking for. I'll get back to you on it's effectiveness.
The new child headset is supposedly an aviation one, and the destination is an aviation MGL radio, so one would have hoped that there wouldn't be such a large discrepancy in levels!
Thanks again
Etienne
