pmnewlon
Posted: Tue Jun 21, 2011 2:01 pm Post subject: push to test circuit for differing loads |
I posted on VAF yesterday and got a partial answer to my question there, which caused me to have more questions so I thought I better get to the right place!
I have seven annunciator LEDs on my panel; as it turns out all but one switch the positive side of the LED but one switches the ground. I understand how to arrange diodes in a push to test circuit if all the LEDs are switched the same way but cannot find an example of a circuit where there is a mixture of ground and positive switching with a single push to test button. The response to my post on VAF suggested a double pole push button but I have not found a suitably small DPST (ON) device. I'd really like to make the circuit with a small SPST (ON) pushbutton but am short on the circuit knowledge.
Does anyone have a reference diagram of such a circuit that I could 'borrow'?
Thanks! Phil
JLuckey(at)pacbell.net Guest
Posted: Tue Jun 21, 2011 3:06 pm Post subject: push to test circuit for differing loads |
Phil,
Just off the top of my head (and without having seen a schematic of your
particular setup) I'd say that what you're asking for is not possible. In a
single pole you could handle the ground legs of the test circuit (with
proper isolation diodes as you mentioned) or the high-side circuit, but not
both.
But I have another suggestion: You could add a small 2-pole relay to manage
the LED test circuitry and control its coil w/ your SPST pushbutton. There
are all kinds of cheap, circuit board mountable, smaller-than-a-sugar-cube
relays that could do the job (I don't have part numbers available to me at
the moment).
Posted: Tue Jun 21, 2011 6:55 pm Post subject: push to test circuit for differing loads |
At 06:01 PM 6/21/2011, you wrote:
Quote: | --> AeroElectric-List message posted by: "pmnewlon" <philn(at)toosan.com>
Does anyone have a reference diagram of such a circuit that I could 'borrow'? |
You betcha. Did this in some airplane wayyyyyyy back when.
The annunciators were light bulbs instead of leds but
the principal is the same.
You can get the parts at Radio Shack . . .
http://tinyurl.com/3lu334y
The transistors operate saturated so given
the intermittent duty service, will not require
heat-sinks. Wire 'em up and truck on. You could
probably get it to work fine with physically
smaller transistors but these TO-200 devices are
robust and easy to mount to a piece of perf-board.
Bob . . . [quote][b]
sprocket(at)vx-aviation.c Guest
Posted: Tue Jun 21, 2011 7:32 pm Post subject: push to test circuit for differing loads |
Check out the IL-4A or IL-12A on this site:
http://vx-aviation.com/page_2.html
The datasheet has the schematic for what you want if you feel like building your own.
Thx,
Vern Little
Vx Aviation
From: Robert L. Nuckolls, III (nuckolls.bob(at)aeroelectric.com)
Sent: Tuesday, June 21, 2011 7:52 PM
Subject: Re: push to test circuit for differing loads
Bob . . . Quote: |
Checked by AVG - www.avg.com
Version: 10.0.1382 / Virus Database: 1513/3718 - Release Date: 06/21/11
Posted: Tue Jun 21, 2011 9:00 pm Post subject: push to test circuit for differing loads |
Ok – devil’s advocate here…
Bob’s schematic parts count: 2 transistors, 4 resistors = 6 components – or -- ONE small, 2-amp, DIP DPDT relay.
Which way is stronger/better/faster/easier?
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Vern Little
Sent: Tuesday, June 21, 2011 20:29
Subject: Re: AeroElectric-List: push to test circuit for differing loads
Thx,
Vern Little
Vx Aviation
Bob . . . Quote: | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c |
06/21/11
0123456789 Quote: | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List | 0 Quote: | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List | 1 Quote: | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List | 2 Quote: | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List | 3 Quote: | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List | 4
pmnewlon
Posted: Wed Jun 22, 2011 2:30 am Post subject: Re: push to test circuit for differing loads |
Thank you guys for your excellent input! Phil
