Tim(at)MyRV10.com Guest
Posted: Fri May 19, 2006 11:11 am Post subject: What fuel pressure should I see for electric or engine fuel |
Just to add to the diagnosis... You will actually hear the
electric fuel pump spin up and as it builds pressure you can
hear it. So if you're pressure is always 6, but you hear
the pump working harder, you know it's in the gauge.
You could always stick a mechanical gauge in the
threaded sensor thing if you had to. Everyone's comments
are right though, you should see much more pressure. I'm
in the mid 20's without boost on.
Rene Felker wrote:
Hate to ask the obvious, but where is your sensor hooked up? Before or
after the servo?
Rene' Felker
