greghale
Joined: 10 Jan 2007 Posts: 91 Location: Tulsa, Oklahoma
Posted: Sat Oct 01, 2011 4:11 pm Post subject: Free RV Weight and balance program |
Hi Guys,
I have finally released the new RV weight and balance program. The program will work for all RV’s except for the RV3 and RV12. If there are any RV12 drivers that would like to have their aircraft included in the program, drop me an email and I will include it.
The program should be pretty straight forward on the operation, but I would suggest you also print the available 9 page Operation Manual on the web site. The beauty of the program is it will not only show you what your CG is at takeoff, but it will also tell you the CG at the arrival airport. Some owners may be surprised the change in the CG during your flight.
The program is absolutely free. This is my contribution to the RV community that I really enjoy.
You can go directly to this site to install the program. If you do get an error message trying to use the “Run� feature, try using the “Save� feature. That will download the file to your computer. You can then use that file to install the program.
http://nwacaptain.com/10weightandbalance.html
Greg….
www.nwacaptain.com
| | - The Matronics RV9-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV9-List |
_________________ Greg Hale rv10 -- N210KH
www.nwacaptain.com |
ralphmariafinch(at)gmail. Guest
Posted: Sat Oct 01, 2011 6:24 pm Post subject: Free RV Weight and balance program |
I've installed it twice, each time it appears to install without
error, but when I double-click the desktop icon I get an error message
about missing vb40032.dll.
Ralph Finch
RV-9A-QB SA
Davis, California
On Sat, Oct 1, 2011 at 5:11 PM, greghale <ghale5224(at)aol.com> wrote:
Hi Guys,
You can go directly to this site to install the program. If you do get an error message trying to use the “Run” feature, try using the “Save” feature. That will download the file to your computer. You can then use that file to install the program.
Greg….
www.nwacaptain.com
www.nwacaptain.com
greghale
Posted: Sat Oct 01, 2011 6:58 pm Post subject: Re: Free RV Weight and balance program |
Yes...My error.
I have reloaded the program to the web site. You will probably need to remove the program from your computer before attempting another install. On the Start button under the Nwacaptain program, there is an uninstall procedure you can use.
Greg...
