rvbuilder(at)sausen.net Guest
Posted: Fri May 19, 2006 10:56 am Post subject: What fuel pressure should I see for electric or engine fuel |
I believe this is the standard boost pump system that Van's sells.
Michael Sausen
RV-10 #352 Working on Fuselage
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-li st-server(at)matronics.com] On Behalf Of Brinker
Sent: Friday, May 19, 2006 11:49 AM
Subject: Re: What fuel pressure should I see for electric or engine fuel pump on IO-540 engine.
--> RV10-List message posted by: "Brinker" <brinker(at)cox-internet.com>
&nb sp; I had the same question a while back. I contacted Airflow Performance about it. Here is a copy & pasted email from them, Randy...............................
  ; We manufacture a boost pump to be used with fuel injected
engines. P/N 3090050 $375.00. The pump is 12 VDC, fuel pressure is 25-30
PSI, flow capacity is 32 GPH (at) 30 PSI, requires a 7-10 amp breaker.
You fuel injection system (Bendix) requires 22-35 PSI to operate. If you have a diaphragm engine driven pump (P/N LW15473) this pump should produce
22-26 PSI. If you engine has a vane pump it should be set to 26-35 PSI.
Don Rivera
Airflow Performance
111 Airflow Drive
Spartanburg, SC 29306
Phone: 864-576-4512
Fax: 864-576-0201
E-Mail: Airflow2(at)bellsouth.net
