Heavy In-flight Vibration Riddle
Goto page Previous  1, 2, 3  Next
wdaniell(at)etb.net.co
PostPosted: Sun Oct 02, 2011 6:18 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Something worked loose and vibrated in the slipstream - a landing light perhaps from your clue
Will
kjburns(at)btinternet.com
PostPosted: Mon Oct 03, 2011 2:21 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
My thoughts would carb related maybe choke, maybe one choke cable slipped causing rich mixture and plugs to foul on one pair of cylinders, or some litter, bag , leaf etc ingested in to air intake, or colapsed air filter in to one carb intake or other ,
But a more simple reason could be:- more simply we are driven mad by a banging flap of plastic on our hanger door in 10 knot + breeze so sugest a flap of some sort, plastic, caught up on some part of the airframe banging in turbulent air at vairious prop speed/ angular settings !
Kevin.
To: "europa-list(at)matronics.com" <europa-list(at)matronics.com>
Sent: Sunday, 2 October 2011, 19:40
Subject: Re: Heavy In-flight Vibration Riddle
Raimo,
The other is carb heat left on for take off?
Cheers,
Toby,
Tim's other son
Tim Ward 12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Ph 64 3 3515166
Mob 0210640221
On 3/10/2011, at 4:58 AM, "Raimo Toivio" <raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)> wrote:
[quote] All
I have got plenty of good guesses via list and also direct.
Some of you have hoped I will not publish them with their names and do not worry I wont´t.
Graham – I /we got an empty message from you – please retype it – I am sure it will be a good info.
One of you have guessed the problem was because a broken de-icing rubber in the prop blade. That´s good but unfortunately my Europa is so far still missing de-icing systems totally. They would be soon very useful in Finland.
No one has so far found a reason for my vibra.
So there are still a possibility to get an Xmas packet from Finland.
I quarantee the shipment will be worth of making a good guess.
Tips:
- the reason was off /on or black /white –type and very easy to repair; it was fixed in seconds.
- when finally found it was not invisible at all.
Go On!
Cheers, Raimo OH-XRT
Sent: Saturday, October 01, 2011 10:44 PM
To: [url=mailto:europa-list(at)matronics.com]europa-list(at)matronics.com (europa-list(at)matronics.com)[/url]
Subject: Heavy In-flight Vibration Riddle
All
I have hope-so a nice riddle for you.
Maybe all the answers are useful – let´s collect them all:
Yesterday I took off from a very remote /small /windy (90 degrees 12 knots and gusting MUCH) grass strip. Soon until well over the ground at altitude +500 feet with full power and 2nd fuel pump still on and gears up I felt suddenly let us say medium or more shake and vibration. My immediate reaction was to go around and land immediately but abandoned because wind was so furious and I felt I cannot do that (a succesful landing).
I decided to try to fly to the next possible sensible airfield EFHV which was 10 minutes apart.
Those minutes were long: I put my prob (Airmaster CS) to manual and drived it from fine to coarse, tried all the power settings and also a 2nd fuel filter. Finally I noticed that when prop was in a climb mode (in my case 5400 rpm /Rotax 912S) and MAP around 20 inches I got quite a comfortable flying mode and I headed straight home. My airspeed was w that selection about 110 knots but because of a strong headwind GS was only about 70 knots (wanted to be clearly over the ground at 3000 ft because it was well over sunset and totally dark, yesterday we got sunset around 1600 Zulutime and time was well over 1630 when flying).
So, I pushed home one looooong hour. All the aerodynamics were well. I was a bit worried my engine will separate or so. When trying to push more pwr it was more vibra and when trying to pull less pwr same. I Followed a main highway and decided to land there if feeling so. Cars there with lights are almost like a lighted runway...
Finally landing to the EFTP flawlesly.
Today we had a FHGP (Family Hangar Grill Party). I tried to check my plane as well as I can. I found something. Very small evidence but something anyway. I tried to fix it and had a test run. I elected to go to fly – hey I am a test pilot who else – and She was better than ever!
I managed to do 2 touches and goes when C172 did one with same runway.
