N968TP
Goto page 1, 2  Next
dlm34077(at)q.com
PostPosted: Mon Oct 31, 2011 6:57 am    Post subject: N968TP Reply with quote
Anyone know about this?
Report created 10/31/2011 Record 6   ********************************************************************************** IDENTIFICATION Regis#: 968TP Make/Model: EXP Description: VANS RV10 Date: 10/30/2011 Time: 1514 Event Type: Incident Highest Injury: Minor Mid Air: N Missing: N Damage: Unknown ********************************************************************************
dmaib@me.com
PostPosted: Mon Oct 31, 2011 9:17 am    Post subject: Re: N968TP Reply with quote
Can't seem to find any news reports about this. Strange.
David Maib
RV-10 #40559
New Smyrna Beach, FL
Strasnuts
PostPosted: Mon Oct 31, 2011 10:08 am    Post subject: N968TP Reply with quote
I see it was certified on 4/2011 low serial number 40031. I found nothing
too.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
dlm34077(at)q.com
PostPosted: Mon Oct 31, 2011 10:24 am    Post subject: N968TP Reply with quote
Pilot or owner of 968TP listed in FAA records as TORELLO FORTUNATO TACCHI of
Jacksonville FL with Private ASEL/S, instrument and IA. Crash site is about
30-40 miles north of Jacksonville. Airworthiness and registration are listed
as 4/2011
philperry9(at)gmail.com
PostPosted: Mon Oct 31, 2011 10:52 am    Post subject: N968TP Reply with quote
I found some notes that indicate the aircraft has been flying since 2006/7ish.
Also found that it had an air boat engine that was overhauled by the owner back around that time frame.
VAF was the source of both.
as 4/2011
dlm34077(at)q.com
PostPosted: Tue Nov 01, 2011 9:47 am    Post subject: N968TP Reply with quote
http://www.charltoncountyherald.com/articles/2011/11/02/news/doc4eb00f9f0f36
c342285798.txt
PostPosted: Tue Nov 01, 2011 9:54 am    Post subject: N968TP Reply with quote
Sounds like fuel exhaustion.....
"The plane, out of Hilliard, was reportedly returning from Waycross when it ran out of fuel, clipped some trees and flipped into a hay field near the edge of Folkston."
http://www.charltoncountyherald.com/articles/2011/11/02/news/doc4eb00f9f0f36c342285798.txt
On Mon, Oct 31, 2011 at 9:50 AM, DLM <dlm34077(at)q.com (dlm34077(at)q.com)> wrote:
robin(at)PaintTheWeb.com
PostPosted: Tue Nov 01, 2011 10:01 am    Post subject: N968TP Reply with quote
Light plane crashes in Folkston field
Published:
Tuesday, November 1, 2011 11:46 AM EDT
Some Charlton County cows got a surprise on Sunday morning when a small plane crashed into a field they were grazing.
The pilot was able to make his way out of the crushed aircraft and then walk nearly half-a-mile to Hwy. 121 where he was picked up by a passing motorist and transported to Charlton Memorial Hospital where he was treated.
Charlton County Sheriff Dobie Conner said the incident was reported to his department around 1 p.m. on Sunday, but the actual crash occurred earlier in the morning. The pilot was the lone occupant of the plane and no one on the ground ��†not even a cow ��†was injured.
The FAA was called in to investigate the incident.
 Filesize:  75.73 KB
 Viewed:  10285 Time(s)
rv10rob(at)gmail.com
PostPosted: Tue Nov 01, 2011 12:05 pm    Post subject: N968TP Reply with quote
So is that the 5th RV-10 hull loss now?
On Tue, Nov 1, 2011 at 10:59 AM, Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)> wrote:
Published:
Tim Olson
PostPosted: Tue Nov 01, 2011 12:26 pm    Post subject: N968TP Reply with quote
I think it's more than that...
We've had:
The Dan Lloyd Incident
The IFR incident
The possibly Medical incident
The inflight fire
The post-landing fire
The out-of-gas (this one)
.. and I'm not positive if the others were hull losses but I know there
were at least a couple others, one being the V-8 I think that pancaked
in (not sure if they got it flying again?), and another one that was
a botched landing that punched the gear up through. Off the top of my
head I can't remember if that's it or not. At least I *think* the
hull losses are less than you can count on 2 hands.
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
Bob Turner
PostPosted: Tue Nov 01, 2011 12:32 pm    Post subject: Re: N968TP Reply with quote
More than that. By my count:
3 fatals: auto engine failure/botched corn field landing
improper IMC
Probable in flight heart attack
non-fatal: auto engine/fire on the ground
in flight fire-fuel connection loose- may not be total loss
crash in OH 28 Sept 2011 cause unknown
this one.
