Posted: Tue Jul 19, 2011 12:26 pm Post subject: My "fix" for dragging brakes |
Your spring idea is good. However placing a compression spring over the
cylinder shaft would be lighter and maybe more effective solution.
Linn
On 7/19/2011 3:53 PM, billz wrote:
I've been reading about the various dragging brake issues on the forum, talked with several folks and experienced the problem with a friend's RV-10.
1. I found out, from the folks at Matco, that it is critical for the master cylinder to fully extend when pressure is removed from the brake pedals. The last 1/16th in. of piston extension is needed for fluid to bypass internally allowing the brake pads to retract. It doesn't take much to keep pressure on the brake pads. My friend fixed his with a spring arrangement on the pedals.
2. I also learned that minimizing friction in the brake pedals is important. They should move freely with no binding. All bolt holes should be properly drilled to assure free movement. The bolts should not be overly tightened, to minimize drag.
3. The Van's design uses two short AN3 bolts on each side of the bottom of the pedals. This can result in some minor twisting that can add resistance to the pedal movement. Matco suggested replacing these with one long bolt. (I purchased AN3-60 bolts, $10 each) I also used some aluminum tubing over the bolt to provide a spacer inside the pedal flanges. I found springs at McMaster (part # 9271K542 and 9271K542, 270 deg, left and right hand). These were put over the through bolt and aluminum tube. The springs I settled on (to get enough return force) were larger inside diameter than the aluminum tube so I found some old garden hose to put over the tubing as a spacer.
As you can see from the pictures, the springs provide return force and work nicely to provide positive pressure on the pedal and master cylinders. So far, it seems like a "no drag" configuration. Since I'm not flying, a final report will have to wait for the future. Does all this make sense from what others have learned from experience??
http://forums.matronics.com/viewtopic.php?p=347079#347079
http://forums.matronics.com//files/img_1388_336.jpg
http://forums.matronics.com//files/img_1387_104.jpg
http://forums.matronics.com//files/img_1386_109.jpg
msausen
Posted: Tue Jul 19, 2011 1:08 pm Post subject: My "fix" for dragging brakes |
I forgot who did that but I've seen it before and it is what I plan to do.
Michael
billz
Joined: 08 Jul 2009 Posts: 26 Location: Clinton, New York
Posted: Tue Jul 19, 2011 1:22 pm Post subject: Re: My |
I tried a variety of compression springs with collars, as previously shown on the forum. I kept having problems with the spring only having a limited range of compression which limited the travel of the piston. I could only get about 1 in compression before the spring was fully compressed. Matco says all you need is 3/4 in travel, but I wanted to keep the option for greater travel, if needed.
Maybe someone else will have better luck with that approach than I did.
Good Luck!
Posted: Tue Jul 19, 2011 2:11 pm Post subject: My "fix" for dragging brakes |
I replied to Ralph off-line, but just a reminder ......
Slight brake dragging is a natural function of disc brakes. The area
just outside the O-ring collects dirt which doesn't allow the puck to
retract more, and that O-ring gets stiff with time/heat.
The spring remedy only allows the cylinder shaft to extend fully
allowing the fluid pressure to relax. Nothing is available to 'suck'
the brake puck back.
Linn
On 7/19/2011 5:22 PM, billz wrote:
Good Luck!
http://forums.matronics.com/viewtopic.php?p=347095#347095
philperry9(at)gmail.com Guest
Posted: Tue Jul 19, 2011 3:26 pm Post subject: My "fix" for dragging brakes |
It was me. I'll see if I can find some old write ups and photos of the mod. It was easy, cheap, and effective. If I were building another one, I'd do the same thing again.
Phil
On Jul 19, 2011, at 4:05 PM, "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> wrote:
Michael
Tim Olson
Posted: Tue Jul 19, 2011 7:38 pm Post subject: My "fix" for dragging brakes |
While I'm not going to say you shouldn't improve it if
you want to, I will make a couple of comments:
1) We need to make sure that builders understand NOT
to torque the bolts too tight that the pedals hinge on.
If you don't torque them too tight, you're unlikely
to have an issue with them even with the standard bolts.
Improving them isn't going to hurt, but I would say
that it isn't necessary for most people...maybe those
with some parts or things that aren't in normal
tolerances.
2) Regarding the springs, that's the same deal. I don't
think most people will need anything like that. Sure,
it may not hurt, but if you're going to do it, just do
it in a way that doesn't have any other possible failure
mode that could jam the brakes. As long as you
do that, modify them if you think you need to. I just
don't think most people will need to.
