		don.honabach(at)pcperfect Guest
				 Posted: Thu Jul 21, 2011 7:53 am    Post subject: Liquid Cooled Heads... |
				Saw an ad for this product today in KitPlanes – liquid cooled heads for the Jabiru Engines.
 http://www.rotecaerosport.com/product-info/lch/
 I rarely have cooling problems on my 3300A. Evening though I’m in Arizona, worst case is if the engine gets heat soaked on the ground I have to baby the plane to altitude to avoid going over 350F CHTs during our hot summer days.
 That said, I know others do and this seems like an interesting product. If nothing else, I would feel better about ‘de-stressing the engine’ by running it cooler and distributing the heat load evenly which is impossible to do with the air cooled/carb setup.
 Pete, any thoughts on this?
 Thanks!
 Don Honabach
 Tempe, AZ
 Zodiac 601HDS – 3300A (~200 Hours)
  |  | - The Matronics JabiruEngine-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?JabiruEngine-List |
		aerobiz1(at)gmail.com Guest
				 Posted: Thu Jul 21, 2011 3:15 pm    Post subject: Liquid Cooled Heads... |
				Hi Don,
 I have just completed fitting a set of the Rotec Liquid Cooled Heads on a J230 that had chronic overheating issues, such that it had to have two heads reconditioned at less than 100 hrs from new, and again at 200 hrs.  I made some mods to the carb and induction plenum to try and get better distribution, but the LC heads have made a huge difference.
  I have even gone down 2 sizes in main jet  (#245)  and temps are , if anything, a bit on the cool side.  Very straightforward to fit and sort out the plumbing.  Added 16 lbs to the weight, but am looking at ditching the muffler and running a pair of 3-1 collectors, which should get about 5-6 lbs off.
 We have tried everything else, and it has worked for us.
 Martin
 On Fri, Jul 22, 2011 at 1:52 AM, Don Honabach <don.honabach(at)pcperfect.com (don.honabach(at)pcperfect.com)> wrote:
 Thanks!
 Don Honabach
 Tempe, AZ
 ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
 tp://forums.matronics.com
		djtoddb
				 Posted: Thu Jul 21, 2011 8:28 pm    Post subject: Liquid Cooled Heads... |
				I am also in Phoenix and have a Hyd 3300 on a Titan Tornado and am concerned about High Temps and Head Wear.  The water cooled heads look good but are a bit pricey.  I am also concerned that the 20 amp Alternator will not put out enough current to run the water pump as I already have low amperage issues.  Does anyone know what our original heads are worth in attempt to sell them to offset the cost of the water cooled heads?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
      Todd Bristol
  Great Entertainment isn't expensive... It's Priceless!
  Interactive Entertainment Events, DJs and Game Shows
  Mesa, Arizona
  480-755-4200
  www.djs4u.com
 www.gameshowsamerica.com
 www.condopenasco.com
 --- On Thu, 7/21/11, Martin Hone <aerobiz1(at)gmail.com> wrote:
 Subject: Re: Liquid Cooled Heads...
 To: jabiruengine-list(at)matronics.com
 Date: Thursday, July 21, 2011, 4:11 PM
  Hi Don,
  Martin
 Thanks!
 Don Honabach
 Tempe, AZ
 ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?JabiruEngine-List
 et=_blank>http://forums.matronics.com
  | 	   [quote][b]
  _________________ Titan Tornado II with Jab 3300 |
				 Posted: Thu Jul 21, 2011 10:36 pm    Post subject: Liquid Cooled Heads... |
				Hi Todd.
 I don't think the old heads will be worth much.  I do know that the Rotec LC heads are CHEAPER than the Jabiru ones.  You have a valid point about alternator output.  We used the larger of the two electric water pumps available, and it has not been an issue with the J230 which has a full glass panel , strobes, beacon, GPS etc..  We do have the pump wired to a separate switch for starting, but after jetting the carb it is starting easily in the cold weather we have this time of year.
