dougsnash
Posted: Fri Sep 02, 2011 2:34 am Post subject: 701 Nose Strut Bearing Mod |
John, I think you'll find this is just the "newness" of your plane. Mine was stiff the first few flights too but by the end of the test period it was nice and smooth. Make sure you've got some lube on the nylon bearings and it will probably work its way in before too long.
Doug MacDonald
CH-701, NW Ontario, Canada
Sent: Friday, September 2, 2011 3:54:16 AM
Subject: Zenith701801-List: 701 Nose Strut Bearing Mod
I am seriously considering adding a rolling bearing to my nose strut to reduce friction while flying.
Looking at ACS it was unclear if I wanted a DP ( my guess ) or DSP bearing. Anyone have the part number?
Thinking about it more, since I have a gap between the strut stop plate and the support shelf, adding a 2" ID thrust bearing between the two would be the easiest and most foolproof way. Has anyone done this or found such a thrust bearing?
John Marzulli
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?Zenith701801-List
et=_blank>http://forums.matronics.com
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
NYTerminat(at)aol.com Guest
Posted: Fri Sep 02, 2011 5:01 am Post subject: 701 Nose Strut Bearing Mod |
I agree with Doug
Bob Spudis
In a message dated 9/2/2011 6:34:37 A.M. Eastern Daylight Time, dougsnash(at)yahoo.com writes:
Quote: | John, I think you'll find this is just the "newness" of your plane. Mine was stiff the first few flights too but by the end of the test period it was nice and smooth. Make sure you've got some lube on the nylon bearings and it will probably work its way in before too long.
Doug MacDonald
Subject: 701 Nose Strut Bearing Mod
John Marzulli
List href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
ronlee
Posted: Fri Sep 02, 2011 6:55 am Post subject: Re: 701 Nose Strut Bearing Mod |
One would think Zenith would have found a fix to this shortcoming by now.
I put nylon sliders on mine and it helps considerably but is still heavy and does not move freely as it should. Even when I first flew the demo 701 the stiff rudder got my attention and it had tons of time on it. There has to be a better way. Did they use the same system on the 750? If they did it shows they don't care as it has been a topic of disappointment on the 701 for a long time so they are certainly well aware of it. In spite of this I do love my 701 very much.
_________________ Ron Lee
Tucson, Arizona |
dougsnash
Posted: Fri Sep 02, 2011 7:32 am Post subject: 701 Nose Strut Bearing Mod |
Ron, it might be a "pilot preference" thing with regard to the rudder feel. I was happy with the rudder feel on the demo plane and am completely satisfied with the feel of my plane.
As for the 750, there is some difference on how the lower bearing fits together. The lower bearing block is a black plastic material and has the "V" block built into it. There is no metal to metal contact in this setup. I only have the one demo flight for time on a 750 and don't recal there being any rudder feel issues. Additionally, I found the 750 to be more of a "feet flat on the floor" plane that the 701. Not the the 701 has bad adverse yaw, I just found the 750 that much better.
Doug MacDonald
CH-701 from scratch
NW Ontario, Canada
--- On Fri, 9/2/11, ronlee <rlee468(at)comcast.net> wrote:
Quote: |
Subject: Re: 701 Nose Strut Bearing Mod
Received: Friday, September 2, 2011, 9:55 AM
--> Zenith701801-List message posted by: "ronlee" <rlee468(at)comcast.net (rlee468(at)comcast.net)>
Ron Lee
Tucson, Arizona
| [quote][b]
klondike(at)megalink.net Guest
Posted: Fri Sep 02, 2011 7:41 am Post subject: 701 Nose Strut Bearing Mod |
Not to "re-invent the wheel" but---- have you done away with the "V" notch
the strut sits in while in flight? If not, lift the nose off the ground
and watch how this assembly flex(s). Terrible!!!!! After seeing this,
I did away with the "V" notch and made mine without the notch. (many years
ago)
Fritz
mksoucy(at)yahoo.com Guest
Posted: Fri Sep 02, 2011 7:52 am Post subject: 701 Nose Strut Bearing Mod |
If I remember right, Fred S. Poor had the same solution and it worked out great for him.
--- On Fri, 9/2/11, fritz <klondike(at)megalink.net> wrote:
Subject: Re: Re: 701 Nose Strut Bearing Mod
Date: Friday, September 2, 2011, 11:37 AM
--> Zenith701801-List message posted by: "fritz" <klondike(at)megalink.net (klondike(at)megalink.net)>
Not to "re-invent the wheel" but---- have you done away with the "V" notch the strut sits in while in flight? If not, lift the nose off the ground and watch how this assembly flex(s). Terrible!!!!! After seeing this, I did away with the "V" notch and made mine without the notch. (many years ago)
Fritz
stepinwolf
Posted: Fri Sep 02, 2011 7:53 am Post subject: 701 Nose Strut Bearing Mod |
I wonder if anyone has removed the notches completely, making it more like
the Cessna's and Piper's we all learned to fly on. I can't see myself
landing any aircraft with out both feet feverishly working the rudders, so
centering the nose wheel would not be needed, nor be an issue for me.
Robert
_________________ Long wing + vga's, = lo & slo |
Posted: Fri Sep 02, 2011 8:24 am Post subject: 701 Nose Strut Bearing Mod |
yes and replacing the "old metal V notch" with "Teflon" without the notch.
This gives a lot more surface are for the "pin" which goes through the nose
strut to slide on.
If new on site, check archives, should be a lot of info there also.
Posted: Fri Sep 02, 2011 9:27 am Post subject: 701 Nose Strut Bearing Mod |
The 750 uses the design from the 601/650: a large black/gray nylon block
with the V notch formed by the nylon. So no steel on aluminum. Having had a
601 kit in the past I ordered the 601 parts and adapted them for my 701.
Haven't flown it yet.
-- Craig
Posted: Fri Sep 02, 2011 10:53 am Post subject: 701 Nose Strut Bearing Mod |
I'd get rid of the "V" notch, no matter what I used for material.
Fritz
