thumbs
Posted: Thu Aug 18, 2011 7:45 am Post subject: Oil and fuel |
I posted this on the Rotax forum but didn't get a response. Pretty sure I will here though. LOL
I have a 97(I think) 503 dual carb Rotax oil injected with about 50 hr on it. As I remember Pennsoil two stroke was the oil to use when I last flew. What are you guys using now? Is it still the best and is it still available?
Also what fuel are your guys using? Are you guys using premium pump gas? Can you get gas without ethanol in it or is that ok anyway?
I read somewhere that one of the causes of engine outs is ethanol in the fuel. Is this right?
thanks for the help
_________________ Gary
Souderton, Pa.
Firestar II |
Arksey(at)aol.com Guest
Posted: Thu Aug 18, 2011 8:06 am Post subject: Oil and fuel |
Garry,
I also have a Rotax 503....i use pennsoil air cooled 2cycle oil and 87 octane auto gas....have had no problems and I burn a lot of it...so I dont let the gas get old...best thing is to fly often....jim swan
Jim Swan Kolb Firestar ll, 503 Rotax , 6147 Wilcox Rd., Eaton Rapids, Mi 48827 ph 517-663-8488 GPS GPS FOR MY RUNWAY N 42 deg 28.581 W084deg 44.825
In a message dated 8/18/2011 11:48:01 A.M. Eastern Daylight Time, gbthacker(at)hotmail.com writes:
| Quote: | --> Kolb-List message posted by: "thumbs" <gbthacker(at)hotmail.com>
Gary
Souderton, Pa.
Firestar II
http://forums.matronics.com/viewtopic.php?p=349856#349856
donaho1(at)verizon.net Guest
Posted: Thu Aug 18, 2011 8:35 am Post subject: Oil and fuel |
Gary, I won`t address what the best oil and fuel combination is,
because I don`t know that answer. I will tell you what I use. Yes,
you can still buy Pennzoil air cooled oil, which is what I use. It is
only sold in 8 oz bottles now, where as it was available in 16 oz
bottles in the past. I use 92 octane fuel from a local gas station.
It does contain 10% ethanol. So far so good. I did put a gascolator
in my fuel system so I could check for water in my fuel tanks. So far
I have never found any water due to separation in my fuel. I also add
marine fuel stabilizer to all my fuel. Some people think it is only
snake oil, but it seems to work for me. For the price, I figure why not.
On another note, at the end of each flying season I drain all the
fuel out of my tanks and use it in my weed whips and chain saws.
(50:1 as I had to remove my oil injector to install my electric
starter) I just finished that left over fuel yesterday. It was about
eight months old and still smelled fresh and my small two strokes ran
fine. Is that due to the stabilizer I add? I like to think so.
One more note. Last night there was an experimental airplane crash
near Scranton Pa. about 60 miles from where I live. The private pilot
was on his first flight in what looked like a Drifter. Witnesses said
they heard the engine running rough then quit, then restart. The
plane went down in a wooded area, the pilot was taken to the hospital
where he passed away. Everyone fly safely out there, including
myself. http://pahomepage.com/fulltext?nxd_id=196107 Lanny N598LF
FSII Numidia Pa.
captainron1(at)cox.net Guest
Posted: Thu Aug 18, 2011 9:27 am Post subject: Oil and fuel |
I flew a Cuyana 430 not long ago I used premium unleaded which had 10% ethanol, and also used syntec 2 cycle oil from Walmart. Motor was smooth and nice.
I have also used it in my 2 cycle Yamaha motorcycle, the synthetic stuff was always much better than the regular mineral oil types. I think the most important thing is the mix ratio, make sure you are never too lean in oil ratio. I in fact I always run it a bit rich in terms oil. I think it was asking for 50/1 I was using 40/1 ratio. Have no idea what the EGT's looked like as I had no instruments. As for the ethanol my unscientific observation is that it did nothing bad, and probably made the motor run a bit cooler as it has less oomph per volume and a higher octane.
Ron (at) KFHU
thanks for the help
Gary
Souderton, Pa.