 Cheers
 Martin
 On Fri, Jul 22, 2011 at 2:24 PM, Todd Bristol <djtoddb(at)yahoo.com (djtoddb(at)yahoo.com)> wrote:
      Todd Bristol
  Mesa, Arizona
  [url=tel:480-755-4200]480-755-4200[/url]
  www.djs4u.com
 --- On Thu, 7/21/11, Martin Hone <aerobiz1(at)gmail.com (aerobiz1(at)gmail.com)> wrote:
 From: Martin Hone <aerobiz1(at)gmail.com (aerobiz1(at)gmail.com)>
 Subject: Re: JabiruEngine-List: Liquid Cooled Heads...
  To: jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)
  Hi Don,
  Martin
  On Fri, Jul 22, 2011 at 1:52 AM, Don Honabach <don.honabach(at)pcperfect.com> wrote:
 Thanks!
 Don Honabach
 Tempe, AZ
  | 	  [b]
		mhubel
				 Posted: Fri Jul 22, 2011 4:43 am    Post subject: Liquid Cooled Heads... |
				Todd,
          For the record, I replaced all the strobes and position lights     with LED types and reduced the current demand significantly, Now all     the lights together are an average of about 1 amp. The Jabiru does     not have much margin but with the LED lights, I believe the load of     the water pump could be tolerated.
      On 07/22/2011 12:24 AM, Todd Bristol wrote:      	  | Quote: |
        Todd Bristol
                        Mesa, Arizona
                        480-755-4200
                        www.djs4u.com
                --- On Thu, 7/21/11, Martin Hone <aerobiz1(at)gmail.com> (aerobiz1(at)gmail.com)               wrote:
                  From: Martin Hone <aerobiz1(at)gmail.com> (aerobiz1(at)gmail.com)
                  Hi Don,
                    Martin
 Thanks!
 Don Honabach
 Tempe, AZ
 Mark Hubelbank
 NorthEast Monitoring
 2 Clock Tower Place
 Suite 555
 Maynard, MA, 01754 - USA
 mhubel(at)nemon.com (mhubel(at)nemon.com)
 978-443-3955 |
  _________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
				 Posted: Fri Jul 22, 2011 10:24 am    Post subject: Liquid Cooled Heads... |
				For what it worth, I have the LED setup on my plane and love it and was pretty much essential after seeing the AMP draw of traditional landing light(s), strobes, etc.
 Just thinking out loud …
 One of the things I’ve been tossing around in the back of my head is to switch out the bing carb. I tend to like to fly at the higher power ratings and get taxed heavily with excessive fuel burn rates using the bing carb. As such, going to a more traditional carb where I can adjust the mixture might make sense and would solve the high burn rate issue (assumption here?),  as would probably messing with the bing needles if I stuck with a bing carb. In either case though, if I do that, chances are my temps will climb so it is a bit of a balancing act for sure. I’m thinking that the LC heads would allow me to have the best of both worlds (low fuel burn rates, high power settings, low temps) even on a hot day sort of thing…
 Don
 P.S. Todd, where are you based in AZ? Any chance over at P19? I thought I saw a Titan there the other day. If so, I’m the red/white Zodie by the fuel pumps.
 From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Mark Hubelbank
 Sent: Friday, July 22, 2011 5:41 AM
 Todd,
 Todd Bristol
 Mesa, Arizona
 480-755-4200
 www.djs4u.com
 Hi Don,
 Martin
 Thanks!
 Don Honabach
 Tempe, AZ
 0123
 45678901
				 Posted: Fri Jul 22, 2011 10:29 am    Post subject: Liquid Cooled Heads... |
				Martin -
 Any chance you could post some pics of the install? In particular anything that would show the water radiator and installation?
 Thanks!
