first flight of G-UMPY Sywell
graeme bird
PostPosted: Sun Dec 11, 2011 5:08 am    Post subject: first flight of G-UMPY Sywell Reply with quote
inaugural flight of G-UMPY yesterday and Sywell, at the capable hands of Andy Draper.
Sounds fantastic going overhead, dont know why it should sound any different to any other 912 engined plane.
"A good one" the man said.
However, on inspection after today's flight the Port water downpipe to the radiator is too close to the exhaust. I'll need to move the raditor/air guide down and back slightly and maybe use a silicone pipe or add insulation somehow. Its a classic body with XS FWFD anyone else had this issue?
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
rlborger(at)mac.com
PostPosted: Sun Dec 11, 2011 5:44 am    Post subject: first flight of G-UMPY Sywell Reply with quote
Graeme,
CONGRATULATIONS! on the first flight of G-UMPY. You should be able to resolve the plumbing issue and enjoy many hours flying your own Bird. I'll be at the hanger later this morning and will see if I can get some pictures of my down-pipe for you.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
Graeme Bird
G-UMPY
Mono Classic/XS FWFD 912ULS/Warp drive FP
Build nearing completion
http://forums.matronics.com/viewtopic.php?p=360665#360665
steven.pitt2(at)ntlworld.
PostPosted: Sun Dec 11, 2011 6:53 am    Post subject: first flight of G-UMPY Sywell Reply with quote
Congratulations Graeme - hope to see you out and about during the coming
year.
Steve Pitt
G-SMDH trigear XS
flyingphil2
PostPosted: Sun Dec 11, 2011 9:41 am    Post subject: Re: first flight of G-UMPY Sywell Reply with quote
Well done and congratulations Graeme, bet you can't wait to fly it yourself.
Phil
jimpuglise(at)comcast.net
PostPosted: Sun Dec 11, 2011 9:51 am    Post subject: first flight of G-UMPY Sywell Reply with quote
Graeme-
CONGRATULATIONS! Isn't it nice to have most of the build behind you? Not starts the real work! Enjoy!
Jim Puglise
N283JL -- 13.8 hrs.
Sent: Sunday, December 11, 2011 8:08:11 AM
Subject: Europa-List: first flight of G-UMPY Sywell
--> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk>
Graeme Bird
G-UMPY
< -Matt Dralle - List Contribution Web Site -
europapa
PostPosted: Sun Dec 11, 2011 11:20 am    Post subject: Re: first flight of G-UMPY Sywell Reply with quote
Hi Graeme,
congrats to this big moment.
On my Europa classic I had the same problem with the radiator hose to close to the exhaust.
The hose broke one due to the high temperature.
The owner before then used some heat shield material, zhe same as used on the firewall.
That worked so far but I now replaced the hose with a alloy pipe but have not been airborne jet.
The Rotax installation book recommends this too.
Regards Juergen
ward.t(at)xtra.co.nz
PostPosted: Sun Dec 11, 2011 12:09 pm    Post subject: first flight of G-UMPY Sywell Reply with quote
Congratulations Graeme, well done. All the best for the test flying which is great fun and enjoy the touring. Nice to see another "classic" in the air.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
ptag.dev(at)tiscali.co.uk
PostPosted: Sun Dec 11, 2011 12:44 pm    Post subject: first flight of G-UMPY Sywell Reply with quote
Well done Graham.
Now join up for some tours.....
Bob Harrison G-PTAG
kingsnjan(at)westnet.com.
PostPosted: Sun Dec 11, 2011 6:49 pm    Post subject: first flight of G-UMPY Sywell Reply with quote
Congratulations Graeme and all the best for many enjoyable hours of flying in the future.
Gee, mine must be close to being the only Classic yet to fly!!
Best regards
Kingsley in Oz
Graeme Bird
G-UMPY
Ivor Phillips
PostPosted: Mon Dec 12, 2011 1:17 pm    Post subject: first flight of G-UMPY Sywell Reply with quote
Very well done Graeme, Hope to see you at some of the rallies in the new year,
All your hard work will repay it self tenfold in the shear pleasure of flying a aircraft you
built your self,
best wishes
Ivor Phillips
On 12 December 2011 02:45, Kingsley Hurst <kingsnjan(at)westnet.com.au (kingsnjan(at)westnet.com.au)> wrote:
[quote]--> Europa-List message posted by: Kingsley Hurst <kingsnjan(at)westnet.com.au (kingsnjan(at)westnet.com.au)>
Best regards
Kingsley in Oz
On 11/12/2011, at 11:08 PM, "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)> wrote:
> --> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
> Graeme Bird
> G-UMPY
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
graeme bird
PostPosted: Tue Dec 13, 2011 2:07 pm    Post subject: Re: first flight of G-UMPY Sywell Reply with quote
Thanks for all the posts, really nice of you all.
