[Probable Spam] 601 XL bearing bloc material
larry(at)macsmachine.com
PostPosted: Mon Oct 03, 2011 5:53 am    Post subject: [Probable Spam] 601 XL bearing bloc material Reply with quote
HI Michel,
I’m using UHMWE at 3/8-inch thickness that replaced Nylon that absorbed water.
Not so expensive and easy to work.
Reasonable Source:   http://www.k-mac-plastics.net/index.htm
Larry McFarland  601HDS at www.macsmachine.com
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Michel Therrien
Sent: Monday, October 03, 2011 6:35 AM
Subject: [Probable Spam] 601 XL bearing bloc material
Hello group,
As part orf my 601 renovation project, I want to replace the lower nose wheel fork bearing with the newer style 601 XL plastic bloc. I would like to know what material is mandated (delrin, nylon, acetal, UHMWE?) and what is the thickness.
Thanks!
Michel
Michel Therrien CH601-HD, C-GZGQ
http://mthobby.pcperfect.com/ch601
http://pages.infinit.net/mthobby
From: Larry McFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)>
To: Zenith-List <zenith-list(at)matronics.com (zenith-list(at)matronics.com)>
Sent: Wednesday, September 28, 2011 2:46:58 PM
Subject: access panel drawing
Hi guys,
I’ve had a few people ask about a drawing for the inspection panels I use on my 601HDS.
The link below will get you to the drawing on my site and clicking the drawing at the bottom
of the page will get you to a larger image that’s printable. The panels serve my plane well
and have never given any difficulty. If you want to make a set of these, the drawing is
a good guide.
http://www.macsmachine.com/html/winginsppanels.htm
Fly safe guys,
el=nofollow target=_blank>http://www.matronics.com/Navigator?Zenith-Listet=_blank>http://forums.matronics.comllow target=_blank>http://www.matronics.com/contribution
malcolmhunt(at)mha1.fsbus
PostPosted: Mon Oct 03, 2011 6:40 am    Post subject: [Probable Spam] 601 XL bearing bloc material Reply with quote
Hi Michael
The plans call up Nyoil (at) 1.5” thick, can be obtained in England so should be easy with you.
Nylon is not the easiest to work but the part from the factory is expensive.
Hope this helps
Malcolm Hunt
Plans builder in England
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Larry McFarland
Sent: 03 October 2011 14:51
Subject: RE: [Probable Spam] 601 XL bearing bloc material
HI Michel,
Hello group,
Thanks!
Michel
Hi guys,
a good guide.
Fly safe guys,
5
6
7
8
9
__________ Information from ESET Smart Security, version of virus signature database 6512 (20111003) __________
The message was checked by ESET Smart Security.
mtherr(at)yahoo.com
PostPosted: Mon Oct 03, 2011 8:31 am    Post subject: [Probable Spam] 601 XL bearing bloc material Reply with quote
I use 1/4 inch UHMWE flush with the original 1/8" aluminum... i noticed that my gear leg got a bit of wear (0.003") from movement over the 6 years that the plane flew (probably constant rudder movement). I would like to do away of the aluminum contact on the nose wheel... did you make it so that contact is only on the plastic part?
Thanks!
Michel
Sent: Monday, October 3, 2011 9:50:31 AM
HI Michel,
Hello group,
Thanks!
Michel
Hi guys,
a good guide.
Fly safe guys,
PostPosted: Mon Oct 03, 2011 9:26 am    Post subject: [Probable Spam] 601 XL bearing bloc material Reply with quote
Yes Michel,
I noticed wear in the same fore and aft areas and made adjustments to keep the tube
From being in contact with the aluminum. With the UHMWE, that works rather well.
Get a good fit with the bearing plastic and then remove a little aluminum for clearance.
It’ll hold.
Sent: Monday, October 03, 2011 11:28 AM
Subject: Re: [Probable Spam] 601 XL bearing bloc material
Thanks!
Michel
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
HI Michel,
From: owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com) [mailto:owner-zenith-list-server(at)matronics.com] ([email][mailto:owner-zenith-list-server(at)matronics.com][/email]) On Behalf Of Michel Therrien
Hello group,
Thanks!
Michel
Hi guys,
a good guide.
Fly safe guys,
http://www.matronics.com/Navigator?Zenith-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution el=nofollow target=_blank>http://www.matronics.com/Navigator?Zenith-Listet=_blank>http://forums.matronics.com
5
6
7
8
9
mtherr(at)yahoo.com
PostPosted: Mon Oct 03, 2011 7:26 pm    Post subject: [Probable Spam] 601 XL bearing bloc material Reply with quote
I noticed different varieties of Nyloil... there is the green one and then, the MDX (gray or blue). Are they interchangeable? It appears that the kit part is the grey Nyloil (that is filled with Moly...).
Michel
From: Malcolm Hunt <malcolmhunt(at)mha1.fsbusiness.co.uk>
Sent: Monday, October 3, 2011 10:37:46 AM
Hi Michael
Hope this helps
Malcolm Hunt
Subject: RE: [Probable Spam] Zenith-List: 601 XL bearing bloc material
HI Michel,
Subject: [Probable Spam] Zenith-List: 601 XL bearing bloc material
Hello group,
Thanks!
Michel
Hi guys,
a good guide.
Fly safe guys,
5
6
7
8
9
PostPosted: Tue Oct 04, 2011 3:07 am    Post subject: [Probable Spam] 601 XL bearing bloc material Reply with quote
Michael
I have seen both.  These materials are designed to be used as shaft bearings  spinning at some speed.  The friction generated by the nose strut is by comparison of a much lower order.  Don’t forget to grease the strut prior to installation both bearings
Malcolm
Sent: 04 October 2011 04:24
Michel
Hi Michael
Hope this helps
Malcolm Hunt
HI Michel,
Hello group,
Thanks!
Michel
Hi guys,
a good guide.
Fly safe guys,
http://www.matronics.com/Navigator?Zenith-List http://forums.matronics.com http://www.matronics.com/contribution
5
6
7
8
9
__________ Information from ESET Smart Security, version of virus signature database 6515 (20111004) __________
