Ray.R.Doerr(at)sprint.com Guest
Posted: Fri May 19, 2006 10:02 am Post subject: What fuel pressure should I see for electric or engine fuel |
Thanks for all the replies. I bought the electric boost pump
directly from Van's for the fuel injected engines. My fuel system is
per Van's exactly for the fuel injected engine. This is why I can't
explain the 6 psi from my Dynon Engine monitor when the electric boost
pump is running. I will check the engine driven fuel pump as well
tonight. But I can't believe that I have the wrong electric and engine
driven pump, because both of them only register 6 psi on the Dynon.
Thank You
Ray Doerr
40250