 Don
 From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Todd Bristol
 Sent: Thursday, July 21, 2011 9:25 PM
 Todd Bristol
 Mesa, Arizona
 480-755-4200
 www.djs4u.com<http://www.djs4u.com/>
 www.gameshowsamerica.com<http://www.gameshowsamerica.com>
 www.condopenasco.com<http://www.condopenasco.com>
 --- On Thu, 7/21/11, Martin Hone <aerobiz1(at)gmail.com<mailto:aerobiz1(at)gmail.com>> wrote:
 From: Martin Hone <aerobiz1(at)gmail.com<mailto:aerobiz1(at)gmail.com>>
 To: jabiruengine-list(at)matronics.com<mailto:jabiruengine-list(at)matronics.com>
 Hi Don,
 Martin
 On Fri, Jul 22, 2011 at 1:52 AM, Don Honabach <don.honabach(at)pcperfect.com<http://us.mc1608.mail.yahoo.com/mc/compose?to=don.honabach(at)pcperfect.com>> wrote:
 Thanks!
 Don Honabach
 Tempe, AZ
		Charles R Gallagher
				 Posted: Fri Jul 22, 2011 10:50 am    Post subject: Liquid Cooled Heads... |
				Don,check YOUTUBE...search .Rotec  see it there in action. CRG
 To: "jabiruengine-list(at)matronics.com" <jabiruengine-list(at)matronics.com>
 Sent: Friday, July 22, 2011 1:28 PM
 Subject: RE: Liquid Cooled Heads...
 Martin -
 Thanks!
 Don
 Todd Bristol
 Mesa, Arizona
 480-755-4200
 www.djs4u.com
 Hi Don,
 Martin
 Thanks!
 Don Honabach
 Tempe, AZ
 01234
  ¦·›~‰í²,Þg(–ŠÓM4ÓGÚqü¢êâz¹ÞÁÊ.®'«8^%¦â®á'‚)Þ.+-f¢”Z+ºt±ëaxÆ®‰ârÂâ²Ñ^jÛ«zÃZ¾(¶Ší¡ºèÂǶ¦j|‹ŠËn¶)b¶'¬²ç!jÂâ²Õ'ý+›±Êâ¦Ø¨œ+r¯y'šÈC£	å¡§{ ¬�®Œ,x(Z´P
				 Posted: Fri Jul 22, 2011 11:02 am    Post subject: Liquid Cooled Heads... |
				Thanks!
 Don
 From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Charles Gallagher
 Sent: Friday, July 22, 2011 11:48 AM
 Subject: RE: JabiruEngine-List: Liquid Cooled Heads...
 Martin -
 Thanks!
 Don
 Todd Bristol
 Mesa, Arizona
 480-755-4200
 www.djs4u.com
 Hi Don,
 Martin
 Thanks!
 Don Honabach
 Tempe, AZ
 012345
 67890123456789 	  | Quote: | 	 		  | tp://forums.matronics.com | 	  0 	  | Quote: | 	 		  | tp://forums.matronics.com | 	  1 	  | Quote: | 	 		  | tp://forums.matronics.com | 	  2 	  | Quote: | 	 		  | tp://forums.matronics.com | 	  3 	  | Quote: | 	 		  | tp://forums.matronics.com | 	  4 	  | Quote: | 	 		  | tp://forums.matronics.com | 	  5 	  | Quote: | 	 		  | tp://forums.matronics.com | 	  6 	  | Quote: | 	 		  | tp://forums.matronics.com | 	  7 	  | Quote: | 	 		  | tp://forums.matronics.com | 	  8 	  | Quote: | 	 		  | tp://forums.matronics.com | 	  9
				 Posted: Fri Jul 22, 2011 1:33 pm    Post subject: Liquid Cooled Heads... |
				Hi Don,
 As Richard pointed out, there is a lot on Youtube, but the Rotec website is full of great stuff.  If you want pics of our own installation, email me directly and I can send to you.  Our installation is overly conservative.  We live in a hot part of the world so I oversized the radiator and placed it directly under the prop.  I had to add an inline thermostat to get some temps into it. When I do another one, the radiator will be 1/2 the size and placed under the engine.
 Cheers
 Martin
 On Sat, Jul 23, 2011 at 4:28 AM, Don Honabach <don.honabach(at)pcperfect.com (don.honabach(at)pcperfect.com)> wrote:
 Martin -
 Thanks!
 Don
 From: owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com) [mailto:owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com)] On Behalf Of Todd Bristol
 Todd Bristol
 Mesa, Arizona
 www.djs4u.com
 Hi Don,
  Martin
 Thanks!