Firestar II
kugelair.com
Dennis Thate
Posted: Thu Aug 18, 2011 10:20 am Post subject: Re: Oil and fuel |
My Rotax 503 has always been on ;
California Power Systems CPS AV-2 Blend
http://www.rotaxparts.net/scripts/prodView.asp?idproduct=968
The 6 Key Reasons for Rotax 503 Sudden Engine Stoppage:
1. Fuel Filter Clogged
2. Alcohol in Gasoline
3. Old Fuel
4. Inadvertent Mixture Leaning at Idle
5. Engine Warm Up and Shock Cooling
6. Air Filter Clogged
Plugs
NGK BR8ES
Kolb Spark Plugs
Solid Top
Gap. .016 +/- .002
Torquing 204 in. lb.
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern
Last edited by Dennis Thate on Fri Aug 19, 2011 3:41 am; edited 3 times in total |
HShack(at)aol.com Guest
Posted: Thu Aug 18, 2011 10:22 am Post subject: Oil and fuel |
Pennsoil is good- I used it for two years, but IMO the very best is Citgo Sea & Snow for 2 stroke air cooled. Hard to get here in SC but worth the trouble.
On a 503, you are wasting your money if you use premium gas [unless you have to buy premium to get ethanol-free]. 87 octane is fine; been using it for over 500 hrs. Yes, a 503 will run fine with ethanol in the gas, but it's effects are insidious. Over time, problems develope. If you must use it, I suggest you take measures as suggested on this forum.
Howard Shackleford
FS II
SC
| Quote: | As I remember Pennsoil two stroke was the oil to use when I last flew. What are you guys using now? Is it still the best and is it still available?
Dana
Posted: Thu Aug 18, 2011 12:04 pm Post subject: Oil and fuel |
Adding more oil than the manufacturer specifies is actually bad (Cuyuna specified 40:1 BTW so you were fine). More oil = less fuel/air ratio so the engine is actually running lean... which as we all know is bad. Kart racers actually use this to tune their engines when there's no time for a jet change.
Of course more oil also means more chance of plug fouling.
I still use the Pennzoil "2 stroke outdoor" (that's what they call it now), but they recently came out with a new "2 stroke aircraft" oil (which may be the same thing in a bigger bottle and with a bigger price).
Whatever you use, it should be marked "API TC" (as Rotax specifies) and not "TC-W3" which is a marine spec, for oils optimized for the cooler running temperatures of a marine engine.
-Dana
"Ron (at) KFHU" <captainron1(at)cox.net> wrote:[quote] [quote]--> Kolb-List message posted by: "Ron (at) KFHU" <captainron1(at)cox.net>I flew a Cuyana 430 not long ago I used premium unleaded which had 10% ethanol, and also used syntec 2 cycle oil from Walmart. Motor was smooth and nice. I have also used it in my 2 cycle Yamaha motorcycle, the synthetic stuff was always much better than the regular mineral oil types. I think the most important thing is the mix ratio, make sure you are never too lean in oil ratio. I in fact I always run it a bit rich in terms oil. I think it was asking for 50/1 I was using 40/1 ratio. Have no idea what the EGT's looked like as I had no instruments. As for the ethanol my unscientific observation is that it did nothing bad, and probably made the motor run a bit cooler as it has less oomph per volume and a higher octane. Ron (at) KFHU============---- thumbs <gbthacker(at)hotmail.com> wrote: =============--> Kolb-List message posted by: "thumbs" <gbthacker(at)hotmail.com>I posted this on the Rotax forum but didn't get a response. Pretty sure I will here though. LOLI have a 97(I think) 503 dual carb Rotax oil injected with about 50 hr on it. As I remember Pennsoil two stroke was the oil to use when I last flew. What are you guys using now? Is it still the best and is it still available?Also what fuel are your guys using? Are you guys using premium pump gas? Can you get gas without ethanol in it or is that ok anyway?I read somewhere that one of the causes of engine outs is ethanol in the fuel. Is this right?thanks for the help--------GarySouderton, Pa.Firestar IIRead this topic online here:
rickofudall
Posted: Thu Aug 18, 2011 2:44 pm Post subject: Oil and fuel |
As I published a while back after talking to a Shell tech rep, Pennzoil air cooled (Shell owns the Pennzoil brand) is not being produced anymore. The supply that is out there in the supply chain is all there is. The new Shell Two Stroke has Rotax written all over it. Not much doubt about whether its an approved oil. The big thing about API-TC and TC-W3 is that they are not compatible in injection systems. Put together they congeal.
