Posted: Fri Aug 19, 2011 7:49 am Post subject: inspecting innards of oil filter |
You need to look at the inside by cutting the element off of the support.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Fri, Aug 19, 2011 at 8:32 AM, thomas sargent <sarg314(at)gmail.com> wrote:
| Quote: | I put a new oil filter in my IO-360 a week ago and cut open the old one.
Does any one know which way the oil flows thru the filter? Does it go from
the inside out to the periphery or the other way round? If it goes from the
outside to the inside, then I only have to inspect the outsie - easily
visible - surface. If it goes the other way, I have to inspect the harder
to get to (= really messy) inner surface.
Tom Sargent, RV-6A, N811WT
burnsm(at)suddenlink.net Guest
Posted: Fri Aug 19, 2011 8:13 am Post subject: inspecting innards of oil filter |
Tom,
Oil flows from outside to the inside.
So, for a quick look you can just spread the pleats. But the right way is to
cut it out of there and lay it flat.
Mark
Connected by DROID on Verizon Wireless
-----Original message-----
To: rv-list <rv-list(at)matronics.com>
Sent: Fri, Aug 19, 2011 15:32:29 GMT+00:00
Subject: inspecting innards of oil filter
Gary.A.Sobek
Posted: Fri Aug 19, 2011 2:14 pm Post subject: inspecting innards of oil filter |
Tom:
Oil goes from the OUTSIDE in. For the past 14-years, I have cut every filter open at oil change on my 2,536 Hobbs hours RV-6. There has NEVER been anything on the inside but I do occasionally find stuff on the outside. Cut the paper off and stretch it out is the proper way to do it. Some guys was it out with solvent to inspect for even smaller parts.
Yes I am an A&P / DAR.
Date: Fri, 19 Aug 2011 08:32:29 -0700
Subject: RV-List: inspecting innards of oil filter
To: rv-list(at)matronics.com
I put a new oil filter in my IO-360 a week ago and cut open the old one. Does any one know which way the oil flows thru the filter? Does it go from the inside out to the periphery or the other way round? If it goes from the outside to the inside, then I only have to inspect the outsie - easily visible - surface. If it goes the other way, I have to inspect the harder to get to (= really messy) inner surface.
t" target="_blank">http://www.matronics.com/Navigator?RV-List
lank">http://forums.matronics.com
rget="_blank">http://www.matronics.com/contribution