3) As was already noted, disc brakes just work with a
bit of drag on them because there is no "retract"
spring for the pistons. You push the brakes, they
go out and touch the discs, and when you release
the brakes they still just barely touch the discs.
Even a standard design for the pedals should not
cause any additional drag, as long as your pedals
retract and you keep your heels on the floor and
don't ride the brakes. So again, while improving
them to your satisfaction isn't a bad thing, It's really
not a necessary thing. You're never going to eliminate
the inherent disc brake drag.
With 750+ hours on mine, and using the standard
setup, I've never seen any reason to have anything
more. The one-piece bolt isn't a bad idea at all,
and if they included it all in the kit, I'd be
happy with it. But don't make all the other builders
think there is some problem with the design, because
those pedals will work just fine per-plans, provided
you don't overtorque or have some other misalignment
that causes the pedals to not move freely. All
builders should make sure that THIS isn't a problem
as they build...then they'll end up with a fine
working system.
Tim Olson - RV-10 N104CD
On 7/19/2011 2:53 PM, billz wrote:
friend's RV-10.
as a spacer.
experience??
ricksked(at)cox.net Guest
Posted: Tue Jul 19, 2011 8:04 pm Post subject: My "fix" for dragging brakes |
I didn't know there was a problem. But I only had 120 hours on mine before it went to it's new owner. I think I'll keep the original on the next one as well. IMHO it's feet that are dragging or riding on the pedals, not the system or design. But I don't piss in buckets either.
Rick Sked
Fuselage number 2 kit 1154
On Jul 19, 2011, at 8:33 PM, Tim Olson <Tim(at)myrv10.com> wrote:
tolerances.
working system.
> friend's RV-10.
> as a spacer.
> experience??
Posted: Tue Jul 19, 2011 8:09 pm Post subject: My "fix" for dragging brakes |
What Tim said.
Plus, keep in mind that the master cylinders have internal springs
that push the piston back out. If they aren't sufficient there could
be another problem. The clothes pin springs and long bolts are a nice
touch but I see a couple of wear points that might need to eventually
be addressed. Fewer parts are usually better!
Make sure the assembly is free, even a little sloppy, and it should work fine.
Dave Saylor 895 hours
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Tue, Jul 19, 2011 at 8:33 PM, Tim Olson <Tim(at)myrv10.com> wrote:
tolerances.
working system.
> friend's RV-10.
> as a spacer.
> experience??
Dick Sipp
Posted: Tue Jul 19, 2011 8:43 pm Post subject: My "fix" for dragging brakes |
We'll have to "ditto" Tim's comments on this issue. We got almost 300 hours
on the first set of pads with a standard per the plans brake installation.
The earlier RV's all had similar issues. In my opinion most of these are
related to the somewhat severe angle that the pedals meet your feet, i.e. it
is very easy to apply brake pressure when you would think you are not.
The -10, IMHO, is the least problematic in this regard so far. (The RV-12
kit includes plastic blocks installed on the bottom of the pedals to reduce
this angle not unlike what others have done as a mod on the 10)
I believe a little practice in the technique of keeping heels on the floor
at all times unless brake application is desired will go a long way to
getting good brake pad life and minimal heating.
Tailwinds,
Dick Sipp
RV-4, RV-10, B-25D
all castering nose wheels and sensitive brakes
Dick Sipp
Posted: Tue Jul 19, 2011 8:46 pm Post subject: My "fix" for dragging brakes |
CORRECTION:
My bad, of course the RV-4 does not have a castering nose wheel.
Dick
Posted: Thu Jul 21, 2011 8:24 am Post subject: My "fix" for dragging brakes |
A day or two late, but here are some details on the mod. I shot a video on my brake lines and someone noticed the return springs. At the bottom of this thread is a narrative description.
http://www.vansairforce.com/community/showthread.php?t=63149
The single best thing one could do is bend the flanges of the pedals inward so the bolt holes are perfectly aligned. This eliminates all binding caused by misaligned boles on both sides of the pedal. Once they're aligned there is absolutely no binding and the pedal is free to do anything it wants. I don't think I even need the return springs now, but since they are there and I already spent the money on them - I left them.
Phil
On Tue, Jul 19, 2011 at 6:22 PM, Phil Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
[quote] It was me. I'll see if I can find some old write ups and photos of the mod. It was easy, cheap, and effective. If I were building another one, I'd do the same thing again.
Phil
On Jul 19, 2011, at 4:05 PM, "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net (rvbuilder(at)sausen.net)> wrote:
> --> RV10-List message posted by: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net (rvbuilder(at)sausen.net)>
> Michael
