Recommendation M-14 engines
Goto page Previous  1, 2
mark.bitterlich(at)navy.m
PostPosted: Tue Oct 11, 2011 7:15 am    Post subject: Recommendation M-14 engines Reply with quote
Sorry. Thought he meant it could be used to TIME THE ENGINE. I had
assumed he was responding to the message string.
So yep, agree... it would be better than a screwdriver stuck in the
sparkplug hole to find TDC, which is less than good. Smile
Mark
p.s. I re-started this work address, and will see what happens. You
know what I am talking about Dennis.
PostPosted: Tue Oct 11, 2011 7:18 am    Post subject: Recommendation M-14 engines Reply with quote
Sorry for the misunderstanding on my part. Yes, you are correct on TDC
finder. Correct on pointer, but hard to do with spinner, but Dennis
showed me a tool to take care of that too.
It's been done "by the book" for decades, and it obviously works. That
said, I have my doubts on what the timing REALLY is when using this
method. Sure it works, the engine runs, and the mag drop is fine... but
is every engine set this way accurate to within a degree? I'm not sure,
but I kinda doubt it.
The TIMERITE might work in this regard (only on fixed timing mags; per
Walt's comments) but it may be not much better than what we have.
However, it would not hurt in any way to have the company be convinced
to make the proper parts to support the M-14 engine (Again; with the
right mags).
Mark
PostPosted: Tue Oct 11, 2011 7:33 am    Post subject: Recommendation M-14 engines Reply with quote
Didier,
If (and "if" runs into several different issues), the TIMERITE worked
corrected, you could screw it into the spark plug hole and HOPEFULLY
time the engine to within a degree or less with repeatable results. You
could also do it with a spinner on the engine, and without any other
tools. It is not a matter of simply replacing the Top Dead Center tool,
which personally I do not find very accurate.... .but again that also
revolves around Walt's comments regarding piston dwell and the
difficulty in determining just exactly where TDC is because of it. In
any case, once you find TDC, you need to move the engine to the proper
position so as to set the mags properly. Putting a piece of safety wire
on the front and trying to use the front engine timing strip is all well
and good, but ... again the issue of prop spinners, using yet another
tool, etc. There is also the matter of gear lash in the planetary gear
assy, since this is a geared engine. Get that wrong, and your timing is
going to incorrect as well.
In addition, I always have been suspect of a timing strip mounted
externally on ANY engine. Just how accurate is that piece? Do you know
for sure? Nope... no way you can know for sure. When you use something
that is totally related to actual engine piston movement, I believe you
can get much more accurate and you are not relying on something someone
else "calibrated" that is external on the engine.
Listen... to all that read this. I am not recommending to anyone that
they change whatever they happen to like doing. There is no argument or
debate intended here. The goal was simply to get a company to make
parts that would allow their device to be used on M-14 engines. Whether
anyone here decides that they want to use it or not is really not the
point. It just never hurts to have other options.
Or am I missing something here? Wouldn't be the first time for that
either.
Mark
viperdoc(at)mindspring.co
PostPosted: Tue Oct 11, 2011 8:00 am    Post subject: Recommendation M-14 engines Reply with quote
mark,
from what I can tell so far, the Russian timing light does pretty much that. Getting your hands on one though is the challenge.
Doc
wlannon(at)shaw.ca
PostPosted: Tue Oct 11, 2011 8:10 am    Post subject: Recommendation M-14 engines Reply with quote
The TIMERITE is, as Mark indicated, a very dependable and accurate
instrument. It is relatively simple and easy to use. Since it is using
piston position directly there is no need for a precise location of TDC (in
angular terms) only an assurance that the piston is at TDC on the
compression stroke. This can be determined with your thumb.
If ATS could be persuaded to manufacture the necessary arm and scale for
their existing unit it would be by far the best way to time the M14P with
M9F (fixed spark) mags.
which is most engines.
Walt
tigeryak18t
PostPosted: Tue Oct 11, 2011 9:20 am    Post subject: Recommendation M-14 engines Reply with quote
OK Mark
I get it.
We are very happy in Europe to know that in the US you know how to reproduce tools and parts for our old plane. And often better than the original. So yes I get it and I will also ring Timerite to add a voice to the count. Even if at the end everybody is using whatever tool tyhey want at least that would fix a standard tool.
Get it
thanks for all your effort to make me understand
Cheers and FLY SAFE PLEASE for the sake of the Yak community.
Didier
2011/10/11 Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
[quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
Didier,
either.
Mark
Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing
PostPosted: Tue Oct 11, 2011 10:57 am    Post subject: Recommendation M-14 engines Reply with quote
Excuse me? "The Russian Timing Light" ?? Not aware of same. How does it work? Most timing lights I have used are triggered off the spark plug firing. That then fires the light. But this is a geared engine? I am also not so sure I would want to be sitting there with the engine running and the prop RIGHT THERE!
Any more details on this?
Mark
PostPosted: Tue Oct 11, 2011 11:02 am    Post subject: Recommendation M-14 engines Reply with quote
Thanks for making perfectly clear what I was struggling to get across.
Mark
PostPosted: Tue Oct 11, 2011 11:10 am    Post subject: Recommendation M-14 engines Reply with quote
Thanks Didier, and my apologies for explaining all this poorly. Please
see Walt's comments for a clear and concise explanation. Also, my last
post to you was not proof read very carefully. Sorry for all the
grammatical errors as well!
Take care, and thanks for all your help with other issues over in Europe
as well.
Mark
tigeryak18t
PostPosted: Tue Oct 11, 2011 12:34 pm    Post subject: Recommendation M-14 engines Reply with quote
Mark
always a pleasure speaking with pleasant and passionnate people.
Thanks to you Mark and with you all the people that we know well.
Now I know what it is to try to do something when nobody does and receive only criticism and misplaced remarks.....
You there on the other side are giving us strenght.
kind regards
Didier
as well.
Mark
Didier Tiger YAK18T
French Wing
wlannon(at)shaw.ca
PostPosted: Tue Oct 11, 2011 7:24 pm    Post subject: Recommendation M-14 engines Reply with quote
Maybe the Russian timing light looks somrthing like the Russian land mine
detector.
Page 2 of 2