I attach a picture of the plane (same as the rest, except perhaps not so polished) and Andy Draper and my inspector Matthew Boddington.
Gumpy at the end of its first flight at Sywell dec 10-12-11
 Filesize:  66.42 KB
 Viewed:  19019 Time(s)
Graeme Bird
kit4 (Wagstaff) TBD
fklein(at)orcasonline.com
PostPosted: Tue Dec 13, 2011 4:57 pm    Post subject: first flight of G-UMPY Sywell Reply with quote
You look suitably proud Graeme, and your polish exceeds my standards,
ever decreasing as they may be as I pressure myself to finish.
What's the back story on your use of what appears to be an XS cowl on
your Classic?...and your prop/spinner combo is?
Congratulations,
Fred
wdaniell(at)etb.net.co
PostPosted: Wed Dec 14, 2011 4:41 am    Post subject: first flight of G-UMPY Sywell Reply with quote
Belated congrats from Colombia...i second fred's comments
Will
stephen vestuti
PostPosted: Wed Dec 14, 2011 11:59 am    Post subject: Re: first flight of G-UMPY Sywell Reply with quote
Well Done and Congratulations ! she looks stunning.
Looks as if all those hours in the shed have finally paid off.
Happy Flying !
graeme bird
PostPosted: Sun Mar 04, 2012 2:45 am    Post subject: Re: first flight of G-UMPY Sywell Reply with quote
Well, did the test flights, got the permit (took a couple of months), and have just about completed the coaching (LAA scheme) with Andy Draper at Sywell and met the insurance requirements (5hrs, 15 landings).
Not too much trouble so far with landings. All on grass, different conditions/runways.
Few small snags to sort:
I find the gear leaver hard to pull off the notch - might need a different handle
I need a rubber slit on it to stop water/air coming up the slot,
Original tyre is rubbing slightly (might try some hellerman oil on it before each flight) I guess I'll have to change to the thinner one soon.
Witter ASI tends to ring on rotation.
Andy has been great.
Otherwise all good and very pleasing.
Graeme Bird
kit4 (Wagstaff) TBD
Dave Disney
PostPosted: Sun Mar 04, 2012 10:47 am    Post subject: Re: first flight of G-UMPY Sywell Reply with quote
Well done Graeme,
As a Europa wannabe I'm interested to learn more about your insurance costs. Are you a tail wheel pilot of old or are you new to the Europa transferring from a tricycle?
5 hrs 15 landings doesn't seem too onerous to me.
Dave
graeme bird
PostPosted: Sun Mar 04, 2012 10:58 am    Post subject: Re: first flight of G-UMPY Sywell Reply with quote
Dave, I have about 600hrs, all tricycle, several different types, been with Traffords for about 10 years mostly as part of a syndicate on a Rallye.
Insurance is around £1500. I had also insured the project with them. No accident history.
Didnt seem that bad to me considering my C42 is/was around 1200-1300.
Interestingly, I now have a one-up/ one down policy with them for around another 350 so both planes are insured presently (me only though).
Graeme Bird
kit4 (Wagstaff) TBD
PostPosted: Sun Mar 04, 2012 12:57 pm    Post subject: first flight of G-UMPY Sywell Reply with quote
Well done Graeme.
So how soon will we be seeing you on a tour ?
Bob Harrison G-PTAG
graeme bird
PostPosted: Sat Mar 31, 2012 12:04 pm    Post subject: Re: first flight of G-UMPY Sywell Reply with quote
After around 70 practice landings on grass Andy Draper sat with me while I tried the mono on tarmac for the first time. Interesting, not that scary though, seems to want to rock a bit and I was recommended not to feel compelled to get back on the Centre Line once I'd wandered off but to keep straight.
Also tried my short grass strip with no head wind a few times.The strip seemed a lot shorter than with my C42.
So my formal training is complete and it didn't seem so difficult to me.
Graeme Bird
kit4 (Wagstaff) TBD
