jesse(at)itecusa.org Guest
Posted: Fri May 19, 2006 10:18 am Post subject: What fuel pressure should I see for electric or engine fuel |
By the way, tachometer may be the same thing. We were only getting about
2,000 rpm I think on the reading when we tested it with a visual tachometer
and found that it was right at red-line. Make sure you check the settings
for all of the different probes, especially if you are seeing something odd
like that.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