140 knots during downwind makes me always happy.
So – dear Ladies and Gentlemen – what was wrong?
It would be nice and very life-useful to hear your opinions or guesses what was wrong.
The Rules: one single guess per person, please.
The Prize: The Best Guess will get a Very Special Xmas Present from Finland!
I will let you know a solution after a week – be patient.
Have a nice weekend and
Cheers, Raimo Toivio
<Europa%20A2A-ala2OK[1].png> Europa XS Mono OH-XRT #417
Updated flight hours /landings: 258,3
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
toivio(at)fly.to (toivio(at)fly.to)
www.rwm.fi
el=nofollow target=_blank>http://www.matronics.com/Navigator?Europa-List
et=_blank>http://forums.matronics.com
Justin(at)systemwise.co.u
PostPosted: Mon Oct 03, 2011 3:00 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Hey,
How about a spinner bolt missing?
Justin
G-ZTED Classic Monowheel
PostPosted: Mon Oct 03, 2011 6:01 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Hanna,
are you sure you are Hanna or in fact Tim, Hanna´s dad (who is going to try to win desperately the shipment from Finland) ? Wink
If you really are Hanna; you may try 2nd time, because you are a pilot´s daughter.
Please read my first mail once again carefully: I wrote
“Soon until well over the ground at altitude +500 feet with full power and 2nd fuel pump still on ... “
Notice also, these words below are really essential info, something maybe to do with prop/pwr –settings:
“Those minutes were long: I put my prob (Airmaster CS) to manual and drived it from fine to coarse, tried all the power settings and also a 2nd fuel filter. Finally I noticed that when prop was in a climb mode (in my case 5400 rpm /Rotax 912S) and MAP around 20 inches I got quite a comfortable flying mode and I headed straight home. “
All,
One of you is now really close, physically say 50 mm /2" inches.
Cheers, Raimo OH-XRT Finland
Sent: Sunday, October 02, 2011 9:39 PM
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Raimo,
Two thoughts.
Fuel starvation with the fuel pumps not turned on for take off?
Cheers,
Hannah
Tim daughter
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
[quote] All
Tips:
Go On!
All
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
zwakie
PostPosted: Mon Oct 03, 2011 6:34 am    Post subject: Re: Heavy In-flight Vibration Riddle Reply with quote
Some sort of contamination found it's way into the spinner hole of one of the prop blades, preventing full travel for just this blade's pitch?
Jet
(Marcel's wife) Wink
Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR
PostPosted: Mon Oct 03, 2011 8:03 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Jet,
you may also guess twice (because you are pilot´s
wife):
- notice that shaking and vibration was not
momentary! Every time I tried to change
powersettings up or down, more or less, an awful
trembling came back. Maybe I am a bit sensitive
(for trembling planes!) but that was really
alarming.
- 5400 rpm & 20 inches were in the lowest point of
that vibration curve
-----Alkuperäinen viesti-----
Sent: Monday, October 03, 2011 5:34 PM
Vibration Riddle
<mz(at)cariama.nl>
Jet
(Marcel's wife) [Wink]
Marcel
(Europa Classic Tri-Gear PH-MZW)
http://forums.matronics.com/viewtopic.php?p=353877#353877
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
europabill(at)bellsouth.n
PostPosted: Mon Oct 03, 2011 8:24 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Ramio,
Sounds like a throttle cable to one carb was loose causing the spring to
hold full throttle on the carb while you could vary the other as it was
connected properly.
Bill
A010 Classic Monowheel
Speedbird
PostPosted: Mon Oct 03, 2011 8:27 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Spark Plugs...?
Cheers!
-----Ursprungligt meddelande-----
Sent: Monday, October 03, 2011 6:00 PM
Subject: Re: Re: Heavy In-flight Vibration Riddle
Jet,
wife):
alarming.
