lcfitt(at)sbcglobal.net Guest
Posted: Thu Oct 27, 2011 6:38 am Post subject: Low RPMs at Run Up |
A friend is experiencing low RPMs on a brand new 912 ULS. He reports that
one ignition circuit will have the RPM drop to 1600 or so with rough
running. He thinks that he has at least two plugs that are not firing. He
has followed the book and not done any of the "never dos". He has switched
the modules and the problem follows the module. Total time on the engine is
about 5 hours. Much of that spent on trying to diagnose the ignition
issues.
Any suggestions? He is trying to avoid the "New Low Price" of $1100 for a
new module.
Lowell
Aerobatics(at)aol.com Guest
Posted: Thu Oct 27, 2011 7:52 am Post subject: Low RPMs at Run Up |
try basics....
Plugs are cheap re gap etc....
Make sure its set up per spec....
In a message dated 10/27/2011 9:38:51 A.M. Central Daylight Time, lcfitt(at)sbcglobal.net writes:
| Quote: | --> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
issues.
new module.
Lowell the ies ay - MATRONICS WEB FORUMS - List Contribution Web Site p;
