jgh2(at)charter.net Guest
Posted: Wed Jun 22, 2011 2:22 am Post subject: Mag Timing |
See the low cost magneto timing kit at www.MagnetoTimer.com.It works well and can be built and tested quickly.
Jack Haviland
RV-6A
Posted: Wed Jun 22, 2011 5:53 am Post subject: Mag Timing |
At 05:19 AM 6/22/2011, you wrote:
| Quote: | See the low cost magneto timing kit at www.MagnetoTimer.com.
It works well and can be built and tested quickly. |
The "magic" behind a magneto timing light is the
device's ability to detect points opening and
closing when paralleled with a VERY low resistance
of a magneto's p-lead winding.
The DC resistance measured with points-open
is low and goes lower when points close . . .
difficult to see with the garden variety
ohmmeter. The legacy mag-timer used a
buzzer to generate an AC signal (not unlike
the Shower-of-Sparks buzzer) to excite
the p-lead circuit.
[img]cid:.0[/img]
When the mag points are closed, there's a dead
short across the primary of the transformer and
no signal is detected by the neon lamp. When the
points open, the dc resistance rises slightly
but the inductive value rises greatly. The small
AC component that appears between the test leads
is amplified by the transformer to a value sufficient
to light the neon lamp. This is the legacy "buzz box".
Additionally, one could generally hear a change in
the characteristic of the sound from the buzzer
when the points open.
You can still build this device from readily
available parts. For a compendium of magneto
timing devices see:
http://www.aeroelectric.com/articles/Magneto_Timing/
There's a dozen ways to "skin this cat." I've
not tried it, but I'll bet the low-ohms adapter
we developed would detect point-opening/closure
on a mag. I'm certain that the new and improved
version (coming out shortly) would do it.
The directory cited above shows Jim Wier's
approach to exciting the open p-lead with a
2 kHz signal and then detecting the rise in
circuit impedance as points open to light
some leds and give an audible indication.
A google search on 'magneto timing' will
yield dozens of articles and tools . . . each
of which is cited as a better way to skin
the cat. In fact, all such tools from the
lowly buzz-box to the most sophisticated
micro-processor based gee-whiz work as
advertised . . .
Sometimes, the best way to drive a nail
is with a hammer.
31.18 KB |
3329 Time(s) |