Vibration Riddle
<mz(at)cariama.nl>
Jet
Marcel
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
__________ Information från ESET Smart Security, version av
virussignaturdatabas 6513 (20111003) __________
Meddelandet har kontrollerats av ESET Smart Security.
http://www.esetscandinavia.com
PostPosted: Mon Oct 03, 2011 11:52 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Hi Raimo,
Yes I am Tim’s daughter, Hannah, and my second guess is;
Was the Airmaster Auto/Man switch left on Man for the Take-off?
Cheers,
Hannah
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nz
Sent: Tuesday, October 04, 2011 2:58 AM
Hanna,
All,
Raimo,
Two thoughts.
Cheers,
Hannah
Tim daughter
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
[quote] All
Tips:
Go On!
All
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
bill.sue(at)orcon.net.nz
PostPosted: Mon Oct 03, 2011 12:33 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Hi Raimo,
I suggest your spinner cracked at the rear and lost a piece of metal or the retaining screw.
Cheers from New Zealand
ZK CHV
MONO XS. 914. Airmaster.
950hrs
Sue & Bill
On 4/10/2011 8:49 a.m., Tim Ward wrote: [quote] Hi Raimo,
Cheers,
Hannah
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Hanna,
All,
Raimo,
Two thoughts.
Cheers,
Hannah
Tim daughter
Fendalton,
Christchurch,  8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
All
Tips:
Go On!
All
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
kingsnjan(at)westnet.com.
PostPosted: Mon Oct 03, 2011 1:01 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Raimo,
I don't know if you use tapes to seal any of the flying surfaces but if so, I suspect one might have come unstuck.
Cheers
Kingsley
zwakie
PostPosted: Mon Oct 03, 2011 1:07 pm    Post subject: Re: Heavy In-flight Vibration Riddle Reply with quote
Thanks Raimo for offering me a second chance (Marcel already told me you seem to have a weak spot for women Wink )
My second guess: one of the carb venting tubes got detached from the plenum chamber.
Jet
Marcel Zwakenberg
Trevpond(at)aol.com
PostPosted: Mon Oct 03, 2011 1:33 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Hi Raimo,
Sticky carbuerettor slide.
regards
Trev
G-LINN
In a message dated 03/10/2011 21:33:37 GMT Daylight Time, bill.sue(at)orcon.net.nz writes:
Hi Raimo,
ZK CHV
950hrs
Sue & Bill
Hi Raimo,
Cheers,
Hannah
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
Hanna,
All,
Raimo,
Two thoughts.
Cheers,
Hannah
Tim daughter
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
All
Tips:
Go On!
All
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
ef="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
s.matronics.com/">http://forums.matronics.com
p://www.matronics.com/contribution">http://www.matronics.com/contribution
rambug
PostPosted: Mon Oct 03, 2011 3:14 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Hello this is Françoise, Luc's wife.
Could it be something that obstructed the airflow to the airbox in an intermittent manner ?  Such as a leaf flapping ?
I assume that now, as all spouses, I do get a 2nd chance...  I will use it soon...
Regards from Montreal,
Françoise, Luc and little Iris...
On Mon, Oct 3, 2011 at 09:58, Raimo Toivio <raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)> wrote:
[quote] Hanna,
All,
Raimo,
Two thoughts.
Cheers,
Hannah
Tim daughter
Fendalton,
Christchurch,  8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
All
Tips:
Go On!
To: (europa-list(at)matronics.com)europa-list(at)matronics.com (europa-list(at)matronics.com)
All
37500 Lempaala
FINLAND
p [url=tel:%2B358-3-3753%20777]+358-3-3753 777[/url]
f [url=tel:%2B358-3-3753%20100]+358-3-3753 100[/url]
www.rwm.fi
arget="_blank">http://www.matronics.com/Navigator?Europa-List
Luc Michaud
Europa Monowheel A059
Canadian Registration C-GLOB (in progress)
Montreal, Québec, Canada
grahamsingleton(at)btinte
PostPosted: Mon Oct 03, 2011 3:17 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Could be Trev. One carb on fixed power and the other on variable therefore only smooth at one power setting. Must have been a glide approach when you got home Raimo?
