Ray.R.Doerr(at)sprint.com Guest
Posted: Fri May 19, 2006 10:50 am Post subject: What fuel pressure should I see for electric or engine fuel |
I just found this on Dynon's sites as well. I will have to
check tonight, but I suspect I have mine set for Type 1 when it should
be type 2. This makes sense because the engine runs fine and the
builder (America's Aircraft Engines) ran the engine for over an hour at
75% power.
Thank You
Ray Doerr
