Mike Welch
Posted: Wed Jun 01, 2011 5:36 am Post subject: Dynon alarm--LED part of the circuit |
Mike,
http://www.allaboutcircuits.com/vol_6/chpt_7/6.html
Here is the LED sequencer part of the circuit. It a fairly straight-forward
circuit. I simply tied the LED sequencer's input to the Alarm Circuit's
LED, so that they both receive power upon activation.
When the alarm signal is activated, the LED on the alarm circuitboard
lights up nice and bright, and the sequencer starts strobing the line of
LEDs on my panel. VERY attention getting for an AOA alarm!!
Like I said, on the kitchen table and hooked up to the 12 volt transformer,
everything works like a champ!! If I apply a power signal (with BOTH of
them unhooked) to either the green wire(the test leg), OR the light blue
wire (the Dynon alarm wire), either one of them activate the whole circuit
of sequencing LEDs.
Mike Welch
mikerv6a(at)ao-cs.com Guest
Posted: Wed Jun 01, 2011 8:31 am Post subject: Dynon alarm--LED part of the circuit |
Hi Mike
Look at the LM555 data on the National Semiconductor
website: http://www.national.com/ds/LM/LM555.pdf
The astable (free-running) oscillator connections
are shown at lower right of page 7. Note that your
circuit lacks RB between pins 6 and 7 of the '555.
The effect of this is that the discharge time is
very short. Sometimes the use of zero resistance
for RB doesn't work reliably. Add a resistor that's
large enough to make the discharge time at least
10 microseconds.
Also, the capacitor at pin 5 that's shown in the
datasheet is missing from your circuit. This capacitor
can reduce noise susceptibility of the '555.
Regarding the burned-out 10K resistor, I suppose
that it could have been a defective part that was
prone to early failure. This is a very rare event in
these kinds of components.
Mike Linse
RV-6A builder
Corvallis, OR
Mike,
straight-forward
transformer,
circuit
of sequencing LEDs.
Mike Welch
Mike Welch
Posted: Wed Jun 01, 2011 9:02 am Post subject: Dynon alarm--LED part of the circuit |
Hi Mike,
Thanks for the time you're putting in for my problem. I do agree the components you
mentioned appear to be missing.
Although it IS a lot of work, I think I'll rebuild the whole thing, and make those changes.
This isn't something that I want to be tempermental.
Can anyone answer if lower the resistances on those 10K's in the Alarm Design circuit
would help, and if so, which ones??
Mike Welch
> Date: Wed, 1 Jun 2011 09:23:59 -0700
| Quote: | From: mikerv6a(at)ao-cs.com
Subject: Re: Dynon alarm--LED part of the circuit
--> AeroElectric-List message posted by: "MikeRV6-A" <mikerv6a(at)ao-cs.com>
Hi Mike
10 microseconds.
Mike Linse
RV-6A builder
Corvallis, OR
> Mike,
> straight-forward
> transformer,
> circuit
> of sequencing LEDs.
> Mike Welch
&g=======================
&g============
Mike Welch
Posted: Wed Jun 01, 2011 10:50 am Post subject: Dynon alarm--LED part of the circuit |
Vern & Mike L,
Rather than rebuild the whole thing, I went ahead and made the
changes you guys suggested. I replaced those two 10K resistors
in the alarm circuit with two 4.7K's. These were the resistors that
went to each leg of the activation leads. I didn't replace any of the
10Ks in any of the rest of the alarm circuit.
Next, I added a 22K resistor, rather than the straight wire that
was there, between pins 6&7 on the 555. I didn't add the capacitor
that you referred to, Mike, that went from pin 6 to ground , on the 555.
I figured if it didn't act right, I'd try it. Besides, I didn't have a value,
so I didn't know what size would work the best.
The results: On the table, it works perfect, just like before!! Now,
for the test that really matters.....the plane. I dropped it in place,
hooked up the LEDs, and the +12 & neg leads. Then I ran a jumper
wire from the instrument bus to the light blue wire. Works perfect!!
So far, so good!!
Now, for the hurdle I couldn't seem to get over!! Unhooked the light
blue wire, and hooked up the green.....IT WORKS!!! Progress finally!!
Now, for the final test.....the joystick button. Plugged it in, pushed it,
and voila'!! Works like a champ!!
I can now say that everything functions as it should!! I really
appreciate your help and pointers, Mike and Vern. Thanks a million!!