Graham
Sent: Monday, 3 October, 2011 22:31:05
Subject: Re: Europa-List: Heavy In-flight Vibration Riddle
Hi Raimo,
regards
Trev
G-LINN
Hi Raimo,
ZK CHV
950hrs
Sue & Bill
Hi Raimo,
Cheers,
Hannah
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
Hanna,
All,
Raimo,
Two thoughts.
Cheers,
Hannah
Tim daughter
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
All
Tips:
Go On!
All
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
href="http://www.matronics.com/Navigator?Europa-List">[url= target=]http://www.matronhref=[/url]"http://forums.matronics.com">http://forums.matronics.com
http://www.matronics.com/Navigator?Eurank" href="http://forums.matronics.com">http://forums.matronics.com rel="nofollow" target="_blank" href="http://www.matronics.com/contri===
that's what I guessed too
Graham
Sent: Monday, 3 October, 2011 22:07:19
--> Europa-List message posted by: "zwakie" <mz(at)cariama.nl (mz(at)cariama.nl)>
Thanks Raimo for offering me a second chance (Marcel already told me you seem to have a weak spot for women [Wink] )
Jet
Marcel
http://forums.matronics.com/viewtopic.php?p=353931#353931
http://forums.matronics. &nbsptronics.com/contribution" target="_blank">http://www.matronics.com/contri================
rlborger(at)mac.com
PostPosted: Mon Oct 03, 2011 5:02 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Raimo,
I think that Graham is very close. I was thinking that on advancing the throttle only one carb was advancing, that's why it ran better at low throttle setting and with a light load (high rpm setting on prop). One cable kinked in the throttle box so only one carb advanced.
Blue skies & tail winds,
Bob Borger
On Oct 1, 2011, at 2:44 PM, Raimo Toivio wrote:
All
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
<Europa_2011_vibration_grill_party.jpg><Europa_2011_just_before_test_flight.jpg><Europa_2011_just_before_shakeing.jpg><Europa_2011_going_fast.jpg>
keithhickling(at)clear.ne
PostPosted: Mon Oct 03, 2011 5:21 pm    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Or one of the springs that open the throttles come off - it only took 2 seconds to fix remember, and was quite visible. I think the springs come off quite easily.
Keith Hickling,
New Zealand.
"I was thinking that on advancing the throttle only one carb was advancing, that's why it ran better at low throttle setting and with a light load (high rpm setting on prop). One cable kinked in the throttle box so only one carb advanced. "
Bob Borger
PostPosted: Tue Oct 04, 2011 9:12 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Dear Graham,
that was a good one. But is was not reality this time: when I took power off during a long and high final, it was really off.
So it was a glide abroach but only because I wanted so (and the engine was idling).
From: GRAHAM SINGLETON (grahamsingleton(at)btinternet.com)
Sent: Tuesday, October 04, 2011 2:14 AM
Graham
Hi Raimo,
regards
Trev
G-LINN
Hi Raimo,
ZK CHV
950hrs
Sue & Bill
Hi Raimo,
Cheers,
Hannah
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
Hanna,
All,
Raimo,
Two thoughts.
Cheers,
Hannah
Tim daughter
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
All
Tips:
Go On!
All
37500 Lempaala
FINLAND
p +358-3-3753 777
f +358-3-3753 100
www.rwm.fi
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref=/"http://forums.matronics.com">http://forums.matronics.com
[quote]http://www.matronics.com/Navigator?Eurank" href="http://forums.matronics.com">http://forums.matronics.com rel="nofollow" target="_blank" href="http://www.matronics.com/contri===
PostPosted: Tue Oct 04, 2011 9:14 am    Post subject: Heavy In-flight Vibration Riddle Reply with quote
Luc,
what is your girlfriend´s opinion?
If your wife´s name is Francoise, I am sure you have a mistress or even several.
R
Sent: Tuesday, October 04, 2011 2:09 AM
Hanna,
All,
Raimo,
Two thoughts.
Cheers,
Hannah
Tim daughter
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
All
Tips:
Go On!
All
37500 Lempaala
FINLAND
www.rwm.fi
Page 2 of 3
