rvdave
Posted: Fri Dec 02, 2011 5:54 pm Post subject: wiring list |
Getting back to working on the 10 after remodeling work at home, am getting ready to order some wiring and items for fwf to aft fuselage so I can close things up and have compiled a list of things, wondering if anyone can see what I'm missing. So far the only thing I have running back is static line.
18' #2 cable
30 ' 7 conductor shielded cable- 1 for servo, 1 extra
18' antenna cable
battery contactor
starter contactor
misc crimp connectors for #2 cable
_________________ Dave Ford
Cadillac, MI |
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Fri Dec 02, 2011 6:54 pm Post subject: Re: wiring list |
Dave,
If you mean what to run forward to aft in terms of cables and wires, here are things to consider.
1. Power and ground to tail light. This will be dictated by the type of light(s), ie, strobe, incandescent, or LED. Note that strobe/LED can be synchronized which adds a wire.
2. Pitch servo - 7 wires
3. Elevator trim - 5 wires
4. Some AHRS units and magnetometers go back there. This could be several wire bundles. I recommend installing conduit for pulling wires later.
5. Remote mounted transponder and/or ADS-B could go back there.
6. Pos and ground battery wires to starter and engine or common grounding point.
7. Power from battery to main buss(es).
8. Coax for comm antenna(s).
9. Multiple conductor to ELT. Shielded 2 pair for GPS feed, power, and phone type cable to control ELT from panel switch.
10. Passenger headsets
11. Lights, power outlets, or anything else mounted back there.
12. Door reed switch wires
13. Battery master contactor wire
14. More wires if you are installing 2 batteries or a cross-feed connector
15. Transponder coax
If you want to include wing wires, then there are more.
What about oxygen system plumbing?
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
kearney
Posted: Fri Dec 02, 2011 7:10 pm Post subject: wiring list |
Dave
Here are the things going to my tail.
Magnometer wiring - 2
Elt wiring
Comm Antenna coax - 2
GPS antenna coax
Nav antenna coax
O2 lines to bottle in baggage area
Wiring for vent to rear of overhead plenum
Wiring for cabin lights in overhead plenum
Wiring for rudder trim
Wiring for elevator trim
Wiring for autopilot pitch servo
Wiring for tail light
Wiring to Whalen lighting system power supply and return lines for wing nav lights
I ran conduit along the sides to aft if the baggage area. One per side. It would have been better to have a couple of lines per side.
Cheers
Les
On 2011-12-02, at 6:54 PM, rvdave <davidbf(at)centurytel.net> wrote:
18' #2 cable
18' antenna cable
battery contactor
starter contactor
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=360088#360088
