tricycle conversion
dave.go
PostPosted: Fri Aug 26, 2011 8:36 am    Post subject: tricycle conversion Reply with quote
I emailed the factory and confirmed that a nose wheel conversion is available for my Model IV - 1050. It's pricey enough to discourage me for just now but I might follow up in a few months. Has anyone actually tried and flown a Model IV with the tricycle gear? I understand I be giving up landing on sandbars, farmers fields, and all sorts of out of the way places. I can live with all that. I would be interested in how the nose wheel affects flight, eases landings etc. Just for info. [quote][b]
dave
PostPosted: Fri Aug 26, 2011 9:46 am    Post subject: Re: tricycle conversion Reply with quote
Dave,
I have flown a Trigear Mod 2 and since then converted it to a taildragger for the owner.
Plane handles excellent on the ground but you could go off the runway if you decide to not steer it. ( lazy feet)
I do not think the owner will change it back and he a low time pilot.
You seem to have some reservation on your Kitfox -- 582 not trusted now taildragger not right. My current Mod IV I have over 2000 hours on it on 582 alone and never had a engine failure. Kitfox are a great, fun airplane and they are what you make of it.
I have over 200 videos on youtube and the Kitfox is a blast.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
occom
PostPosted: Fri Aug 26, 2011 12:19 pm    Post subject: tricycle conversion Reply with quote
I wouldn't say I have reservations as such. My 582 works quite well, but I
have not had enough hours behind it to allow me to completely dismiss all
the horror stories people like to tell. As far as the tricycle gear goes, I
am having a little trouble learning to cope with the tailwheel on landing
and am a little frustrated. The plane flies fine and any landing problem are
with me not the aircraft. OTOH two of the major differences between this and
the little Cessna I used to rent are tailwheel and the screaming little
motor, I'm still coming to grips with both of them.
[quote] --
lcfitt(at)sbcglobal.net
PostPosted: Fri Aug 26, 2011 1:41 pm    Post subject: tricycle conversion Reply with quote
Dave, the Kitfox is notoriously squirrely on landing. For the most part, I
believe because the bungee gear comes from the factory seriously toed in. I
checked my new to me 1992 gear and it was toed in almost three degrees per
side. This gear had never been on an airplane and was in new out of the box
condition. Toed in is very destabilizing especially on roll out. I might
suggest that you check the wheel alignment and if toed in use the muscle
method to tweak the gear into alignment and see if it helps. It is a much
less expensive and simpler trick than replacing the engine mount and adding
the nose gear.
Lowell
Sent: Friday, August 26, 2011 1:16 PM
Subject: RE: Re: tricycle conversion
I
I
are
and
Tommy Walker
PostPosted: Fri Aug 26, 2011 1:46 pm    Post subject: Re: tricycle conversion Reply with quote
Excuse me for butting in....
I know nothing! (As Shultz used to say) about tail draggers, but I noticed in the Kitfox catalog they sell some shims to correct that problem. Or at least that's what it looked like to me.
Tommy Walker in Alabama
Do Not Archive.....
[quote="dave.go"]Toed in is very destabilizing especially on roll out. I might
the nose gear.
Tommy Walker
N25A - Anniston, AL
PostPosted: Fri Aug 26, 2011 5:30 pm    Post subject: tricycle conversion Reply with quote
Tommy,
You are correct providing the airplane has either the Grove aluminum spring
gear or their new Bush Gear with the bolt on axles. The original factory
gear came with a welded tube that the axle is inserted into and fastened
with a single bolt through the butt end. The only way to correct the
alignment on these gear legs is to secure the airplane solid and muscle them
into alignment with brute force. It can be done. Denney in the old days
wrote an article on it in the Kitrox Times, their quarterly builders
newsletter.
Lowell
Sent: Friday, August 26, 2011 2:46 PM
Subject: Re: tricycle conversion
Do Not Archive.....
[quote="dave.go"]I emailed the factory and confirmed that a nose wheel
for info.
> [b]
Tommy Walker
N8701 - Anniston, AL
http://forums.matronics.com/viewtopic.php?p=350673#350673
7suds(at)Chartermi.net
PostPosted: Sat Aug 27, 2011 7:21 pm    Post subject: tricycle conversion Reply with quote
Tommy,
When I did my Model 4 it was done exactly as Lowell is describing, brute
force. I snapped a line on the floor of my garage and dropped 2 plumb bobs
from the fuselage to the line to square the plane over it. I then used two
8' aluminum angles against the ends of the axles and squared with a
machinist's square (I did this with my tires off), then measured to the
center line fore and aft. Then you know what axle needs to go what way and
how much, I used a piece of solid shaft that fit snuggly through the tube
where the axle is attached, (I had to pull the axle out each time), I would
slip it through so I had several feet out each side, then as Lowell
mentioned, start pulling. I had to tweak on them several times and each time
I would have to slip the axle back in, re-plumb and check. Once I had it I
put the plane in flight attitude and checked again (Wheel landing position).
I was not looking for perfection but I wanted them close and toed out both
at both 3-point and wheel landing attitudes. If you are having trouble with
darting on landing, this may be your problem.
Lloyd