Now, I can start the final stages of the plane construction.
Mike Welch
Posted: Thu Jun 02, 2011 10:34 am Post subject: Dynon alarm--LED part of the circuit |
Good work guys.
Bob . . . [quote][b]
sprocket(at)vx-aviation.c Guest
Posted: Thu Jun 02, 2011 4:14 pm Post subject: Dynon alarm--LED part of the circuit |
I still think that you may have the 1N4148 diode wired in reverse. The 10K’s should have worked, but the 4.7K’s may be enough current to forward bias the diode and the base-emitter junction of the 2N3904. The band on the diode should connect to the transistor.
V
Sent: Wednesday, June 01, 2011 11:44 AM
Subject: RE: Dynon alarm--LED part of the circuit
Vern & Mike L,
So far, so good!!
Mike Welch
Checked by AVG - www.avg.com
Version: 10.0.1375 / Virus Database: 1511/3673 - Release Date: 06/01/11
Mike Welch
Posted: Thu Jun 02, 2011 5:47 pm Post subject: Dynon alarm--LED part of the circuit |
Hi Vern,
I think I verified that it was correct, when I was replacing those resisotrs....but I will
double-check, and get back to you.
Thanks, Mike W
Date: Thu, 2 Jun 2011 17:08:02 -0700
.ExternalClass .ecx.hmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Tahoma;} I still think that you may have the 1N4148 diode wired in reverse. The 10K’s should have worked, but the 4.7K’s may be enough current to forward bias the diode and the base-emitter junction of the 2N3904. The band on the diode should connect to the transistor.
V
Vern & Mike L,
So far, so good!!
Mike Welch
-List" target=_blank>http://www.matronics.com/Navigator?AeroElectric-List
ttp://forums.matronics.com
=_blank>http://www.matronics.com/contribution
Mike Welch
Posted: Fri Jun 03, 2011 7:57 am Post subject: Dynon alarm--LED part of the circuit |
Vern,
I just check for the orientation of the 1N4148. Yes, it is correct. The 'band' end
of the diode is sharing the 2N3904 base node (the center leg of the 3904). I turned
the ignition on and did another joystick button check....still working great. By all
accounts, and from what I can tell, everything appears to be operating very well now.
I have a question for Bob Nuchols,
Bob, Does it hurt the circuitry by changing just those two resistors from 10K to 4.7K?
These were the ones that went to the Dynon alarm signal wire, and the test PTT
switch.
Maybe I exceeded the original design abilities of the 10K's (current requirements)
by adding in that 555/4017 cascading LED circuit. All I know at this point is it sure
likes the 4.7K's!
Will there be any deleterious consequences by not changing any of the other
resistors in the Dynon Alarm circuit? Or, can I call it good?
Thanks for all your help, guys.
Mike Welch
V
Mike Welch
Posted: Fri Jun 03, 2011 8:48 am Post subject: Dynon alarm--LED part of the circuit |
Bob N,
My apologies for the mispelling of your name. Nuckolls, not Nuchols.
Mike
[quote] [b]
Posted: Fri Jun 03, 2011 2:37 pm Post subject: Dynon alarm--LED part of the circuit |
At 12:44 PM 6/3/2011, you wrote:
| Quote: | Bob N,
No problem, I've answered to all the above for decades.
Posted: Fri Jun 03, 2011 2:47 pm Post subject: Dynon alarm--LED part of the circuit |
from 10K to 4.7K?
switch.
likes the 4.7K's!
No, not at all. Those values were a WAG based on
best judgement at the time for minimizing loads
on the circuit being monitored . . . but always
subject to tweaking based on observed behaviors.
the other
Probably not . . .within limits. For example, if
you had to reduce a 1000 ohm resistor down to 100
ohms to get something to work, the 10:1 'miss' on
the WAG may point to fundamental mis-understandings of
how things are working . . . or not working.
There's some level of risk for doing design,
development and production by remote control.
Not having it all spread out on the bench where
you can poke, measure, observe and then validate
or modify a circuit has some risks associated
with it. Risks that you've suffered.
Fortunately, there's little or no risk for
what you're doing beyond failure to function. The
power levels your dealing with are not going
to set things on fire.
| Quote: | Thanks for all your help, guys.
I was interesting in watching the exercise
play out . . . and it MIGHT not be over yet.
But much has been discovered so far. Y'all done
good.
