		mhubel
				 Posted: Mon Jul 11, 2011 2:04 pm    Post subject: Jabiru 3300 cooling and noise |
				I wonder how others have faired with the Jabiru 3300 in the 601XL airframe.
 I find that even doing everything right, - oil at bottom of dipstick range, 4-5 inches of H2O pressure across the oil cooler and the same on the cylinder heads I have oil temps of 220F with a OAT of 65F at 4500 FT and 6.5 GPH (which is probably about 70% power). Any attempt to run the power even slightly higher results in 230+ temps. At lower altitudes where the OAT is higher, the problem is worse.
 Then there is the ignition. I have put in Magnacore suppression wire on the magnetos. The wire to the plugs seems to be a high quality suppression wire. There are ferrite cores on every wire. While it is much better than the "as supplied by Jabiru" level, it is still not acceptable for hearing ATC at the edges of their normal hand off range.
 I have isolated the radio and tried running it on its own battery (no effect). Disconnecting the antenna wire eliminates all noise so it is all coming in through the antenna. I have removed the P leads on the mags  and verified they have no effect. All the noise seems to be coming through the high voltage side.
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
		psm(at)att.net Guest
				 Posted: Mon Jul 11, 2011 3:21 pm    Post subject: Jabiru 3300 cooling and noise |
				Hi Mark,
 I wonder how big the ground wire is between your engine and central
 ground point.  Mine is a piece of copper braid that is about 1 inch
 across folded (it is actually a tube lying flat).  That is a lot of
 copper.  I have a smaller piece of copper braid going from the central
 ground point, on my firewall, to the metal instrument panel.
 I can't give you a good explanation of why I did this, but a couple of
 decades designing digital electronics for production taught me you just
 can't have too much ground current capacity.
 You can get copper braid wire (it looks like silver because of solder
 dipping) at any amateur radio supplier.
 I don't have much experience yet with this plane but the radio seems to
 work just fine.
 One other nasty possibility is that there just isn't a good shield in
 your radio.  This is not easy to fix.  (Mine is a Garmin SL-30.)
 Paul
 XL just entered flight test.
 On 7/11/2011 3:04 PM, mhubel wrote:
  Mark Hubelbank
  N708HU
  CH601XL
  Jabiru 3300
  Rotec TBI 40-3 carb
  70 hr TAF
  http://forums.matronics.com/viewtopic.php?p=345960#345960
		mhubel
				 Posted: Mon Jul 11, 2011 4:52 pm    Post subject: Jabiru 3300 cooling and noise |
				Paul,
      The ground is a short run of #4 wire. I also had the thought that
 the ground might be making it worse. The only thing that your
 installation might point out is that you have a SL-30. I suspect that
 Garmin had a noise spike suppressor in the design. It is unlikely that
 the radio I have has that. A really good spike suppression circuit can
 reduce the noise 20 db or so. I think I will try an experiment with a
 King handheld that I have access to. Even if that works, it does not
 eliminate the source of the noise, it just masks it.
 On 07/11/2011 7:18 PM, Paul Mulwitz wrote:
  Hi Mark,
  just can't have too much ground current capacity.
  to work just fine.
  Paul
 > airframe.
 > Mark Hubelbank
 > N708HU
 > CH601XL
 > Jabiru 3300
 > Rotec TBI 40-3 carb
 > 70 hr TAF
 Mark Hubelbank
 NorthEast Monitoring
 2 Clock Tower Place
 Suite 555
 Maynard, MA, 01754 - USA
 mhubel(at)nemon.com
 978-443-3955
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
				 Posted: Mon Jul 11, 2011 5:22 pm    Post subject: Jabiru 3300 cooling and noise |
				Hi Mark,
 I think a 1 inch wide copper braid would produce a lot better ground -
 particularly for RF noise - than a #4 round wire cable.  The copper in
 your wire would provide plenty of DC current capacity for the starter
 motor, but RF noise might jump right around it.
 There is a phenomenon called "Skin effect" that makes high frequency
 signals migrate away from the center of a conductor.  The higher the
 frequency the more it stays away from the center.  For very high
 frequency noise - around the 120 MHz used by your comm radio this would
 make your round wire look like a thin tube.
 You can test my idea relatively easily with a big automotive jumper
 cable attached between the engine and ground point on  your firewall.
 If this makes the noise change at all it will give a clue to the real
 problem you are experiencing.  You can coil up the jumper cable and add
 a few tie-wraps to keep it out of the way.
