dlm34077(at)q.com Guest
Posted: Fri Jun 03, 2011 2:49 pm Post subject: fuel pressure sender VDO360003 |
Has any one had one of these fail? usual install is with GRT EIS 6000. When it fails, does it sense zero for high scale? mine has become flaky with a few occasions of slightly high pressure followed by a duration of flight normal range. I have the replacement in the spare parts box in the baggage area but waiting to install. Total time is 429.
dmaib@me.com
Posted: Fri Jun 03, 2011 6:07 pm Post subject: Re: fuel pressure sender VDO360003 |
I am at home and can't confirm the part number, but I recently replaced my fuel pressure sender for the second time after about 370 hours. The first one started acting flaky at about 170 hours. Both times the symptoms were occasional spikes of very high fuel pressure. GRT tells me this is common and sent me a replacement right away, both times. Changing the sender takes about five minutes and does not require "breaking" any fuel lines if installed using the stock Van's manifold.
I don't remember the cost, but seem to remember it was in the $40 range. Maybe less.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Posted: Fri Jun 03, 2011 6:47 pm Post subject: fuel pressure sender VDO360003 |
Sounds like mine; we will see how long it goes. The part number is available
online for about $29 shipped. It is a German part distributed in USA by JEGS
a car "extras" site.
