jesse(at)itecusa.org Guest
Posted: Fri May 19, 2006 10:17 am Post subject: What fuel pressure should I see for electric or engine fuel |
With the Dynon, there are different settings for different sensors. Some
sensors are for Carbureted engines while some are for injected. If you got
the fuel injected probes, then you will need to tell the Dynon unit that you
have the injected probe. That is most likely your issue. If all else
fails, call Dynon and ask which sensor to tell the unit that you are using.
Hope this helps.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
