europapa
Posted: Thu Oct 06, 2011 12:53 pm Post subject: CAD file of instrument panel |
Hi,
I am about to make a new instrument panel and will replace all my vacuum driven avionics with an Dynon D-100.
I would like to use a laser cut service but the laser will only move with the right software.
I am absolutely unexperienced in this matter.
Has somebody got a file of the shape of the main panel?
Or can somebody help me with the whole project?
Where can I find the plate to close the whole where the vacuum pump has been mounted?
Thank you
Juergen
D-EBOA
gregoryf.flyboy(at)comcas Guest
Posted: Thu Oct 06, 2011 1:42 pm Post subject: CAD file of instrument panel |
Hello Juergen,
The lasers will work with more than one piece of software.
The one I would recommend the most would be Corel Draw. The next would be
Autocad. I have used both, with the laser that I have access to.
If you work on a file with either of these, they should work fine. Need more
help? I can work with you off-list.
I will eventually make a file to create the main panel, that will use a
laser to cut it...but have not done it yet. Maybe someone else has? If so, I
would like to get the file as well
Greg
europapa
Posted: Fri Oct 07, 2011 9:10 am Post subject: Re: CAD file of instrument panel |
Hi Greg,
few hours ago I received my Dinon.
Now I think it would be simple enough to make the tree cut outs by hand.
Anyway thank you very much for your kind offer.
Juergen
