effectus(at)rogers.com Guest
Posted: Fri Jun 24, 2011 6:05 am Post subject: Plugging holes in fuselage sides |
Hi Everyone,
I am wondering what everyone is doing to seal the two openings at the lower front sides of the fuselage close to where the leading edge of the wing intersects the fuselage.
Dave Hertner
Sent from my Samsung Captivate(tm) on Rogers
Tim Olson
Posted: Fri Jun 24, 2011 6:27 am Post subject: Plugging holes in fuselage sides |
I cut a block of wood to fit, then tacked down tar paper, then covered it with a small piece of asphalt shingle.
Honestly, I filled the hole with clear silicone and cut it when cured to roughly match the contour. It's not a real noticeable thing when done, but I'm sure some folks agonize over it and try fancier things.
On Jun 24, 2011, at 9:00 AM, David Hertner <effectus(at)rogers.com> wrote:
Hi Everyone,
Dave Hertner
rene(at)felker.com Guest
Posted: Fri Jun 24, 2011 6:28 am Post subject: Plugging holes in fuselage sides |
I used Silicone.
Rene' Felker
N423CF
801-721-6080
dlm34077(at)q.com Guest
Posted: Fri Jun 24, 2011 7:02 am Post subject: Plugging holes in fuselage sides |
nichts
kearney
Posted: Fri Jun 24, 2011 7:23 am Post subject: Plugging holes in fuselage sides |
North of the 49th we use duct tape for a more professional finish. Wood / shingles???? How déclassé can you get.
Les
On 2011-06-24, at 8:24 AM, Tim Olson <Tim(at)myrv10.com> wrote:
> Hi Everyone,
> Dave Hertner
Tim Olson
Posted: Fri Jun 24, 2011 7:39 am Post subject: Plugging holes in fuselage sides |
Les,
Duct Tape! Wow, I didn't know you guys up north were that
caught up on technology! You've really come a long ways.
I was going to just use a gob of roofing tar, but figured
the shingles would give it that extra level of protection.
I think Scott Schmidt used about 5 pieces of Hubba Bubba
bubble gum, after chewing it for just the right amount
of time that the flavor wasn't yet gone, but the gum
was more sticky so it would last. It doubles as a bubble
gum flavored air freshener.
Tim Olson - RV-10 N104CD
On 6/24/2011 10:20 AM, Les Kearney wrote:
Les
> covered it with a small piece of asphalt shingle. Tim
> fancier things.
condreyb(at)gmail.com Guest
Posted: Fri Jun 24, 2011 8:07 am Post subject: Plugging holes in fuselage sides |
Proseal works well. Avoid RTV or anything with silicone because of paint adhesion issues later.
Bob
On Fri, Jun 24, 2011 at 9:00 AM, David Hertner <effectus(at)rogers.com (effectus(at)rogers.com)> wrote:
[quote]--> RV10-List message posted by: David Hertner <effectus(at)rogers.com (effectus(at)rogers.com)>
Hi Everyone,
Dave Hertner
br> nics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
-Matt Dralle, List Admin.
scottmschmidt(at)yahoo.co Guest
Posted: Fri Jun 24, 2011 9:14 am Post subject: Plugging holes in fuselage sides |
Dang you Tim, my patent application has not gone through yet on that technique.
-Scott
On Jun 24, 2011, at 9:36 AM, Tim Olson <Tim(at)myrv10.com> wrote:
Les,
> Tim
> Les
> Sent from my iPhone
>> fancier things.
robin(at)PaintTheWeb.com Guest
Posted: Fri Jun 24, 2011 9:25 am Post subject: Plugging holes in fuselage sides |
I left mine as is. I figured it would make for easier draining when I
overshoot the runway landing Lake Tahoe.
Robin
Kellym
Posted: Fri Jun 24, 2011 12:06 pm Post subject: Plugging holes in fuselage sides |
While you are discussing this, anyone anal enough to seal the pop rivet
shank holes in the floor boards to prevent dirt and liquids from getting
where you can't inspect or clean? I suppose pro-seal or superfill are
possibilities, no on RTV because of paint issues.
On 6/24/2011 10:10 AM, Scott Schmidt wrote:
-Scott
On Jun 24, 2011, at 9:36 AM, Tim Olson<Tim(at)myrv10.com> wrote:
> Les,
> do not archive
>> Tim
>> Les
>> Sent from my iPhone
>>> fancier things.
KCHD |
coop85(at)verizon.net Guest
Posted: Fri Jun 24, 2011 4:05 pm Post subject: Plugging holes in fuselage sides |
Most folks end up with some kind of carpet so I can't imagine it would be worth the effort. Doubtful even without the carpet to be honest.
Marcus
On Jun 24, 2011, at 4:01 PM, Kelly McMullen wrote:
While you are discussing this, anyone anal enough to seal the pop rivet shank holes in the floor boards to prevent dirt and liquids from getting where you can't inspect or clean? I suppose pro-seal or superfill are possibilities, no on RTV because of paint issues.
> -Scott
> Sent from my iPhone
>> Les,
>> do not archive
>>> Tim
>>> Les
>>> Sent from my iPhone
>>>> fancier things.
Tim Olson
Posted: Fri Jun 24, 2011 4:38 pm Post subject: Plugging holes in fuselage sides |
Actually, I think that's a great possible location for
Carbon Monoxide to get in so I think sealing it is
a good idea. You'll never notice the hole on the inside
even without carpet, but you'd notice it if you were
up high at altitude and then got CO poisoning...
On 6/24/2011 7:02 PM, Marcus Cooper wrote:
Marcus
>> -Scott
>> Sent from my iPhone
>>> Les,
>>> do not archive
>>>> Tim
>>>> Les
>>>> Sent from my iPhone
>>>>> fancier things.
Posted: Sat Jun 25, 2011 3:10 am Post subject: Plugging holes in fuselage sides |
Everyone,
Thanks for all of the spirited answers. I like how
I can get good information and a good chuckle from
this list.
Dave Hertner
dmaib(at)mac.com Guest
Posted: Sat Jun 25, 2011 1:53 pm Post subject: Plugging holes in fuselage sides |
Nada!
David Maib
40559
Flying
On Jun 24, 2011, at 10:00 AM, David Hertner wrote:
Hi Everyone,
Dave Hertner