Bob Turner
RV-10 QB
aerosport1
PostPosted: Tue Nov 01, 2011 12:37 pm    Post subject: N968TP Reply with quote
Tim is correct with the accidents. I think it is 6 total losses so far.
Geoff Combs
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
arplnplt(at)gmail.com
PostPosted: Tue Nov 01, 2011 12:38 pm    Post subject: N968TP Reply with quote
What about the one just before this one with the guy from Texas taking delivery? Did we ever find out what the cause was on that one?
Dave Leikam
We've had:
The IFR incident
The inflight fire
... and I'm not positive if the others were hull losses but I know there
> Rob Kochman
> Woodinville, WA
rleffler
PostPosted: Tue Nov 01, 2011 12:39 pm    Post subject: N968TP Reply with quote
, one being the V-8 I think that pancaked in (not sure if they got it flying again?)
It was repaired and flew into OSH 2 years ago.
bob
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
jcumins(at)jcis.net
PostPosted: Tue Nov 01, 2011 12:41 pm    Post subject: N968TP Reply with quote
Yes, the bad part it could have been avoided completely.  There is no excuse for running out of gas when flying over the US.  There is a airport just about every 50 miles.
This is a total shame and just drives everyones insurance rate higher, due to bad decisions.
John Cumins
40864, wing top skins moving forward.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Tuesday, November 01, 2011 1:02 PM
Subject: Re: Re: N968TP
Published:
Bob Turner
PostPosted: Tue Nov 01, 2011 1:04 pm    Post subject: Re: N968TP Reply with quote
"What about the one just before this one with the guy from Texas taking delivery? Did we ever find out what the cause was on that one?"
This was the Ohio crash. Per VAF the pilots are now both out of the hospital although the builder was seriously burned. The builder has posted on VAF his condition but has not said anything about the cause. Curiously, it also is not listed on the NTSB web site yet.
As to running out of gas, this certainly is very poor judgement. Although, until the facts are in, we don't know. Maybe there was a serious undetected fuel leak. I will say, though, that some pilots are type A personalities. The owner of this latest accident aircraft has previously posted on VAF about his (illegal) experimentation with car gas in a certified airplane.
Bob Turner
RV-10 QB
pitts_pilot(at)bellsouth.
PostPosted: Tue Nov 01, 2011 1:31 pm    Post subject: N968TP Reply with quote
improper IMC
This one may be being rebuilt in Melbourne, FL.
Linn
this one.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=356577#356577
jcumins(at)jcis.net
PostPosted: Tue Nov 01, 2011 1:39 pm    Post subject: N968TP Reply with quote
Man people are stupid. Auto fuel in a certified plane, yes there are stc's
for them, but not many really do not work out well. I have helped recover
many a plane in Alaska out in the bush due to auto fuel for one reason or
another. And when auto fuel burns it is very hard to see the flame when it
is small and it's flash point is so much lower than 100LL.
You would never catch me using auto fuel in any airplane.
Bob yes I agree with you the story is not complete and that there could have
been a fuel leak causing the plane to run out sooner than expected or very
fast, but that's not the usual case.
Bob another thing that might need to be brought up is the quality of the
flares people are making on their own. I have seen so many flares that were
not made correctly and over flared or the flare was not deep enough. This
the leaks found in the Vans airplane is way too high. I am not sure if it
is a training issue on how to make tubing flares correctly or is it the
cheap soft tubing that vans supplies.
I will be for sure using 5052 tubing in my -10, yes it is much stiffer and
much harder to work with but it is much stronger and less likely to crack.
So the real question is?? Is the leak rates that are being found due to
material issues or craftsman quality of making the tubing??
Just my thoughts.
John Cumins
President
707-425-7100
707-425-7576 Fax
jdriggs49(at)msn.com
PostPosted: Tue Nov 01, 2011 1:47 pm    Post subject: N968TP Reply with quote
Did you count the one from several years ago from Lebanon, TN that crashed in south Alabama in IMC??
[quote] Date: Tue, 1 Nov 2011 17:28:31 -0400
--> RV10-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net>
> --> RV10-List message posted by: "Bob Turner"<bobturner(at)alum.rpi.edu>
> improper IMC
Linn
> this one.
> Bob Turner
> RV-10 QB
amekler
PostPosted: Tue Nov 01, 2011 3:13 pm    Post subject: N968TP Reply with quote
Tim,
What do you think these accidents/incidents will do to our insurance rates? Is the Rv-10 rate higher than other comparable planes?
Alan
N668G
Goto page 1, 2  Next
Page 1 of 2