Rick Girard
On Thu, Aug 18, 2011 at 3:01 PM, Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)> wrote:
| Quote: | Adding more oil than the manufacturer specifies is actually bad (Cuyuna specified 40:1 BTW so you were fine). More oil = less fuel/air ratio so the engine is actually running lean... which as we all know is bad. Kart racers actually use this to tune their engines when there's no time for a jet change.
-Dana
"Ron (at) KFHU" <captainron1(at)cox.net (captainron1(at)cox.net)> wrote:
| Quote: | | Quote: | --> Kolb-List message posted by: "Ron (at) KFHU" <captainron1(at)cox.net (captainron1(at)cox.net)>
<gbthacker(at)hotmail.com (gbthacker(at)hotmail.com)> wrote: =============--> Kolb-List message posted by: "thumbs" <gbthacker(at)hotmail.com (gbthacker(at)hotmail.com)>
"courier new,courier">http://www.matronics.com/Navigator?Kolb-List
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Richard Pike
Posted: Thu Aug 18, 2011 4:23 pm Post subject: Re: Oil and fuel |
I tried Pennzoil for one season, worked great, but made a bigger mess on the airplane than Phillips Injex, so I went back to that. Been using Injex since 1983, both as pre-mix and as injected with no problems. If you cannot get Pennzoil, I would suggest Phillips Injex. Google it and see what the jet ski and snowmobile guys have to say about it as it is still readily available and the price is not out the roof.
I try to avoid ethanol gas as it dissolves my epoxy gas tanks. If the feds and their subsidies (call your congressman and complain!) eventually end up putting ethanol in all our gas and I cannot get ethanol free gas any longer, then I will have to redo my gas tanks.
I have personally seen premix with ethanol do weird things and cause problems. It is apparently ok to use up to 10% ethanol when you are running injected oil, but I would never use ethanol gas and premix.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
thumbs
Posted: Thu Aug 18, 2011 5:10 pm Post subject: Re: Oil and fuel |
Thanks for all the help guys. I have been out of the loop for a few years. I am trying to get back into the air and have a lot of questions.
First of all where can I get ethanol free gas? Is there a brand or a grade that is ethanol free?
The next question is, as I understand it from the posts, I can use Pennsoil new 2 stroke oil in my oil injected engine using pump gas with ethanol. The possible problem comes if you premix right?
Since the plane has been sitting for a while one of the things I want to do is replace the fuel lines, filter and prime bulb. I measured the od of the fuel line and it's 3/8". Can I use any fuel line? I was thinking the blue plastic stuff. I am guessing that would be fine. If not what should I use?
I would also like to replace the "equalizer" tube on the carbs. Maybe not the right term but it is the tube that has the small hole in the bottom and runs from one side of the carb to the other. Is that a special tube or can I use any 1/8"od fuel line and put a small hole in the bottom?
I plan to drain the oil res. and put in new oil. Since the engine not run for a while would it be smart to premix a gallon or so of fuel even with the oil injection system in operation just to make sure the first few minutes of running has plenty of oil at the beginning? I know to much oil is a no no but I only wanted to use the premix and oil injection for the first 5 or 10 minutes of running on the ground what do you guys think?
thanks again for the help
Souderton, Pa.
