l_luv2_fly(at)yahoo.com Guest
Posted: Mon Aug 01, 2011 3:14 pm Post subject: Fuel smell on take off |
Hi All,
I have a Europa with a Rotax 914. I had the engine in at LEAF last year to have them work on an oil leak due to crank case fretting. While the engine was there I had them overhaul the carbs.
Ever since that time I have had a fuel smell which is a common issue with Europa's. For quite a long time I assumed that it was new fuel hoses that I installed and I was slowly going through the process of eliminating each source with no success. Finally I resorted to putting in UV fuel dye and I discovered that the starboard carb was covered with dye.
Pulling the carbs of a 914 is a bit of a pain and before I do so I'd like some suggestions of what would cause a fuel leak at full power.
Thanks in advance, Paul
rlborger(at)mac.com Guest
Posted: Mon Aug 01, 2011 6:51 pm Post subject: Fuel smell on take off |
Paul,
Check the bowl to make sure it's tight. Make sure the gasket is seated properly without breaks or kinks. The pressure in the carb bowl appears to be forcing fuel out.
Rich Shultz is having issues with his carb bowls coming loose and leaking fuel and pressure. In his case, the leak is sufficient to lower the pressure in the bowl, causing fuel to cut out at high boost. The problem was discovered when the mechanic noticed fuel coming out from where the bowl contacts the carb.
Blue skies & tailwinds,
Bob Borger
http://www.europaowners.org/N914XL
Europa XS, Short Wing, Intercooled Rotax 914
rlborger(at)mac.com (rlborger(at)mac.com)
Cel: 817-992-1117
On Aug 1, 2011, at 6:11 PM, Paul McAllister wrote:
| Quote: | Hi All,
h&jeuropa
Posted: Tue Aug 02, 2011 5:23 am Post subject: Re: Fuel smell on take off |
paul,
We had LEAF rebuild our carbs with no problems. At the class we took at LEAF they commented that you have to seal all the plugs in the castings after putting the carbs in a caustic cleaner. If you look at your carbs, do you see clear epoxy around all the plugs? It's easy to see around the plug on the very top of the carb. Perhaps they didn't seal one of yours.
Jim & Heather
N241BW
KeysFox
Posted: Tue Aug 02, 2011 6:12 am Post subject: Fuel smell on take off |
Word of mouth indicates that some of the composite factory LSA planes with
integral wing tanks are experiencing sag in the wing/tank surfaces over
extended time frames, presumably related to constant fuel exposure.
BJ
Kitfox IV 912
| Quote: | Jim:
Interesting point about the EPOXY.
What EPOXY are they using?
NOW - Paul... Are you running MoGas?
I do not know of any EPOXY that will stand up to MoGas.
Never tested AvGas with EPOXY. I would guess there are some that would
work
since there are composite built planes.
Barry
> paul,
> carbs, do
> plug
> Jim & Heather
> N241BW
> http://forums.matronics.com/viewtopic.php?p=348358#348358
_________________ B Jones
N154K
443-480-1023 |
Posted: Tue Aug 02, 2011 8:30 am Post subject: Fuel smell on take off |
Barry,
Europa used Redux for the wing skins and bonding in the fuel strainers among other things. I have found it to be highly resistant to fuel, however it is a very expensive epoxy.
To answer you question I run mogas and always have.
Paul
To: rotaxengines-list(at)matronics.com
Sent: Tuesday, August 2, 2011 8:55 AM
Subject: Re: Re: Fuel smell on take off
Jim:
Never tested AvGas with EPOXY. I would guess there are some that would work since there are composite built planes.
Barry
On Tue, Aug 2, 2011 at 9:23 AM, h&jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
[quote] --> RotaxEngines-List message posted by: "h&jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
paul,
Jim & Heather
N241BW
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
http://www.matro====================