 Ground problems have always been the hardest ones for me to find (along
 with all my colleagues).  Of course this presumes you are not dealing
 with a software problem.  Those accounted for about 99 percent of all my
 field problems.
 Paul
 On 7/11/2011 5:50 PM, Mark Hubelbank wrote:
  Paul,
 > Hi Mark,
 > central ground point, on my firewall, to the metal instrument panel.
 > of decades designing digital electronics for production taught me you
 > to work just fine.
 > Paul
 >> airframe.
 >> Mark Hubelbank
 >> N708HU
 >> CH601XL
 >> Jabiru 3300
 >> Rotec TBI 40-3 carb
 >> 70 hr TAF
		jeffrey_davidson(at)earth Guest
				 Posted: Mon Jul 11, 2011 5:32 pm    Post subject: Jabiru 3300 cooling and noise |
				Mark,
 For the high oil temperatures, you might look at the air intake in the cowling for the oil cooler.  For mine, I fashioned an air plenum to force the air into the oil cooler.  I used Aluminum on the sides of the opening in the Jabiru cowling and a thick piece of rubber baffling riveted to an L that is attached to the rear two oil cooler attachments.  The end result is that air can't go past the cooler either under it or around to the side.  Just a suggestion.
 Jeff Davidson
		DaveG601XL
  Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
				 Posted: Tue Jul 12, 2011 3:30 am    Post subject: Re: Jabiru 3300 cooling and noise |
				Mark,
 I am also using a #4 round cable for engine grounding.  I have an I-com A200 radio, which is certainly not a high-end model that I doubt has anything for spike suppression built-in.  I have no engine-induced radio noise and have been told my transmissions are pretty clear.  I get a little strobe noise in the system, but that is about it.  Have you tried a new antenna or antenna wire?  Antenna installation and grounding to the aircraft skin itself is quite important too.  Also, have you taken your issue to the AeroElectric forum here in Matronics??  There are some real voltheads over there.
 Do you have the early style, flat, automotive oil cooler or the newer Positech cooler.  I have the Positech installed per the Jabiru instructions and have no real issues with it.  Oil temps up to 90F oat are usually below 220F.  202-212F are more typical for an average summer flying day.  I did add some additional aluminum and RTV around the cooler to ensure as much air as possible goes through it, but that is about it.
  _________________ David Gallagher
Cincinnati, OH area |
		mhubel
				 Posted: Tue Jul 12, 2011 4:58 am    Post subject: Jabiru 3300 cooling and noise |
				David,
      I am almost sure the ICOM line all have some form of ANL (automatic
 noise limiting) in the design I will see if I can check that out. It is
 really very simple. Unfourtunately, the Microair M760 I have clearly
 does not. This week, I am going to do some tests with signal processing
 to simulate an ANL. If that works, I will probably build one as an add
 on. The alternative would be to use a Becker radio and I have heard
 mixed reports on the noise rejection of a Becker it may not have ANL
 either. If my test works, I will publish the design.
      I have proved that all the noise comes in through the antenna lead.
 The antenna is on the bottom of the fuselage behind the seats, any
 further back and there would be risk of antenna contact during landing.
 Still one source of noise is the exhaust pipe which can act as an
 antenna. I have not been able to do a test to eliminate that yet. Where
 is your antenna?
      I have the Positech cooler with oversize hose and it is very well
 sealed on the air intake side. There is a lot of air moving through it.
 I am wondering if this engine has one of the rubbing piston cylinders
 and is generating excess heat. It does not show when turning it over by
 hand but when the engine is very hot, perhaps the clearances are too
 small. If that is the issue, I don't think it is being changed.
      Note that I can also keep oil temps down to under 220F (which is
 still above Jabiru recommendations) if I keep the power down to under
 6GPH which is well under 75% given the inefficiency of these engines.
 When I actually want to go somewhere and use a "high cruse" of 2900-3000
 RPM at 4500 to 5500 feet and 7 GPH, the oil temperature climbs sharply.
 On 07/12/2011 7:30 AM, DaveG601XL wrote:
  Mark,
  David Gallagher
  601 XL/Jabiru 3300
  First flight 7/24/08, Upgraded 3/19/10
  Flew it to Oshkosh '09& '10
  180+ hours and climbing!
  http://forums.matronics.com/viewtopic.php?p=346034#346034
 Mark Hubelbank
 2 Clock Tower Place
 Suite 555
 mhubel(at)nemon.com
 978-443-3955
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
		DaveG601XL
				 Posted: Tue Jul 12, 2011 6:37 am    Post subject: Re: Jabiru 3300 cooling and noise |
				Mark,
 You are certainly more well versed in radio technology than I am so I will check out of that discussion and monitor it from aside.  My antenna is mounted on top near the rear of the baggage deck.  I have had people ask me if I tuned my antenna or cable lengths with a SWR meter and all I can do is give a dumb stare in return.  I just hooked them all up and started talking.
