		Dan Bish
				 Posted: Wed Jan 11, 2006 10:03 pm    Post subject: Landing Gear Lever Latch |
 Monowheel builders:
  _________________ Kit A144 - N914RB
Mono, 914F
About 40% done, CM finished, most controls, tower, tailplanes, etc. Working on wing incidence and landing gear. |
				 Posted: Wed Jan 11, 2006 11:09 pm    Post subject: Landing Gear Lever Latch |
				Hello Dan
 1 FL10 is supposed to go into the latch, not act as a standoff. You
 probably want to ream the hole if you can or work up in very small
 increments.
 Ron Parigoris
 "Maybe I'm missing something, but when I put one on the bolt that goes
 through the lever, this places the latch too far to port to fit into the
 slot"
		ward.t(at)xtra.co.nz Guest
				 Posted: Wed Jan 11, 2006 11:14 pm    Post subject: Landing Gear Lever Latch |
				Dan
 The spacer goes through the latch to decrease friction and allow the latch
 to free fall in the down position. (in theory)
 The other spacer rests against the lever 'edge' in the down or up position.
 Make sure it is the right sized spacer in diameter terms to fit within the
 latch.
 Also my advice to you is to fit the  spring (diagram in next email to site)
 to make sure the latch stays down on rough runways. Not staying down
 does spoil your days flying, as I found out on a landing! BUGGER!
 The problem is that you put this latch in situ long before you first use it
 and dust etc can affect the freefall of the latch.
 Hence, landing on a rough undulating strip the latch can bounce up and STAY
 UP! Undercarriage decides to go up as well, very quickly.
 $NZ2 spring will stop this, preventing a $3000 repair bill. Insurance is
 also handy.
 Cheers,
 Tim Ward
 12 Waiwetu Street,
 Fendalton,
 Christchurch, 8005
 New Zealand.
 Ph +64 3 3515166
 Mobile 021 0640221
		mau11(at)free.fr Guest
				 Posted: Thu Jan 12, 2006 3:15 am    Post subject: Landing Gear Lever Latch |
				Bonjour N914RB,
 If you are interesting I made drawings of Safety spring latch. Very easy to install.
   I give to you off line contact me.
 Michel Auvray Builder N145 > 280 hours flight
  bientt,
 ======= le 12/01/2006, 07:02:04 vous criviez: =======
 Monowheel builders:
 Anybody out there notice that Figure 14 in Chapter 28 shows the latch
 (LG12A) being attached with 2 FL10 spacers? Maybe I'm missing something, but
 when I put one on the bolt that goes through the lever, this places the
 latch too far to port to fit into the slot. If I remove it, the latch fits
 right into the slot and the lever fits into the correct position in the
 lower slot.
 I've checked what I think is the most recent version of the builder's manual
 against my older copy but they seem to match. So I'm pretty sure it must be
 something I'm not grasping. Wouldn't be the first time!
 Dan
 Dan Bish
 Kit A144 - N914RB
 Tucson, AZ, USA
 Michel Auvray
 mau11(at)free.fr
 12/01/2006
		Dan Bish
				 Posted: Thu Jan 12, 2006 7:14 am    Post subject: Re: Landing Gear Lever Latch |
				Doh!    I knew it was something I wasn't getting. Makes perfect sense now. Thanks for the tips; I'll be installing the spring too.
 Dan
 N914RB - KitA144
 Tucson, AZ, USA
Mono, 914F
		W.Kroon(at)doscha.nl Guest
				 Posted: Thu Jan 12, 2006 9:59 am    Post subject: Landing Gear Lever Latch |
				Nop, morgen gaat hij de router bekijken (instellingen etc.) Wellicht wordt
 er maar 1 IP adres toegewezen want verbinding hebben wij wel echter laat hij
 ons niet toe. Je hoort van mij
		hansjd(at)online.no Guest
				 Posted: Thu Jan 12, 2006 2:25 pm    Post subject: Landing Gear Lever Latch |
				Bonjour Michel
 Can't you put your drawing on the Forum for us all to see?
 Cheers
 Hans