Firestar II |
Dana
Posted: Thu Aug 18, 2011 5:44 pm Post subject: Oil and fuel |
At 08:23 PM 8/18/2011, Richard Pike wrote:
| Quote: | | I have personally seen premix with ethanol do weird things and cause problems. It is apparently ok to use up to 10% ethanol when you are running injected oil, but I would never use ethanol gas and premix. |
Not that ethanol is a good thing (in gasoline, the Scots do wonderful things with it:)), but I've been forced to run ethanol containing gas, premixed, for 10 years now... 5 years in my Kolb (Cuyuna engine) and 10 years in my PPGs. I've never had an internal engine failure of any kind (carb troubles and ignition problems, yes) in that time... and I've run premix stored (in sealed containers!) for 3 months and more.
The biggest problem with ethanol (don't get me started on the corrupt politics involved!) is the effect on non metallic parts. Fiberglass fuel tanks made with polyester resin are a big problem. Rubber parts, (carburetor and fuel pump parts, fuel lines, and engine seals) can also be a problem... though most fuel system parts are alcohol resistant (to an extent) nowadays. The blue fuel line (to answer thumbs' question) holds up reasonably well, but replace it every two years at the most.
-Dana
Whiplash injuries: Research has shown that the rate of return to work was five times greater amongst those who did not see a lawyer compared with those who did.
thumbs
Posted: Fri Aug 19, 2011 11:59 am Post subject: Re: Oil and fuel |
rickofudall
Ok then what Pennsoil do I use? I was over to a shop this afternoon and they had Pennsoil 2 stroke oil in the pints. I looked for the API and it said TC. I am guessing that is not compatible with oil injection.
My 503 is oil injected. What do I use??
thanks
Souderton, Pa.
Firestar II |
Dana
Posted: Fri Aug 19, 2011 12:54 pm Post subject: Oil and fuel |
API TC (which the Pennzoil is) is what you want, what Rotax specifies, and is compatible with oil injection. Despite what some manufacturers may put on the label, there is no special oil to use with oil injection.
-Dana
rickofudall
My 503 is oil injected. What do I use?? |
The dinosours died because they didn't have a space program!
rickofudall
Posted: Sat Aug 20, 2011 6:07 am Post subject: Oil and fuel |
Gary, You have to know what's in it. If you don't, there are two safe ways to go. Give up the pump and premix, or flush out the reservoir, pump and lines and then replace with the oil of your choice.If it helps any, I've had four quarts of Pennzoil Air Cooled that I've been nursing along in my 582's rotary valve reservoir since Sun n Fun 2007. I'm down to my last quart and a half so I'll have to flush and clean soon.
Rick
On Fri, Aug 19, 2011 at 2:59 PM, thumbs <gbthacker(at)hotmail.com (gbthacker(at)hotmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: "thumbs" <gbthacker(at)hotmail.com (gbthacker(at)hotmail.com)>
rickofudall
thanks
Gary
Souderton, Pa.
Firestar II
http://forums.matronics.com/viewtopic.php?p=350005#350005
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
thumbs
Posted: Sat Aug 20, 2011 10:41 am Post subject: Oil and fuel |
Rick
Thanks, I am 99.9% sure I have Pennsoil 2 cycle oil in it now. The reservoir is almost full but it has been in there for about five years. Is this oil still good? The reservoir has been closed all the time. I can get the oil out of the reservoir and the oil line but how do you get it out of the pump?
Gary
Souderton, Pa.
Souderton, Pa.
Firestar II |
Richard Pike
Posted: Sat Aug 20, 2011 11:29 am Post subject: Re: Oil and fuel |
If I was going to change from one sort of oil to another sort and didn't want them to cross contaminate each other, here's what I would do:
Dump in some premix to safely run the engine, pull the oil pump cable to max and start er up, run at about 3,000 rpm. It will pump out the old oil pretty quick. Watch the oil line from the pump and you will see when it quits pumping (or just wait for the smoke to subside to normal levels...) and then dump in the new oil, leave the oil pump cable at max. Run the engine again at around 3,000 until it starts to smoke heavily. Shut it down, check for bubbles in the oil line from the pump, if no bubbles, put everything back to normal, and you ought to be good to go with the new oil.
Richard Pike
Kingsport, TN 3TN0
