PMorel
Joined: 09 Jul 2007 Posts: 62 Location: Locust Grove, GA USA
Posted: Tue Aug 23, 2011 6:37 am Post subject: EGT indicator failure |
Hi,
I have a Westach Quad instrument with one EGT indicator for my Rotax 912 Speedster. I have 340 hours on it and my EGT indicator just seemed to quit working. I use a hose clamp type probe and was wondering if anyone else has had a failure with this? Do the probes go bad? I put a ohm meter on the probe and it shows a little resistance across it between the two leads. I also measured some voltage while heating up the end of the probe. I have continuity from the each lead to the 8 pin connector. Do the actual gauges go bad?
Paul Morel
912 Speedster
Locust Grove, GA
_________________ Paul Morel
912 Speedster
Locust Grove, GA
www.WingsAirPhotos.com |
redrocketrider
Joined: 13 May 2011 Posts: 67 Location: Nervino airport
Posted: Tue Aug 23, 2011 7:25 am Post subject: EGT indicator failure |
Hello, Same system, I just replaced my probe as it was reading erratically, new probe fixed the problem, be sure to get the short probe for your pipe size, mine had a spacer on it and I think that may have also contributed to the problem. Regards, Bob
[quote] From: PMorel (pmorel(at)bellsouth.net)
Sent: Tuesday, August 23, 2011 7:32 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: EGT indicator failure
Hi,
Paul Morel
912 Speedster
Locust Grove, GA
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
_________________ Keep the dirty side down/Blue skies. Bob |
PMorel
Posted: Tue Aug 23, 2011 7:47 am Post subject: Re: EGT indicator failure |
Bob,
That sure makes sense since I didn't have a spacer on my probe. Maybe it bottomed out against the exhaust......I'll make a run over to Aircraft Spruce and see if they have a new probe in stock. Thanks!
Paul
912 Speedster
Locust Grove, GA
