Posted: Tue Jun 07, 2011 8:09 am Post subject: Brass bus bar |
| Quote: | I really recommend configuring wiring so as to not need a bus bar.
Not sure what this means. In the classic sense, a
bus bar is a solid conductor distribution point from
which multiple branch feeds are taken. The strip of
conductor behind rows of breakers on the panel is
a "bus". The strip of conductor down the center of
a multiple slot fuse holder is a "bus".
But when you want to connect two closely spaced
studs together, like on a pair of contactors with
bar stock, that's a rectangular wire. I can deduce
no value in designing "not to need a bus bar."
They are used wherever they present the elegant
solution for minimizing parts count.
| Quote: | Factoids: Gold is good for low corrosion and its resulting low
resistance. But it only makes sense for very low voltages/currents.
The only time gold has a 'voltage/current' significance
is in the use of gold for switching. The very best
switches and relays for switching tiny signal
levels feature gold plated contacts. But gold
is easily eroded away if the wattage levels
in the switch circuit get very high. We generally
limit the use gold switches and relays in the tens
of milliamps and tens of volts range. See:
http://www.aeroelectric.com/Reference_Docs/Microswitch/
| Quote: | You might think gold might would be a great conductor, but it isn't.
But it's not "bad" either. The conductivity
of gold is relatively insignificant because
nobody makes either wire or bus bars out of gold.
They do PLATE certain conductors with gold for
the purpose of minimizing surface corrosion
. . . the layers are so thin as to add no
significant resistance to the joint.
| Quote: | Factoid: Copper and other metals works even if oxidized
??? Don't know what "works" means. Every material
and the manner in which joints are made with other
materials will drive system performance. If the
materials are particularly reactive with each other
and with oxygen in the presence of moisture, performance
levels will degrade with time.
It's true that the observable surfaces of conductors
can be severely corroded without observable
performance issues . . . this happens because
the metal-to-metal interface between components
is sealed from the environment . . . i.e. GAS
TIGHT.
So whether your "rectangular wires" of choice
are copper, aluminum or brass, both initial
and future performance is dependent upon maintaining
gas-tightness of the joint either by exemplary
craftsmanship on assembly, periodic maintenance
later or both.
| Quote: | so keep those connections clean and tight.
Hear, HEAR!!!!
fvalarm(at)rapidnet.net Guest
Posted: Tue Jun 07, 2011 9:10 pm Post subject: Brass bus bar |
Wow,
I had no idea what a lively discussion my original question would initiate.
I have learned much but not the answer to the original question. Maybe it is
less important than the sum of all the new knowledge in my old noggin.
OK, I understand that my electrician friend's advice about using stainless
bar stock with the stainless terminals is not ideal for aircraft. I still
have not found 1/8" copper bar stock locally and really don't want to ship
it.
What about using some 1/2" copper plumbing pipe, hammer flatten each end of
it's 3" length, drill mounting holes as required and bolt it in?
By the way, the current going through this bar stock connector will max out
at about 55amp under max (everything on) load and is protected by the 60 amp
ANL fuse, to which it is connected.
Bevan
henador_titzoff(at)yahoo. Guest
Posted: Wed Jun 08, 2011 3:16 am Post subject: Brass bus bar |
Wow,
If you cannot find copper bus bar at your location and you do NOT want to have it shipped in, then your obvious solution is to use Roger/Jean Curtis' solution. He/she said that they flattened 3/8" soft copper tubing in a vise, and it works great!
Problem solved.
Henador Titzoff
Sent: Wednesday, June 8, 2011 1:07 AM
Subject: RE: Re: Brass bus bar
--> AeroElectric-List message posted by: "B Tomm" <fvalarm(at)rapidnet.net (fvalarm(at)rapidnet.net)>
Wow,
it.
Bevan
william_slaughter(at)att. Guest
Posted: Wed Jun 08, 2011 4:35 am Post subject: Brass bus bar |
I used a sheet of copper stock and cut the strips I needed from it.
Available at hardware stores and hobby shops. Google K&S to find info. Storm
Copper has everything you can imagine if you decide that you can order it in
after all.
William
Posted: Wed Jun 08, 2011 4:37 am Post subject: Brass bus bar |
it.
1/8" is 'hefty' to your task
That would work too but kind'a . . . well . . .
not very graceful. That piece of pipe would be good
for hundreds of amps . . .
For that connection consider using aluminum. .062",
or so, 3/4" wide. Brighten up the interfacing surfaces before
installation. Maybe use some dielectric grease
on those same surfaces (Permatx 67VR or equal
at hardware or automotive parts stores). Torque
the fasteners well.
flyboy494
Posted: Wed Jun 08, 2011 6:28 pm Post subject: Brass bus bar |
Bevan,
You might try going to an electrical contractor or electrical supply
house and see if they have any scrap electrical panels. A 200A or 400A
panel should have 1/8" thick copper bus bars in it.
Good Luck
Kent