 Have you tried extending the rear cowl lip to see if the added pressure drop helps??  Since you already know the pressure drop across your cooler, I assume you are well versed in that trick also.  I have the Sensenich wood prop that I am told is shaped to help with hub airflow.
 How about a new oil temp thermocouple?  They are "usually" pretty bullet proof but that would at least eliminate the instrumentation as a source of your problem.  Dropping it in boiling water and watching the Dynon readout would would serve the same purpose.  Hopefully there are no junctions in the thermocouple wire between the thermocouple and your Dynon.
 Just to compare observations, it looks like you cruise around faster than I do.  If I am just tooling around the area, I set ~2650 RPM.  Solo, this gets me about 115MPH IAS and the 100LL flows at around 4.5 GPH.  If I kick it up to 2850 RPM, it only seems to get me another 10 MPH at 6.5 GPH.  I usually keep the throttle between 2650 and 2750 RPM for cross countries.  With my wood prop, I only see 3000 RPM if I am WOT and in a slight dive.
 Good luck,
		mhubel
				 Posted: Tue Jul 12, 2011 7:25 am    Post subject: Jabiru 3300 cooling and noise |
				David,
      I did the sensor calibration and also did tests with thermocouples
 on both sides of the oil cooler. Even though the pressure difference is
 well within spec, I may still try the bigger lip just for the summer. If
 that helps, then one does ask why.
      If my theory that the exhaust system can act as an antenna (leaking
 RF from the cylinders). then your top mounted antenna would be better
 even if in theory it is not as good for ATC communications. I had a AA-5
 with an antenna on the top and one on the bottom and the bottom mounted
 one was clearly better for some ATC use, that is why I picked the bottom
 location. Still I can think of a way I can do a test to try it without
 actually making a hole and mounting an antenna.
 On 07/12/2011 10:37 AM, DaveG601XL wrote:
  Mark,
  Good luck,
  David Gallagher
  601 XL/Jabiru 3300
  http://forums.matronics.com/viewtopic.php?p=346059#346059
 Mark Hubelbank
 2 Clock Tower Place
 Suite 555
 mhubel(at)nemon.com
 978-443-3955
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
				 Posted: Tue Jul 12, 2011 7:50 am    Post subject: Jabiru 3300 cooling and noise |
				Mark,
 If you think RF from the engine is being radiated from the exhaust
 system then the way to fix this is to improve the grounding of the
 engine.  If the engine is well grounded it cannot radiate any signals.
 Paul
 On 7/12/2011 8:22 AM, Mark Hubelbank wrote:
  	  | Quote: | 	 		   David,
  is well within spec, I may still try the bigger lip just for the
  summer. If that helps, then one does ask why.
  (leaking RF from the cylinders). then your top mounted antenna would
  be better even if in theory it is not as good for ATC communications.
  I had a AA-5 with an antenna on the top and one on the bottom and the
  bottom mounted one was clearly better for some ATC use, that is why I
  picked the bottom location. Still I can think of a way I can do a test
  to try it without actually making a hole and mounting an antenna.
		mhubel
				 Posted: Tue Jul 12, 2011 8:16 am    Post subject: Jabiru 3300 cooling and noise |
				Paul,
      Unfourtunately that is not completely true. The length of the
 exhaust pipe from the muffler is almost an ideal 1/4 wavelength antenna
 at aircraft VHF frequencies. Even if everything is perfectly grounded,
 if some RF energy is coupled from the cylinders or adjacent spark plug
 wires into the exhaust system, it will do an excellent job of radiating.
 Some tests will tell, not easy but it can be done. If this is really
 happening, it might explain why some people have success with resistor
 plugs. We might note that most production aircraft spark plugs are
 resistor designs even with shielded wires. This is all theory.
 On 07/12/2011 11:46 AM, Paul Mulwitz wrote:
  Mark,
  Paul
 > David,
 > thermocouples on both sides of the oil cooler. Even though the
 > pressure difference is well within spec, I may still try the bigger
 > lip just for the summer. If that helps, then one does ask why.
 > test to try it without actually making a hole and mounting an antenna.
 Mark Hubelbank
 2 Clock Tower Place
 Suite 555
 mhubel(at)nemon.com
 978-443-3955
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
