kearney
Posted: Sun Dec 04, 2011 8:49 pm Post subject: Window Installation |
Hi
I am getting closer to finishing my avionics which means windows are on the horizon. After reading the many posts regarding crazing and other weld-on challenges, I am wondering what the the current consensus is on window installs.
I am leaning to Silpruf for the side / door windows but that still leaves a big hunk of plexi upfront.
Does anyone have a guide to window install that eliminate / reduces the risks associated with Weld-on. Given that I live in Canada, Weld-on may be difficult to get Weld-on so I may have to consider alternatives.
Inquiring minds need to know.
Les
#40643
Kellym
Posted: Sun Dec 04, 2011 9:08 pm Post subject: Window Installation |
PM sent with Michael Sausen's write-up using urethane adhesive Geoff
Combs used. circa Oct 2, 2009.
alternatives.
Les
#40643
KCHD |
n223rv(at)wolflakeairport Guest
Posted: Mon Dec 05, 2011 4:52 am Post subject: Window Installation |
I used sika flex on 2 RV-10's with great success, and weld-on on 1 RV-10 with poor success. So poor we had to replace 1 side window and the windshield.
Of course, your results may vary. Many people have had success with weld-on, but the margin for error is much less.
-Mike Kraus
On Dec 5, 2011, at 12:04 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
Quote: |
PM sent with Michael Sausen's write-up using urethane adhesive Geoff Combs used. circa Oct 2, 2009.
> Hi
> Les
> #40643
davidsoutpost(at)comcast. Guest
Posted: Mon Dec 05, 2011 6:09 am Post subject: Window Installation |
I used the same method that we used on the Cozy MKIV to install the windows in my -10, epoxy mixed with flox. Then followed up with 2 layers of 2.5" wide BID glass tape on the outside. I have never heard of a window coming off a Rutan canard aircraft using this method. Last year I replaced the glass in my Cessna and used Weld-ON to glue the compass mount to the new windshield. Within a month crazing was apparent. No way I was going to use that crap again!
David Clifford
RV-10 Builder
Howell, MI
Sent: Sunday, December 4, 2011 11:43:33 PM
Subject: Window Installation
Hi
Les
#40643
gipsowh(at)hotmail.com Guest
Posted: Mon Dec 05, 2011 7:00 am Post subject: Window Installation |
Les, am currently replacing my windshield that I installed about three years ago. During a very hot summer here in S. E. Texas, one day I opened my hangar door to discover crazing over the entire windshield. What the ...
All I can think of is that the weld on 10 wouldn't allow expansion causing stress fractures. Will be using silka-flex this time.
Sent from my iPhoneBill Gipson
On Dec 4, 2011, at 10:56 PM, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
[quote] Hi
Les
#40643
Kelly McMullen
Posted: Mon Dec 05, 2011 7:12 am Post subject: Window Installation |
Just curious why few folks seem to have any interest in the Lord 7545A/E urethane adhesive Geoff located and tested to be as strong as Weld On without the negative aspects.
On Mon, Dec 5, 2011 at 7:57 AM, Bill Gipson <gipsowh(at)hotmail.com (gipsowh(at)hotmail.com)> wrote:
Quote: | Les, am currently replacing my windshield that I installed about three years ago. During a very hot summer here in S. E. Texas, one day I opened my hangar door to discover crazing over the entire windshield. What the ...
Les
#40643
A&P/IA, EAA Tech Counselor
KCHD |
robin(at)PaintTheWeb.com Guest
Posted: Mon Dec 05, 2011 8:44 am Post subject: Window Installation |
We were very happy with Silka flex too. The Glasair guys generally use Silka flex as their default choice.
Robin
aerosport1
Posted: Mon Dec 05, 2011 10:42 am Post subject: Window Installation |
If I am not correct please let me know on this but I believe all Sikaflex
material is a polyurethane base material
And it only comes as a single component material. The Lord 7545A/E material
is a 2 part urethane material which has higher Heat deflection temperature
and is a harder material than the Silkaflex adhesives. I am not sure which
one people
Have used for installing the windows but the Lord is a very good solution.
It is very easy to clean up. Just use
A urethane reducers like PPG DT870. This will not hurt your windows but
works great on cleanup. I would always
Chose a 2 part material over a single part any time when a strong bond or
durable surface is required. Using a
Air cured type system is not as good in my opinion and experience.
FWIW
Geoff
Geoff Combs
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Posted: Mon Dec 05, 2011 10:53 am Post subject: Window Installation |
I might add that Silka flex was our solution long before Geoff made his recommendation. I would generally give great weight to Geoff's suggestions regardless of the topic.
Robin
Posted: Mon Dec 05, 2011 11:48 am Post subject: Window Installation |
How much do you use on a -10, and where do you get it in smaller quantities?
Linn
one people
FWIW
Geoff
Geoff Combs
Aerosport Modeling& Design
614-834-5227p
614-834-5230f
efdsteve(at)aol.com Guest
Posted: Tue Dec 06, 2011 8:53 am Post subject: Window Installation |
I spent quite a bit of time looking for the Lord product in the smaller quantities but was unable to find it. If anyone wants to split a larger order, please let me know. I'm just about ready to pull the trigger with Van's recommendation.
Thanks.
Steve Weinstock
40230
Posted: Tue Dec 06, 2011 11:39 am Post subject: Window Installation |
Does anyone know what the sealant is that's used to install car windshields?
Linn
Jim(at)sold702.com Guest
Kellym
Posted: Tue Dec 06, 2011 12:27 pm Post subject: Window Installation |
http://www.chemical-concepts.com/index.php/lord-7545-a-7545-g-1-1-pak-50ml.html
On 12/6/2011 9:47 AM, efdsteve(at)aol.com wrote:
[quote] I spent quite a bit of time looking for the Lord product in the
Thanks.
Steve Weinstock
40230
KCHD |
sean(at)stephensville.com Guest
Posted: Tue Dec 06, 2011 1:02 pm Post subject: Window Installation |
How many 50ml kits would be needed to do all? Windscreen, doors and
side windows?
-Sean #40303
> Thanks.
> Steve Weinstock
> 40230
