RV10-List: Small Drill Driver Recommendation
johnciolino(at)comcast.ne
PostPosted: Tue May 31, 2011 12:30 am    Post subject: RV10-List: Small Drill Driver Recommendation Reply with quote
Chris,
You can buy a hex drive chuck to convert this drill to a regular chuck. Google “hex drive chuck” for examples.
John Ciolino
RV-8
N894Y
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Chris Colohan
Sent: Monday, May 30, 2011 7:16 PM
Subject: Re: RV10-List: Small Drill Driver Recommendation
Personally, I have one of these Makita drivers:
http://www.google.com/products/catalog?q=makita+fd01w&um=1&ie=UTF-8&tbm=shop&cid=15995060857694302261&sa=X&ei=tSTkTfHTAob0swOkwqEW&ved=0CFgQ8wIwAQ
It works great. The only thing which I'd do differently is have an option for adding a chuck -- having to use hex bits for everything gets old. (Recently I acquired a set of collets for this, perhaps this will make me happier.)
Chris
On Sat, May 28, 2011 at 2:43 PM, Robin Marks <Robin(at)painttheweb.com (Robin(at)painttheweb.com)> wrote:
About a year ago someone on the RV list recommended a small Li Ion drill driver. I looked in the archives but could not find the thread. Anyone out there with a preference on this type of tool?
Robin
get="_blank">http://www.matronics.com/Navigator?RV10-Listtp://forums.matronics.com_blank">http://www.matronics.com/contribution
robin(at)PaintTheWeb.com
PostPosted: Fri Jun 03, 2011 7:34 pm    Post subject: RV10-List: Small Drill Driver Recommendation Reply with quote
Thanks everyone for the Small Drill Driver recommendations. I ended up purchasing these for $130 delivered.
I just arrived home to find them. The quality, weight & balance seem top drawer. Very impressed so far. I basically went this way for a few extra $ mostly to get the second battery (2 batteries required for Hangar use). I consider the impact driver a throw in even though it is also of equal quality.
Robin
 Filesize:  31.82 KB
 Viewed:  2090 Time(s)