 Don Honabach
 Tempe, AZ
  0 12 7-Day Browse, Chat, FAQ,[/b] | 	   http://www.matronics.com/Navigator?JabiruEngine-List" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List[/b][/quote]          - MATRONICS WEB FORUMS a the Web Forums![/b][/quote] ef="http://forums.matronics.com" target="_blank">http://forums.matronic============[/b][/quote]    - List Contribution Web Site -[/b] [/quote]3 bution" target="_blank">http://www.matronics.com/contribution<===================[/b] [/quote]4
				 Posted: Fri Jul 22, 2011 1:40 pm    Post subject: Liquid Cooled Heads... |
				Don,
 You have a few options regarding a mixture adjusting carb - Aerocarb, Ellison TB and Rotec TB.  I have used both the Aerocarb and the Rotec TBI, and the Rotec unit is the more sophisticated.  If you are running unleaded fuel, you might also like to consider adding a wide-band Air Fuel Ratio meter. Makes getting the correct mixture a breeze.
  Also permits running LOP if you are interested in another tin of worms......
 Cheers
 Martin
 On Sat, Jul 23, 2011 at 4:23 AM, Don Honabach <don.honabach(at)pcperfect.com (don.honabach(at)pcperfect.com)> wrote:
 Don
 From: owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com) [mailto:owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com)] On Behalf Of Mark Hubelbank
 Todd,
 Todd Bristol
 Mesa, Arizona
  www.djs4u.com
 Hi Don,
  Martin
 Thanks!
 Don Honabach
 Tempe, AZ
  0 123
 45 67890 1
		Lynn Matteson
				 Posted: Fri Jul 22, 2011 4:10 pm    Post subject: Liquid Cooled Heads... |
				What make of A/F meter do you have, Martin? Answer quickly, as I'm
 heading to Oshkosh with room on my credit card (but none on my
 panel....drats!).    : )
 Lynn Matteson
 Jabiru 2200, #2062
 Prince prop 64 x 30, P-tip
 Rotec TBI-40 injection (sleeved to 36mm)
 Status: flying with "Ramcharger" intake manifold...1142 hrs (since
 3-27-2006)
 On Jul 22, 2011, at 5:37 PM, Martin Hone wrote:
  	  | Quote: | 	 		   Don,
  mixture a breeze.
  worms.......
  Cheers
  Martin
  One of the things Ive been tossing around in the back of my head
  bit of a balancing act for sure. Im thinking that the LC heads
  thing
  Don
  thought I saw a Titan there the other day. If so, Im the red/white
  Todd,
  Todd Bristol
  Mesa, Arizona
  480-755-4200
  www.djs4u.com
  Hi Don,
  Martin
  Saw an ad for this product today in KitPlanes  liquid cooled heads
  I rarely have cooling problems on my 3300A. Evening though Im in
  product. If nothing else, I would feel better about de-stressing
  the engine by running it cooler and distributing the heat load
  Thanks!
  Don Honabach
  Tempe, AZ
  Zodiac 601HDS  3300A (~200 Hours)
  JabiruEngine-List tp://forums.matronics.com_blank">http://
  Navigator?JabiruEngine-List et=_blank>http://
  forums.matronics.comllow target=_blank>http://www.matronics.com/
  contribution
  -- Mark Hubelbank NorthEast Monitoring2 Clock Tower PlaceSuite
  555Maynard, MA, 01754 - USAmhubel(at)nemon.com 978-443-3955
  www.matronics.com/contribution _-
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
				 Posted: Fri Jul 22, 2011 5:43 pm    Post subject: Liquid Cooled Heads... |
				I bought a FAST gauge (analogue, but they have digital)  from JEGS in the States. Love it.
