gorejr(at)bellsouth.net Guest
Posted: Fri May 12, 2006 12:16 pm Post subject: Engine prices |
Who do you buy the modified cowl from? Jim
Date: 2006/05/11 Thu AM 09:55:06 EDT
Subject: FW: Engine prices
Ron:
Let me clarify, the ceramic coated exhaust is not required with the BPE
IO-540-X, it is merely an option. The ceramic coating is designed to
keep radiant heat out of the cowl (there has been significant discussion
of this issue on the lists.) We like the Forsling exhaust, because we
have tested it on our dyno and found that it runs nice and gives a small
hp boost on the engine we ran (a new IO-540-X with 9.5:1 compression and
Barrett's Cold Air Induction.) You can use any exhaust you choose. You
would only need the modified cowl if you decided to run our Cold Air
Induction, which is a performance upgrade. It is my understanding that
the modified cowl is scheduled to be priced very similarly to Van's
standard cowl. The IO-540 without Cold Air does not require any
modifications. Hope this helps clarify.
Rhonda Barrett-Bewley
Barrett Precision Engines, Inc.
2870-B N. Sheridan Rd.
Tulsa, OK 74115
(918) 835-1089 phone
(918) 835-1745 fax
www.barrettprecisionengines.com
<http://www.barrettprecisionengines.com/>
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Wednesday, May 10, 2006 7:11 PM
Subject: RE: Engine prices
There's only ~$1K difference between the Vans and Aerosport engines, yet
Vans is certified. Why would anyone buy an experimental from Aero
Sport?? What are the extra 'bangs' that you get for your Aero Sport
'bucks'??
The high performance BPA engine looks like a great package, but throw in
the required ceramic exhaust and a non standard cowl and it becomes an
expensive proposition.
Rhonda(at)bpaengines.com Guest
Posted: Fri May 12, 2006 12:22 pm Post subject: Engine prices |
Sam James is designing the modified cowl, and the first production cowl
is scheduled to be on display at OSH.
Rhonda
Posted: Fri May 12, 2006 5:42 pm Post subject: Engine prices |
Does the modified cowl have a larger lower opening for the cold induction? Thanks Jim I think it needs to be 3 1/2 inch diameter.
Date: 2006/05/12 Fri PM 04:22:31 EDT
Subject: RE: FW: Engine prices
Rhonda
Deems Davis
Posted: Fri May 12, 2006 6:38 pm Post subject: Engine prices |
Jim, I just went through this as I've ordered The BPA IOP 540-X w/ 9:1
pistons, the CAS system, the John Forsling tuned Exhaust and the James
Cowl/Plemmum. According to Will James, The modified cowl will have a
different shaped opening similar to a 'smiley face' to accommodate the
forward facing Barrett Cold Air Induction system. They pointed me to the
eggenfellner website, and the posted pictures of their new cowl for
their H6 engine. here's the link
http://eggenfellneraircraft.com/100_1866.JPG.
Will has been working with Jan & co developing the new cowl for their 6
cyl engine. He is currently working with an RV10 builder who is getting
close to flying and Allen Barrett (BPA) on the Cold air mod, as I
understand it they have already made at least one cowl that's intended
to be a throw away just for test fit purposes. the plan is to have it
all finalized by OSH and be ready for production cowls from final molds.
btw, the reports on the Forsling ceramic coated exhaust is that you can
hold you hand within 1/2 to 1 inch of the manifolds on a running engine
and not get burned. I'm hoping this will help with the reported tunnel
heating probs, that appear to have their root in the heat build up that
occurs in the Van's cowl. As I've recently learned, the openings in the
Van's cowl are soo large that more air bubbles back out of the cowl
around the prop than goes through the baffles and exits through the cowl
openings in the bottom. It all equals a BIG amount of drag. All of that
warm air bubbling around within the cowl can't be a good thing. The down
side to the Forsling exhaust is that if you live in a cold climate (I
don't, it was 103 here today), you will have a harder time pulling heat
off of the exhaust.
Deems Davis # 406
Fuse
http://deemsrv10.com/
Deems Davis
Posted: Fri May 12, 2006 6:55 pm Post subject: Engine prices |
Here's another pic link of the eggenfellner cowl:
http://eggenfellneraircraft.com/100_1871.JPG
I also just remembered something additional that plays into this
discussion, that the James cowl requires a 14" prop spinner.
Deems Davis # 406
Fuse
Posted: Sat May 13, 2006 5:25 am Post subject: Engine prices |
Where could one purchase the eggenfellner cowl? Is this the cowl made by James? Jim
Deems Davis
Posted: Sat May 13, 2006 6:18 am Post subject: Engine prices |
I'm sorry I should have been more clear in my post. Will James is making
the cowl for the eggenfellner H6 engine installation, it is specifically
designed for that engine. The pictures shown are of an RV 6/7 I believe
I have no idea what Will is doing for that engine on RV-10's, I suspect
it would be an entirely different cowl and would NOT be the same as an
IO 540. I only mentioned it as a reference to an inquiry about
modifications to accomodate the forward facing Barrett Cold Air System.
The eggenfellner cowl is an EXAMPLE of what the Cold Air system cowl
will look like when complete for the RV-10.
The benefits to the James cowl/plenum are:
1. imporved cooling efficiency
2. reduced drag (their web site cites a 7-10 mph avg speed increase from
their cowl/pressure plenum installation. This appears to be
substantiated by builder results and air race results.)
The Cowl without the pressure plenum is only a partial solution. It's
the combination of the devices that produces the above results
Deems Davis # 406
Fuse
The cowl without
gorejr(at)bellsouth.net wrote:
>From: Deems Davis <deemsdavis(at)cox.net>
>Date: 2006/05/12 Fri PM 10:54:51 EDT
>To: rv10-list(at)matronics.com
>Subject: Re: FW: Engine prices
>Deems Davis # 406
>Fuse
millstees(at)ameritech.ne Guest
The cowl is made by James, I met him at Sun-n-Fun, and he said the RV-10 the
cowl for the Eggenfellner is basically ready to go. I did not ask about a
IO-540 cowl.
Steve Mills
40486 finishing wings
Posted: Sat May 13, 2006 6:30 am Post subject: Engine prices |
Thanks for your reply. Still a little confused. If one wanted to purchase a modified cowl for a cold induction for the IO-540 for an RV-10 is there a source? Thanks Jim
Date: 2006/05/13 Sat AM 10:15:42 EDT
Deems Davis # 406
Fuse
The cowl without
>>Deems Davis # 406
>>Fuse
Deems Davis
Posted: Sat May 13, 2006 8:44 am Post subject: Engine prices |
Yes Will James
>Deems Davis # 406
>Fuse
>The cowl without
>>>Deems Davis # 406
>>>Fuse
