Pulsar-List Digest: 5 Msgs - 11/10/11
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List
Bob H
PostPosted: Fri Nov 11, 2011 6:46 am    Post subject: Pulsar-List Digest: 5 Msgs - 11/10/11 Reply with quote
I used breaker switches because they were available to me. Sized them for
anticipated electrical loads and has worked fine. Can turn components on/off
easily. Only had one kick off in service when lights pulled too many
amps.Converted to LEDs and no issues anymore.
Bob H
[quote] From: Pulsar-List Digest Server <pulsar-list(at)matronics.com>
Reply-To: <pulsar-list(at)matronics.com>
Date: Thu, 10 Nov 2011 23:57:25 -0800
To: Pulsar-List Digest List <pulsar-list-digest(at)matronics.com>
Subject: Pulsar-List Digest: 5 Msgs - 11/10/11
Today's complete Pulsar-List Digest can also be found in either of the
of the Pulsar-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2
011-11-10&Archive=Pulsar
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter
Pulsar-List Digest Archive
Total Messages Posted Thu 11/10/11: 5
Today's Message Index:
1. 01:37 PM - Fuses vs. Circuit Breakers (Lance Goddard)
2. 01:47 PM - Re: Fuses vs. Circuit Breakers (pilot623)
3. 02:01 PM - Re: Fuses vs. Circuit Breakers (Brian Anderson)
4. 03:44 PM - Re: Fuses vs. Circuit Breakers (Dennis Adams)
5. 07:05 PM - Re: Fuses vs. Circuit Breakers
(dougwitkowski(at)netscape.net)
________________________________ Message 1
_____________________________________
Time: 01:37:12 PM PST US
Subject: Fuses vs. Circuit Breakers
In a recent email discussion with Myron Truex he suggested I get input
from builders/flyers on their opinions of fuses versus circuit
breakers. It obviously makes sense to have some circuitry protected
by circuit breakers and some not-so-critical circuits protected by
fuses.
What have you done, and what - if anything - might you do differently
if you were to start from scratch? Also, physical location of these
fuses and circuit breakers has importance as well. Your thoughts?
Lance Goddard
________________________________ Message 2
Time: 01:47:13 PM PST US
Subject: RE: Fuses vs. Circuit Breakers
I went with automotive type fuses all the way. The fuse blocks are mounted
under the map/glove box, hinged to swing out from under the panel for access
(but not in flight). I'd do it the same way again.
Jim
- The Matronics Pulsar-List Email Forum -
http://www.matronics.com/Navigator?Pulsar-List
gregsmi
PostPosted: Fri Nov 11, 2011 6:58 am    Post subject: Pulsar-List Digest: 5 Msgs - 11/10/11 Reply with quote
I use breakers because in flight, I do not want to fumble around trying to figure out if a fuse has gone out. When something is tripped you can reset it for emergency use. I bought the breakers from an aircraft salvage business. They have boxes of them in all sizes, and not expensive. In fifteen years, never tripped a breaker.
Greg
Pulsar/Jabiru 2200
In a message dated 11/11/2011 8:47:07 A.M. Central Standard Time, bobh5(at)earthlink.net writes:
[quote]--> Pulsar-List message posted by: Bob Hartunian <bobh5(at)earthlink.net>
Bob H
HTML Version:
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=20
fuses.
Lance Goddard
Jim
pulsarhenry(at)t-online.d
PostPosted: Fri Nov 11, 2011 9:26 am    Post subject: Pulsar-List Digest: 5 Msgs - 11/10/11 Reply with quote
look out for ( P ) PTC fuses - - - http://www.belfuse.com/Data/UploadedFiles/PTC-Fuses.pdf
I use the 16 volt types and never had troubles.
Henry Schlueter
SP 100
D - E O H S - - - http://www.youtube.com/user/sp100ifly
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pulsar-List All times are GMT - 8 Hours