 Not sure they will be at OSH though
 Marty
 On Sat, Jul 23, 2011 at 10:07 AM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
  [quote]--> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
  What make of A/F meter do you have, Martin? Answer quickly, as I'm heading to Oshkosh with room on my credit card (but none on my panel....drats!).    : )
  Lynn Matteson
  Jabiru 2200, #2062
  Status: flying with "Ramcharger" intake manifold...1142 hrs (since 3-27-2006)
   	  | Quote: | 	 		   Don,
  Cheers
  Martin
  Don
  Todd,
  Todd Bristol
  Mesa, Arizona
  www.djs4u.com
  Hi Don,
  Martin
  Thanks!
  Don Honabach
  Tempe, AZ
    ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List tp://forums.matronics.com_blank">http://www.matronics.com/contribution
    ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?JabiruEngine-List et=_blank>http://forums.matronics.comllow target=_blank>http://www.matronics.com/contribution
  -- Mark Hubelbank NorthEast Monitoring2 Clock Tower PlaceSuite 555Maynard, MA, 01754 - USAmhubel(at)nemon.com (USAmhubel(at)nemon.com) [url=tel:978-443-3955]978-443-3955[/url]
  www.mat=============================================
  MS -
  e -
            -Matt Dralle, List Admin.
		Lynn Matteson
				 Posted: Fri Jul 22, 2011 5:55 pm    Post subject: Liquid Cooled Heads... |
				Thanks, Marty....I'll look at Osh, but for the Jegs stuff I'll wait
 until I get back home and then check 'em out.
 Lynn Matteson
 Jabiru 2200, #2062
 3-27-2006)
 On Jul 22, 2011, at 9:40 PM, Martin Hone wrote:
  	  | Quote: | 	 		   I bought a FAST gauge (analogue, but they have digital)  from JEGS
  Marty
  On Sat, Jul 23, 2011 at 10:07 AM, Lynn Matteson <lynnmatt(at)jps.net>
  Lynn Matteson
  Jabiru 2200, #2062
  3-27-2006)
  Don,
  mixture a breeze.
  worms.......
  Cheers
  Martin
  thing
  Don
  Todd,
  Todd Bristol
  Mesa, Arizona
  480-755-4200
  www.djs4u.com
  Hi Don,
  Martin
  Thanks!
  Don Honabach
  Tempe, AZ
  JabiruEngine-List
  MS -
  e -
N369LM |
				 Posted: Tue Jul 26, 2011 1:37 pm    Post subject: Liquid Cooled Heads... |
				Martin,
 Thanks for all the great advice!  Didn’t even know about the Air Fuel Ratio Meters – did a quick search – those are cool and I do love my gadgets <g>!
 Thanks!
 Don
 From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Martin Hone
 Sent: Friday, July 22, 2011 2:38 PM
 Don,
 Also permits running LOP if you are interested in another tin of worms.......
 Cheers
 Martin
 On Sat, Jul 23, 2011 at 4:23 AM, Don Honabach <don.honabach(at)pcperfect.com<mailto:don.honabach(at)pcperfect.com>> wrote:
 Don
 From: owner-jabiruengine-list-server(at)matronics.com<mailto:owner-jabiruengine-list-server(at)matronics.com> [mailto:owner-jabiruengine-list-server(at)matronics.com<mailto:owner-jabiruengine-list-server(at)matronics.com>] On Behalf Of Mark Hubelbank
 Todd,
 Todd Bristol
 Mesa, Arizona
 480-755-4200<tel:480-755-4200>
 --- On Thu, 7/21/11, Martin Hone <aerobiz1(at)gmail.com><mailto:aerobiz1(at)gmail.com> wrote:
 From: Martin Hone <aerobiz1(at)gmail.com><mailto:aerobiz1(at)gmail.com>
 Hi Don,
 Martin
 Thanks!
 Don Honabach
 Tempe, AZ
 tp://forums.matronics.com<http://forums.matronics.com>
 Mark Hubelbank
 2 Clock Tower Place
 Suite 555
 mhubel(at)nemon.com<mailto:mhubel(at)nemon.com>
 978-443-3955<tel:978-443-3955>
				 Posted: Tue Jul 26, 2011 1:56 pm    Post subject: Liquid Cooled Heads... |
				Don,
 I am really impressed with the AFR gauge. Whilst it doesn't monitor each
 individual cylinder, it does tell you what the engine is doing mixture-wise
