Posted: Mon Sep 26, 2011 11:38 am Post subject: nose wheel tow bar recommendations |
Can anyone give me a brand and location to purchase a tow bar for the 10 which works well with the nose faring?
John
Posted: Mon Sep 26, 2011 12:38 pm Post subject: nose wheel tow bar recommendations |
Bogert makes a tow bar that Spruce sells for the -10. It works great.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Sep 26, 2011, at 3:32 PM, John Gonzalez wrote:
[quote]Can anyone give me a brand and location to purchase a tow bar for the 10 which works well with the nose faring?
John
n223rv(at)wolflakeairport Guest
Posted: Mon Sep 26, 2011 12:47 pm Post subject: nose wheel tow bar recommendations |
Search for Bogart tow bars, they make one specifically for the RV-10 and it works great for me.
http://www.aircraftspruce.com/catalog/pspages/bogibars2.php
-Mike Kraus
RV-10 flying
On Sep 26, 2011, at 3:32 PM, John Gonzalez <indigoonlatigo(at)msn.com (indigoonlatigo(at)msn.com)> wrote:
[quote] Can anyone give me a brand and location to purchase a tow bar for the 10 which works well with the nose faring?
John
Posted: Tue Sep 27, 2011 11:25 am Post subject: nose wheel tow bar recommendations |
Yep, the Bogert bar.
One thing I'm looking for now is a rudder lock. Someone has pics of a "Bogert-like tow bar" doubling as rudder lock that looks like it might be great. However, I tried to see if the actual Bogie bar can be made to fit - and not luck.
Can someone elaborate on the tow bar as rudder lock solution? Was it a Bogie bar? What brand was it.
Bill "learning lean to climb and LOP - very good stuff" Watson
On 9/26/2011 3:32 PM, John Gonzalez wrote: [quote] Can anyone give me a brand and location to purchase a tow bar for the 10 which works well with the nose faring?
rene(at)felker.com Guest
Posted: Tue Sep 27, 2011 11:41 am Post subject: nose wheel tow bar recommendations |
I had two rudder lock failures…..bummer. My third one is just PVC
Looks like this……
| __ |
_|_
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson
Sent: Tuesday, September 27, 2011 1:23 PM
Subject: Re: nose wheel tow bar recommendations
http://forums.matronics.com[/url] - List Contribution Web generous nbsp; --> http://www.matronics.com/c=[/b] [/quote]
speckter(at)comcast.net Guest
Posted: Tue Sep 27, 2011 12:35 pm Post subject: nose wheel tow bar recommendations |
I used the Bogert tow bar and added a couple of carriage bolts on the bottom end to fit in the holes in the rudder peddles. I slide the seat forward onto the tow bar top T and tie the seat belt around the stick and the tow bar for a secure set up. Unfortunately I do not have pictures, but the key is to not allow the tow bar to fall off of the rudder peddles and the large head of the carriage bolts keeps it in place and also puts mild pressure on the brakes to hold the plane steady in a blow. It is simple, you always have it with you and there is no extra weight to carry around.
Gary Specketer
Sent: Tuesday, September 27, 2011 3:22 PM
Posted: Tue Sep 27, 2011 7:59 pm Post subject: nose wheel tow bar recommendations |
Bill,
I had a couple tabs welded onto my Bogie Bar so they fit between the rudder pedal and the tube. That locks the bar in place. Just had to make sure the tabs are positioned so they don't interfere with the nose fairing. Pictures are in the archive.
Then I added a bungee on one of the pivot bolts. The stick rests in the V of the lever handle, and the bungee wraps around the stick to secure the ailerons.
Then clamp the whole thing down with the seat belt. See pics in the archives from 10 June 2010.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Tue, Sep 27, 2011 at 12:22 PM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
[quote] Yep, the Bogert bar.
One thing I'm looking for now is a rudder lock. Someone has pics of a "Bogert-like tow bar" doubling as rudder lock that looks like it might be great. However, I tried to see if the actual Bogie bar can be made to fit - and not luck.Â
On 9/26/2011 3:32 PM, John Gonzalez wrote: | Quote: | Can anyone give me a brand and location to purchase a tow bar for the 10 which works well with the nose faring?
Posted: Wed Sep 28, 2011 8:06 am Post subject: nose wheel tow bar recommendations |
Thanks Dave,
I actually saw that and tried to figure out how the bar was made to fit
in there. Couldn't quite do it and assumed it was a non-Bogie Bar.
I'll have to take a closer look and try again. I understand the tab
thing. Had some trouble with fitting my stick tops thru the V... more
evaluation required.
Bill "loving the flying part" Watson
On 9/27/2011 11:55 PM, Dave Saylor wrote:
| Quote: | Bill,
Dave Saylor
AirCrafters
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
